Is This Thing Adjustable?
Old 03-10-23, 02:18 PM
sjanzeir
BF's Resident Dumbass
sjanzeir's Avatar
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times in 496 Posts
This is the front suspension mechanism of my newly acquired Dahon Jetstream:
And this is the front suspension mechanism of my newly acquired Dahon Jetstream upside down:
And this is the big-ass nut in the middle that looks like it might be a tension and/or rebound adjuster of some sort:
Now, when I tried to negotiate this thing with a wrench, I found that it was locked as far as it would go clockwise. I was able to easily turn it a few turns out (counterclockwise,) but I was afraid that if I turned it too far, the whole thing would come apart, so I turned it back in to its clockwise locked position. With the bike on the floor, I'm able to compress the suspension about a quarter of the way through its travel with my full body weight on the handlebars.
So, what am I supposed to do with this thing? Is it actually adjustable, the same way the rear shock is adjustable?
sjanzeir is offline
Old 03-12-23, 11:00 AM
cat0020
Ride more, eat less
cat0020's Avatar
Quoted: 713 Post(s)
Liked 733 Times in 450 Posts
If the suspension piston is within the headtube, there might be adjustment available from above the folding stem.
Fold the stem and check if there is any kind of adjustment from above, likely via a long allen key.
cat0020 is offline
Old 03-12-23, 11:30 AM
john m flores
Rider. Wanderer. Creator.
john m flores's Avatar
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 389 Post(s)
Liked 766 Times in 372 Posts
That big nut looks like it secures the suspension fork to the head tube, not an adjuster.
john m flores is offline
Old 03-12-23, 03:54 PM
sjanzeir
sjanzeir's Avatar
Quoted: 792 Post(s)
I folded the handlepost down and, as expected, there's the standard Dahon headset tension bolt:
I shone a torch down the 10mm hex hole and thought I saw something beneath that, so I undid the bolt and took a closer look. What I found is a pressed-in stopper with a hole in the middle:
The light-colored ring is the pressed-in stopper; a little farther down the hole in the center is what's apparently a piece of elastomer.
I dropped a couple of long allen wrenches of different sizes in there to see if they'd grab onto something abd they didn't, but they did bounce off of a piece of elastomer of some sort, so now at least we know what's doing the cushioning work. Now I'm thinking that maybe the big nut at the bottom is just there to keep the elastomer spring contained, and maybe it can be swapped with harder or softer compounds as desired. I don't know.
sjanzeir is offline
Old 03-12-23, 06:51 PM
CrimsonEclipse
Quoted: 540 Post(s)
Liked 621 Times in 364 Posts
The plastic block on your tension bolt looks cracked
CrimsonEclipse is offline
Old 03-13-23, 04:38 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 237 Times in 173 Posts
The jetstream ex had a outer shock that is serviceable. Unfortunately, the jetstream p8 has sealed cartridge in the stear tube. I had one broken (sagging shock) back in 2008 and I needed a new fork unit. These days, there are not easy to find. I saw some copies on aliexpress and I know of a shop who had a stock of hammerhead fork which they sold to customers to scavenge and adapt to their broken jetstream fork.
The P8 OE rear shock is sealed. There was a crane creek upgrade that was serviceable. If yours has the OE rear shock, you can swap it for a A5 shock with valve to adjust the pressure. They are on ebay.
As I rode it with the kids
Rebuilt for sale last year
Fentuz is offline
Likes For Fentuz:
Old 03-13-23, 06:18 PM
sjanzeir
sjanzeir's Avatar
Quoted: 792 Post(s)
I saw that as soon as I took delivery of the bike, but it still functions as it should, so I'm not too worried because I'm likely going to swap out the the OEM handlepost for a better engineered "Chinese" one (right) that does away with the little plastic thingy and is more reliable for it anyway:
sjanzeir is offline
Likes For sjanzeir:
Old 03-13-23, 06:24 PM
sjanzeir
sjanzeir's Avatar
Quoted: 792 Post(s)
This is the one that came on the bike; is it the same one you're talking about?
I pumped it up to 100psi before I took the bike on its first shakedown ride around the neighborhood and it was rock hard with zero compliance. I've since dropped it down to 50psi and could gain back some give on my man-cave floor, but I haven't ridden it again as of yet.
sjanzeir is offline
Old 03-14-23, 04:47 AM
Fentuz
Quoted: 264 Post(s)
The 2nd generation of jetstream frame uses a std 150mm length rear shock. these are adjustable so you can setup the sag and with the knob, you can control it.
Fentuz is offline
Old 03-14-23, 08:35 PM
sjanzeir
sjanzeir's Avatar
Quoted: 792 Post(s)
Yup. This is a 150mm air shock with rebound adjust. I'm still a long way from trying it out on some terrain, but 50psi seemed to work well the second time out on neighborhood streets. It's certainly more compliant than the fork!
sjanzeir is offline
