Brake help
Brake help
Hi I’ve done a bleed on my Shimano xt done it a few times and my lever almost touching the handlebars I’ve checked if any air in but theys no bubbles coming out when check
ive put new pads on as well and theys a good amount of clearance between pad and disc (I’ve pushed the pistons in as well) so I would understand why they would be more push but what I’m trying to wonder is they a way to make the lever more solid or a way to make the pads and disc closer together thank you
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You still have air in the system somewhere.
Bikes: lots
Liked 2,932 Times
You're doing it wrong. If you have a soft lever it's because you have air in the system.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Play with the free stroke and/or reach adjust?
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
It's almost certainly trapped air or maybe contamination. Tapping the lever and caliper with something hard while bleeding, in addition to changing the angle of the bike around, might do it.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikes: lots
Liked 2,932 Times
If you are totally sure there is no air in the system (my fav method is to remove pads, insert bleed block and feel for any spongyness while pulling the lever) and you are not happy with the throw of the lever you can try to over bleed the system.
Add about 15-20ml of brake fluid to syringe, attach to bleed port at the caliper and open system. Compress syringe until you feel some resistance then close bled port. Pull brake lever to see if you are happy with the throw and check if pads are not rubbing. Repeat if necessary.
Likes For MUDCOWS:
Bikes: lots
Liked 2,932 Times
Quoted: 6178 Post(s)
Liked 4,795 Times
Take the wheel out and find something hard that you can slide up between the pads that fills the space between them completely. Squeeze the levers. Then you'll know better whether your issue is spongy feeling from trapped air or maybe something like the brake lever position adjustment.
Not that it should really have an effect on spongy brakes but have you measured your brake pads or rotor to see if they are within the limits specified by the mfr?
If you are losing any hydraulic fluid what so ever, then you will be getting air in them no matter how many times you bleed them.
