NBD - Schwinn Le Tour ('86?) *** HUGE pics
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 76 Post(s)
Liked 89 Times
NBD - Schwinn Le Tour (1987) *** HUGE pics
Not that it matters to anyone but me, but I think (almost conclusively) that this is a 1987 model based on the catalog (https://waterfordbikes.com/SchwinnCa...0/1987_08.html).
This popped up on the local Facebook Marketplace, and apparently I'm now collecting older lugged Schwinns from my youth/teen years ( recently picked up a BioPace equipped CrossCut as well ). I got a deal. Based on the logos and colorway, it seems like it must be a 1987, but the groupo doesn't make much sense to me as it's got BioPace with Suntour components. Anyone have any thoughts on this? The previous owner said he "had it tuned up" and then blew a tire and bent the rim ( the rim is def repairable by maybe 5-10 minutes on my truing stand ). The tires are flat, and the rear tire tread has a HUGE slash in it... if I had to guess, someone tried pumping it up at the gas station and BLEW it!
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
Likes For RobertUI:
That’s in nice shape. As to the components it make perfect sense. Schwinn was looking to meet a price point for their models and picked components accordingly.
Give it a good lube, grease and wipe down, you should be on your way. It’s a 21” sized frame.
Likes For 3speedslow:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
I was thinking that this would be a good candidate for a clunker challenge. The frame size is a tad small for me, but probably a good choice, so I should be able to put many miles on this. I'm planning to leave it mostly in tact as is for a while, though the BioPace rings might have to go, we'll see. The wheels are really heavy, so I may go ahead and swap them out with my spares, I'll just have to pick up some spacers (all of my spares have 10 speed cassettes).
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
The bike looks nice! Why do the rear dropout slots appear to be filled? It looks like you can slide the axle in only a third of the way before it hits white painted metal. Was this common?
Likes For hokiefyd:
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
There's a whole lot of parts blending on that bike- looks like Maillard skewers (I'd guess Maillard hubs then?) You can also see it doesn't have the "lawyer CLIPS" on the front hub. (I knew of the "lawyer clips" on this era of Schwinns- and it made sense, they were clips and mandated to be put on by lawyers. But it was confusing to me to read people talking about "lawyer LIPS." It was years before I actually saw lawyer lips and then it made sense to me.)
The Shimano crankset paired with the indexing Suntour RD, a non-matching Suntour FD and like Simplex shifters....
There's a lot going on- and it wasn't from Schwinn.
Commence to jigglin’ huh?!?!
Quoted: 3449 Post(s)
Liked 2,800 Times
provided the illusion of a forged dropout, stamped of thick enough material to allow an integrated derailleur hangar. Higher perceived value.
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
The lawyer clips were definitely there on my crosscut, but it looks like someone removed the clips form the wheels, I was kinda surprised they were 'missing' (I didn't miss them when pulling the front wheel). And yes, I do think they're Mallard hubs (haven't spent too much time on it, as I have other priorities right now). For what I paid, I can definitely get my money back by selling a part or two, but I was trying to figure out if this is how it was originally sold (in which case, I'd keep it together). I worked in repair shops during this time period ~87-94 and don't recall ever seeing Suntour & Shimano mixed like this, with the simplex shifters... definitely an odd duck here!
-- I guess the upside is that it's roughly my size, and the frames in excellent condition, with barely any scratches on the decals.
This caught my eye as well.
Liked 1,678 Times
It looks like you've got an FC124 and FC6206- I can't tell the difference between them right off hand- but either way- they're both good cranksets (with the 6206 being way better than "good")
Likes For The Golden Boy:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
Not that the LeTour was particularly high on the food chain, but I think "upgraded" is not the word you'd use for what happened here.
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
I checked and of course I didn't luck out with the 6206 The crank set is Shimano FC-B124, which is nice enough, really no need to change. I've got some tires on the way that'll help get this one on the road (actually rotating tires around 2 of my other bikes, giving this an older set). After replacing the cables, I think I'm just going to ride it as is and see if I like it, maybe it'll take over for my training (with cyclops trainer) setup?
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
I just picked up an 85, detailed elsewhere. I think most of your components are original, but I don’t think the triple crank is, and I wonder about the rear derailleur.
the malliard hubs mentioned earlier are original, I believe.
Likes For denaffen:
Quoted: 822 Post(s)
Liked 1,387 Times
Maillard hubs lasted on LeTours through '89 - they went to SunTour Blaze for 1990.
Likes For rustystrings61:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
EDIT: A quick searching on ebay for the following:
- Shimano FD Z204 (Front Der)
- Shimano RDL-523 (Rear Der)
- Shimano SLL-434 (Shifters)
- Sugino DVP-130 (Crankset)
... tells me I will NOT be 'restoring' this to original. I think I will ride it AS-IS and if I like the frame, I'll do a resto-mod and put some spare 105 (~2014) components on it and ride the snot out of it. It's also very possible that this will make it back to the market place as a rideable bike.
