Why are top caps tapered?
I was looking in my small parts bin and noticed that a lot of headset top caps have that conical shape on the bottom side.
I find it kind of annoying as you have to leave extra gap between the top of the steerer and the last spacer, otherwise the cap ends up bottoming out on the steerer plug and doesn't actually put any preload on the headset. Sometimes that gap is as much as 5 mm, so you have to use a 10mm spacer (unless you have a 7.5 laying around) as your last spacer.
Can't they just make them flat?
Rant over
Rant over
Quoted: 1438 Post(s)
Liked 1,092 Times
Rant over
Rant over
Likes For dsbrantjr:
Wolftooth makes some pretty neat ones. You can even do away with the spacer.https://www.wolftoothcomponents.com/...ted-5mm-spacer
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Rant over
Rant over
As for spacers, they come in tons of different sizes and are relatively cheap. Just get some extra thin ones to have on hand.
Stuart Black
Stuart Black
Quoted: 714 Post(s)
Liked 800 Times
The taper was never a problem for metal steerer tubes with star nuts and actually made the cap stronger, while reducing weight. They do pose problem with trying to use them on a carbon steerer with a compression plug, which sits flush (or nearly flush) with the top of the steerer. Most compression plugs come with a top cap that doesn't have the taper and work fine with a 5mm spacer on top of the stem.
Likes For dsaul:
