Shimano di2 battery drain
Hello,
I have a nasty problem with my Shimano Ultra DI2 system.
Thanks in advance for your help/feedback.
GROUP : ULTEGRA DI2 - 2018
SYMPTOMS:
DI2 group was perfectly working for almost 4 years (25.000 Km).
Few months ago the battery started to discharge EVEN when not using the bike at a pace of approximatively 5 to 10% per day.
I bought a brand-new battery, and the system is still discharging in about 10 days.
I checked the firmware version of all components with the e-tube application and made sure the latest firmware versions were installed on all components. Same problem …
Then I started to disconnect each component, one after the other as follows:
- All components connected except rear derailleur -> battery still draining
- All components connected except the front derailleur ->battery still draining
- All components connected except left shifter -> battery still draining
- All components connected except right shifter -> NO DRAIN
I then checked the cable between the 2 shifters and also used different cable slots (3 per shifter) on the shifters and the battery still drains if I connect the right shifter. The right shifter is connect via 1 cable to the left shifter and the left shifter is connected to the junction box.
What could cause the problem?
I use 1 junction box located in the frame close to the bottom bracket. Could this ione be the problem?
I do not want to buy a new right shifter if the problem is due to another cause.
I also gave my bike to a bike shop and they could not find the problem …
Many thanks in advance for your help.
SYMPTOMS:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Based on your troubleshooting, it is likely you’ve found the culprit
You mentioned taking it to shop, did they use the diagnostic tool (not the charging brick that comes with the bike that also allows connection a PC, but the PC link that permits higher level diagnostics)? Regardless, it sounds like there is a short in one of the components that is causing a continual draw on the battery, which based on your troubleshooting seems to be the right shifter.
Maybe TerryDi2C who maintains a very helpful website called Better Shifting has some ideas.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
With the expense and non-availability of parts, I'd first use a SM-PCE02 to re-flash the latest firmware into that shifter.
The regular charger can't perform that function.
Post where you are, who knows you might find a local friendly SM-PCE02 owner.
Personally, I like Hazy IPA
BTW the SM-PCE02 does not plug into the charging port. It is attached via an E-Tube wire.
So if you're able to watch in a store, you can tell if they use one.
Barry
Barry
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
Barry
Barry
You can also do this using the charger (SM-BCR2) and E-Tube Project 4.0.4.
Note that you cannot always recover 'corrupted' units using the BCR2, but ETP 4.0.4 lets you rewrite firmware to it .
Likes For TerryDi2C:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
Oooops,
There I stood……… Corrected (again)
Barry
Barry
Likes For Barry2:
Quoted: 532 Post(s)
Liked 621 Times
Likes For Badger6:
Quoted: 3238 Post(s)
Liked 2,085 Times
And FWIW, I too have seen the battery discharge while not in use. My Ultegra Di2 system went from about 50% 6 weeks ago, to 25% yesterday. The bike was not used during that period,.
Likes For Steve B.:
Hello,
Thanks a lot for all the comments and advices I received.
After a final check of the firmware version of the right Shifter, I decided to buy a new Di2 7050 right shifter (130 Euros),
I installed it 6 days ago with the existing cables and ... battery full 100%. Problem fixed.
I am surprised by the fact that a Shimano DI2 Ultegra shifter can fail after 4 years of usage? It was operating 100% ok but was also draining the battery !???
Likes For veym:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1946 Post(s)
Liked 1,468 Times
Quoted: 532 Post(s)
Liked 621 Times
Considering the small size of the internal parts, I cannot imagine they are indestructible, especially the individual components of the switches. The right side gets used far more (in my case almost exclusively with semi-synchro), and if you ride in anything but sunny skies, it potentially is being exposed to things that electricity doesn’t like (moisture). It happens, I’ve had parts fail…Di2 and mechanical. It’s a small price to pay for riding a bike, and still far less expensive than driving a car, have you seen the rapid costs on those when parts fail that we think aren’t supposed to fail?
Likes For Badger6:
Sorry for bringing up this thread again.
I am discovering nearly the same issue as the veym . My group is also from 2018 and nearly the same km on the clock. The battery was suddenly starting to drain about 5-10% per day. Beside this no functional issues.
I found this thread during my research. Different to the thread starter I went directly to my LBS and thankfully they spent some time for free with my bike and found the right shifter as the possible problem. First they did a system check with the newest etube project program. A failure on the battery popped-up. After a call with the shimano support the mechanic installed an older version of the etube project and checked each component seperatly. All components were fine except the right shifter. Couldn´t believe that this "simple" component should be able to drain the battery.
To double check, I'm retesting it as the thread starter did. Fully charged and disconnected right shifter. Hopefully tomorrow afternoon with still 100%.
Short update:
Since Saturday noon, a new shifter is installed. Battery fully charged. Since then, about 8 hours of driving time with a lot of shifting. Battery still at 100% according to the Garmin. Problem was the shifter and is fixed now.
Short update:
