Toe clips / straps
Toe clips / straps
Greetings ,
looking for proper toe clips / straps for my son’s late-80s Bianchi Campione d’Italia. I see various sizes but no sizing chart. He wears size 9ish (U.S.) shoe. So, we figure, medium? Also, what’s a good source for both clips and straps (to avoid having to order from two places and incur double the shipping costs, which in this case tend to amount more than the items themselves)? He’s more or less flexible on the brand - his components right now are a mixed bag - but ideally something that makes sense on an Italian frame. Thanks for your guidance.
Quoted: 1106 Post(s)
Liked 1,328 Times
9 is usually medium, but it may depend on where he likes his feet on the pedal.
You need a LBS or co-op with some old ones he can try, then get the shiny new ones that size.
Likes For oneclick:
Quoted: 4511 Post(s)
Liked 6,378 Times
@walterb
These are classic, clips come s/m or l/xl, you don't want them to be small.
The Bianchi is into the clipless era so... I never use them, oldschool all the way.
https://www.ebay.com/itm/29173622825...0AAOSwUKxYm0Ad
https://www.ebay.com/itm/38173513758...YAAOSwxNxbW2Rf
These are free shipping.
And this is my normal setup.
Double gate for more stability without really tight straps.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...the laminated straps that Velo Orange sells now maintain their stiffness and shape longer than any simple single layer leather toe strap, and they are cheaper than the really good laminated ones from Japan. Pperformance used to sell them in their online store for half as much, but they don't any more. Clips are sort of a personal preference thing. Those Zefals recommended above work fine, but I've lately gone to these Soma clips . They fit my shoe toe better, and the white powdercoated ones are pretty cheap. They sell them in chrome, but at two or three times the price.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
I try to get used Christophe clips from the LBS or co-op. They often come with peddles. I buy new Christophe straps on eBay for under $14 shipped (+ tax).
Quoted: 1079 Post(s)
Liked 1,899 Times
They're a copy of an ICS design:
Likes For P!N20:
Be careful about this purchase. There's one more thing to consider besides the clip's size (length).
If the shoes have tall toe box (like the ones shown below), you will need to buy TALL clips. The extra height will allow the very blunt shoe to fully enter the clip. Without that, the blunt-toed shoe will not be able to go all the way in and the metal clip will quickly damage the leather shoe.
If your shoes have a narrow toe and are tapered top to bottom (like Merziac's photo above), the regular clips will be fine.
Likes For Bad Lag:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
This is all great advice and as a person who hits the coop often I certainly suggest that avenue. Our coop routinely has used clips and straps. Personally I buy the straps whenever they are cheap for touring and commuting with loads. The straps are great for securing bulky items to a rack or trailer. Pretty much better than anything else I have tried.
Likes For 52telecaster:
Quoted: 1819 Post(s)
Liked 1,693 Times
@walterb
Likes For alcjphil:
Liked 6,378 Times
Well I tried, guess that will be the case no matter what. Can you search efbay for Canadian sellers maybe? I realize they would be more $$$ just because.
Likes For merziac:
Liked 6,378 Times
Likes For merziac:
Quoted: 4806 Post(s)
Liked 3,928 Times
Random comments from a guy who's got way over 100,000 miles on toeclips. (And who has been pulling them tight and pulling up hard on the pedals to climb and accelerate the whole time.) Plastic toeclips are simply better because they are lighter and far easier to pick up. Also survive the "crunch" when the tip hits the road as the pedal hits 6 o'clock. Yes, they break sooner than metal but serve far better in the meantime.
Christophe straps, while being very time appropriate on almost any era bike, are the bare minimum quality as a strap to be ridden hard. Yes, laminated should be better but not all are of good quality. Some are junk. Really good quality simple leather straps can be far better. I raced the all leather Bindas back in the day and used many since. If you come across them, grab them.