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
I'm obviously becoming obsessed, but I zoomed in to the picture on the catalog I linked, and it looks like the Suntour X 5000 rear derailleur may be original. This shot shows that it's obviously NOT the shimano because of the black line.. and you can kinda make out Suntour
Quoted: 117 Post(s)
Liked 198 Times
My 85 has a suntour ar or arx front derailleur, so it would make sense that it would be suntour ar or arx in the rear too. Which is what that pic looks like to me.
Likes For denaffen:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
Thanks, that's really great info! I am guessing that it probably changed from month to month with which (Suntour or Shimano) could get you parts cheaper. What crankset do you have on your '85?
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 521 Post(s)
Liked 943 Times
I've used my '88 LeTour as a test platform for various drive trains including an SR OvalTech Triple, a Shimano round triple, and various doubles. The frame fits me and is comfortable to ride on rough rural roads, so I keep playing around with different combinations. Currently it is wearing Shimano tri-color 600.
1988 Le Tour with Shimano Tri color and Brooks
1988 LeTour w/ triple and fenders
1988 Le Tour, as purchased with Sun Tour AccuShift.
Likes For Pompiere:
Quoted: 2432 Post(s)
Liked 638 Times
About four years ago I bought that exact model. Did an easy restoration on it and had it looking new. The second ride I took it on the freewheel, which was original, locked up for a split second. It threw the chain off so hard that the rear derailleur ripped completely off and the hanger twisted almost in a complete 360 beyond repair. Never saw or heard anything like that happening before. I pulled out my chain breaker and set it up as a single speed to limp home and the frame had to go in the trash. I was so pissed because it was a very nice ride.
But yeah mine had lower end components.
Likes For Lazyass:
Quoted: 117 Post(s)
Liked 198 Times
Sufi no cranks on mine. Sorry it’s not a better pic
Likes For denaffen:
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
NIce bike.
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
I got it tuned up this weekend, but wound up not being able to ride it because I STUPIDLY didn't think about the fact that the wheels are not 700c!!!! I felt like a total newbie moron when I looked at the rim (as the tire wouldn't go on) and saw 27 1??" and said out loud "oh yeah, that's a thing". I completely forgot as it's been a few years since I dealt with 27s. The wheels cleaned up pretty well, but now I need to find a tire. I stopped at my closest (not favorite) LBS, and the mechanic convinced me that I needed a Schwinn specific tire (I also remember that was a thing) but I told him the rims were marked 27 1??" Weinmann and he told me that wasn't good enough, that I needed to bring them the original tire (I had ridden another bike there). I then came home and got more confused when I couldn't find what he was talking about on the tire... there IS a marking that says SCHWINN after the 16x630 ISO and 27 something. So.. I am asking here to see if anyone can recommend tires. I do NOT believe these are "hookless" and am planning to get something like this: (https://www.ebay.com/itm/29269151691...r=592593031726) Kenda K36 27 x 1-1/8" . Does anyone else have another suggestion? The original tire had a 7" slice along centerline of the tread. The previous owner had lined the tire with duct tape, which obviously didn't hold :-)
FWIW, I did take a nice 19 mile ride on my other lugged Schwinn (resto-mod)!
Bikes: A bunch of old bikes.
Quoted: 265 Post(s)
Liked 821 Times
You do not need any Schwinn specific tire for those rims.
I would suggest buying wire bead instead of folding, just in case the rims don't have hooks. The wire beaded will work on both, folding no.
I like the Pansela Panaracer tires, they are not the fastest, but they ride nice.
Likes For daverup:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
Likes For daverup:
Monkey Boy
Quoted: 76 Post(s)
Liked 89 Times
I had a very happy discovery last night ( as I am patiently awaiting a cheap-ish tire to get this rideable ) as I put a 700C wheel on the front to just do a quick gear-changing test ride. The original Dia-Compe brakes have PLENTY of adjustment, and the 700C works without any changes beyond the brake pad position. What's really crazy is that the tire on the wheel ( only wheel that was within reach ) is a Kenda 40mm and it FITS with a little wiggle room. I certainly couldn't run these with a fender, but it worked perfectly!!! I am now VERY glad that I opted for a single replacement tire b/c I think I'm going to wind up riding this with a different wheelset all together. I'll hold onto the originals for the day I decide to sell, but that was a very happy discovery!
*****EDIT: I didn't look when I did my experiment with the 700C wheel on the front. The rear brake is already maxed out for the back wheel, so I'd need so do some kind of offset (pads or binder bolt) to make the frame work with a 700C rear wheel. I'm leaving this edit here in case anyone else cares.
