Can one stop a chain on a geared road bike from giving a bit when you first push?
Quoted: 71 Post(s)
Liked 18 Times
Hi all
My previous bike was an 80s/early 90s, butted and lugged, steel framed, single speed one - a fixie when I bought it, it had a (from memory 16 tooth) freewheeling hub on the other side of the wheel, so I flipped it because I enjoyed having the option to coast - and because of the simplicity of the chainset I was able to take away any give in the chain - so when I applied pressure, the chain would instantly respond.
On my new bike , a geared bike (Giant Contend 2, with most of the crucial parts upgraded from Shimano Claris to Tiagra or Ultegra), the chain seems to hang a bit lose, so when I apply pressure it jars and knocks taunt a bit because of the slack in the system before catching. It makes a bit of a 'thonk' sound and I feel like I'm kicking a very yielding brick wall. This is hard to understand because the chain doesn't actually seem to hang lose - it's visibly taunt - it's just that, I guess, the system of springs and levers is inherently a bit slack?
I don't like this, it seems like it must be a bit rough on my rear derailleur's hook, if not the whole system - including the chain, the chainring...
But I'm wondering - is it something that can actually be fixed on a gear'd bike? I know that the chain could be in perfect sync with the chainring on my single speed bike because there was not spring'y rear derailleur for it to feed through...
Is there a way I can make it so my pedals respond instantly to my applying pressure, instead of the aforementioned thonk'ing catchup of slack?
I've other mysteries about this bike I'd love to solve here, I'll see how this one goes ^_^ I live in Japan, for future reference, and I can't quite get the answers I'm looking for from my bike guy all the time.
Quoted: 20808 Post(s)
Liked 9,450 Times
You're probably taking about slack before the teeth in the hub engage. If so, get a DT Swiss hub with 54t ratchet upgrade.
Likes For WhyFi:
Quoted: 71 Post(s)
Liked 18 Times
What i'm getting feels very much like my old bike did when the chain was hanging down a bit, and it just had to pick up that slack in the chain before it ran well. On the single speed'er it was fixed by tightening the chain, so that's kinda what I was looking for - whether or not a 'tightening' thing would work on a geared bike.
As for your suggested hub, that looks really cool - I'm watching a video about it - is that the only way road bike riders would solve this problem in the past?
Quoted: 1079 Post(s)
Liked 1,019 Times
WhyFi has probably nailed it, you're dealing with the time it takes for the pawls to engage the splines in the freehub mechanism. Instant engagement with 72 engagement points was the big selling point for Chris King. Even their new r45 has, per the name, 45 engagement points which usually prevents that hard hit engagement feel. I9 has a high number as well. Also doesn't mean you have cheap hubs either, I've had that same issue with Dura Ace and XTR hubs, even my new XT have it, not really a big deal.
Likes For Dean V:
Quoted: 71 Post(s)
Liked 18 Times
Quoted: 1067 Post(s)
Liked 259 Times
If the freewheel is dragging it will overcome the tension in the chain from the rear derailleur.
This would make the chain droop on the top when coasting and create a slack feeling to the drive on engagement.
Likes For Dean V:
Quoted: 71 Post(s)
Liked 18 Times
Hi guys
I actually gave talking to my bike shop guy another try, and it turns out my rear chain rings being Claris and my front chainring being Tiagra (8 speed vs 10 speed) is the reason
Liked 9,450 Times
Yeah, agree with you and others that there's the possibility that his hub isn't freewheelin' quite so freely and it's throwing a bit of chain forward, though hub engagement could still be contributing.
Likes For WhyFi:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Nope, that's not the reason. And when you tightened the chain on your old single speed that much you actually made it slower by creating more drag.
Quoted: 6178 Post(s)
Liked 4,795 Times
If not any of the other things, your chain might just be too long and the DR is near it's ability to take up any more slack. Also, there might be something that is making your freehub not be so free. Did you decide to not trust the mfr and use your own lube, or perhaps it's just really cold where you are currently and that's caused the freewheel innards to be a little slow and drag?
Quoted: 71 Post(s)
Liked 18 Times
It is a bit cold here good idea, I know it made my wheels feel underinflated until I rode them for a few km and the air inside them heated up...
I'm coming to the conclusion that I can't really fix this particular problem in the same way I fixed it on the freewheeler, because the rear derailleur is seemingly built to flex, so there'll always be some flex in it... that's only a hunch though
Did yuor single speed use 1/8" chain. Stiffer laterally than 3/32". Old inch pitch had a different feel too, and many track guys hung onto that for awhile because of its stiffer quality.
Bikes: lots
Liked 2,932 Times
Hey mate, well you give me more thought. I vastly preferred my freewheeler when it was in sync with the chainring, instant feedback takes a lot of stress off components and my joints, I felt.. I enjoyed it I didn't tighten the chain much, just made it so that it didn't sag when i put power into the pedals - you know? anyway it was done in australia at the suggestion of a pretty savvy bike shop owner in melbourne so I tend to reckon he had the right idea~
Hey mate, I must not have been clear enough in my OP but I'm no longer on a freewheeler bike, I've switched to a gear'd bike and that's the one I'm trying to tighten up.
I've worked for the US National track team and UCI trade teams at World Cups so I'm fairly savvy myself.
Quoted: 645 Post(s)
Liked 797 Times
Liked 4,795 Times
Are you wanting to meet by the flagpole after school? <grin>
Are you skipping a tooth on a worn cassette? When you put your foot on the pedal all the slack is taken out.