And I've given up on the quest to find those good ones. (They're out there. But usually expensive and no longer there next time I need a pair.) I simply have the local leather shop cut me 1/2" strips of their quality cowhide and rivet them to quality old buckles. For me, toestraps are consumables; lasting somewhere between cloth handlebar tape and chains.
I was able to remove the lugs and cleats by unscrewing them and installed thick rubber just like you show. The toe box is still too tall for conventional clips.
Liked 6,378 Times
I got inspired by this thread and dug out my new in the box Republic's. I took the front lugs off and ground off the guides, sanded the soles, cleaned them with solvent and put big dabs of Shoe-goo on, filling the cleat slots so the plates got stuck in place.
Walked around on the slick concrete in the garage and then test rode them today and they worked very well, going to add more Shoe-goo and see how well it stays stuck in regular use, protective soles are still the back up plan.
The dual gate Soma Oppy clips are big enough and I have tweaked them to work even better.
Toe clips are tough so they can be hard to tweak, patience is key as they can break or get sprung out of shape if you go too far, but you have to go pretty far to make it stick so its a process. I do them on the pedal on the bike so you can really lean into it carefully.
The fit and the ride with them was very good so I am good with the fit at this point.
These shoes may be a bit shorter in the toe box and they have some give but so far they work great, still if need be the clips would see it my way.
Here's some pics.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
While on this topic, I found a way to get toe straps through the holes in the pedals without them stripping the finish off the edges of the straps. I applied some Lexol leather cleaner to the edges of the straps before pushing them through. It lubricates the leather so it can slip through pretty easily without damaging the leather, then the Lexol dries and disappears in a few hours, leaving no oily stuff, no color change, and no evidence that it was ever there. Use some more later when you want to remove the straps.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Likes For CroMo Mike:
Liked 6,378 Times
Liked 6,378 Times
was I waiting for?
Have had these for a long time.
Likes For merziac:
Bikes: Masi Gran Crit, Bianchi Campione D' Italia 84, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway, Bianchi Infinito CV, Colnago Master
Quoted: 68 Post(s)
Liked 129 Times
Well the protective soles are` only about 1/8 - 3/16ths thick and on those shoes and make for a good fit once the straps are adjusted right.
Here's some pics.
Here's some pics.
I'm also about to test another set up by using the Vittoria cleats by bolting one side of the SPD slot and one bolt from the side cleats.
Likes For Thalia949:
Liked 6,378 Times
I would be interested in finding out how your glueing project turns out for the republics. I have a leather pair where I've removed the side pieces and I am considering finding a cobbler to do the same.
The shoe-goo will be on going, hoping that adding some more will shore it up better, we'll see, I may add some grooves for it to stick to if it doesn't hold up.
Going to fill in the screw holes with it to resolve the last bit of slip and slide, may be challenging to keep them from being slippery the last 10% of the time.
Quoted: 68 Post(s)
Liked 129 Times
Thought I would share a pic of what I am trying with my Republic LX's - attaching a Vittoria cleat. I've ridden once with this, but need to get the position right before I drill the cleat to attach to the bolt point where the lug was.
Not at all sure if I will end up with this as a solution. I like the idea of gluing a sole on the bottom as I have bad knees and need a high amount of float - which the cleat does not provide.
Liked 6,378 Times
Likes For merziac:
Quoted: 68 Post(s)
Liked 129 Times
Thanks merziac - I agree with you on the screw mount. I may be better served using these cleats on another shoe and going the sole route!
Liked 6,378 Times
I was out on another ride yesterday afternoon and stopped at a shoe shop that I had talked to about the protective soles I had put on the other shoes, it was done at a different shop.
I asked this shop about protective soles on the republics and they said they wouldn't want to do it for the danger of the sole peeling up and getting stuck in the pedal while riding.
They probably have a good point as the Shoe-goo struggles to stay stuck so better prep and and or a glue may need to be found.
I'm going to ramp up the prep and goo, probably should have left the ridge guides for the lugs alone to provide a hardstop for the goo.
