Bianchi Super Grizzly Build
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Still waiting for those pics.
I've got an '84 Griz with similar plans.
Quoted: 1372 Post(s)
Liked 1,749 Times
I really want to but every attempt to post a photo on any thread on this site is rejected
Quoted: 5888 Post(s)
Liked 3,471 Times
Also for rims, Sun CR 18 rims are cheap, strong, and good.
Quoted: 2236 Post(s)
Liked 1,314 Times
In my experience, a 36T cog will fit fine. I have tried a 40T on a bike or two. On the first it was working for a while with the stock deore derailer and then wound up with a long cage tourney derailer (sacrilage!).
A 92 Marin that I set up specifically for hill climbing. 42/32/22 x 11-40. I can climb to the point where I'm so slow balance becomes an issue.
The other similar build to the OP was initially a 1x drivetrain 42x11-34 from 11-28. That was nice for a gravel bike. I kept the granny bailout gear as a manual shift option in case I hit a particularly tough hill. https://www.bikeforums.net/cyclocros...e-i-could.html
In that thread, post 39 I talk about swapping out my 11-34 cassette for a sunrace 11-40 cassette, using the same derailer and thumb shifters. This meant changing the hub body to an 8speed but it worked.
Likes For Happy Feet:
Liked 1,749 Times
I'm open to friction considering most bar end shifters are friction.
TXHC
Velocity cliffhanger gets you tubeless and 26” rim brake rims.
If you’re actually going off-road, I’d definitely go tubeless. Here in the desert Southwest, tubeless is a requirement due to all the goat heads.
Ive had great luck with microshift Advent 1x9 11-42. You can even get it in a thumbie version.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
I might have missed it, but what wheel option did you chose go to with?
Regarding the Lauterwasser handlebars, you may want to look at the Nitto/Rivendell Albastache, or one of the many dirt drop-type drop bars that are out there. You might find these much more practical. Plus, installing drop bars on a mountain bike can pose height/reach issues. I suggest you read the MTB drop bar conversion thread in this subforum before you get too far in your build. As someone has already mentioned, the frame may be designed for 130mm spacing. Lots of times you can fit a 135mm axle with a 9-speed freehub, but I know that on my 1986 Kuwahara, the chain would bind up against the dropout when I used a 9-speed cassette, so I am happily using a 7-speed cassette with zero problems. I also recommend going with a triple up front, and using cantilever brakes. You'll find lots of love for cantis on this board.
Likes For wintermute:
I did end up going with a double in the front 44x32? and 9 speed in the back
