Calories and cycling
#376
Quoted: 1186 Post(s)
Liked 289 Times
i’m curious is anyone has seen studies on the “efficiency” of one cyclist to another. is a well trained cyclist much more efficient - less calories per watt? all the references to the figure I’ve seen are pretty absolute, and it surprises me that it wouldn’t be highly variable.
#377
Quoted: 2333 Post(s)
Liked 2,097 Times
[QUOTE=david101;22179326]
Thanks for writing something in a less confrontational manner. So in the same vein....
Believe it or not, I didn't come into this thread for a fight. All my other interactions on this forum have been very civilised and pleasant. This experience came as a bit of a shock
What fight?
Being told you are wrong is not a fight.
When you put yourself into a hole, just stop digging.
I apologized for hurting your feelings and even offered that your shock could be due to generational differences. Next time, instead of snapping off with, "did you read my post"; perhaps, re-read your own especially when it goes against what others wrote, aside from some basic physics. Then, just let it go or write, "Oops, I wrote that poorly or that is not what I mean". Reaching for the shovel and doubling, tripling down usually doesn't work.
Likes For GhostRider62:
#378
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Yes, I think the 25% efficiency figure is used because it makes the math easier, not because it really reflects what's going on. It's actually quite a bit above average.
If I recall correctly, the only way to accurately measure calories burned involves capturing all of the exhaled breath of the subject during the activity. That could be done during a stationary bike ride, but not realistically under real road conditions.
I'm also suspicious of using average speed because I think you'd have to do some pretty tough calculating based on the actual speeds during the ride. Someone with better math skills than I would probably need to weigh in on it, but the cubing of air resistance means that the farther above mean the speed is, the greater the divergence from the mean energy requirement, correct? So, if the average speed is 17 mph, the higher speed values will have a bigger difference from calorie burn at mean speed than speeds below the mean. Thus the total calorie burn per minute curve should skew somewhat to the right of the speed curve (or something, my stats are several decades out of practice).
#379
Liked 289 Times
Likes For gregf83:
#380
Tragically Ignorant
Liked 9,098 Times
Turns out my memory wasn't correct, Differences in efficiency between trained and recreational cyclists found experienced cyclists were more efficient.
More importantly, though, those averages are significantly less than 25%, Only one guy even got close to that number.
What's the source?
#381
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Recently on the lines of the speeds and power and such above.........I finally hit a silly goal I'd had for years. 20mph on a ride that gets 100ft per mile elevation, for an hour. The speed was on, I was short by a couple feet elevation. It "only" took me about 235w. The key was to have the skills to take corners at pace and constantly meter out the power evenly. No freewheeling unless totally unavoidable. Could have gone faster but lots of neighborhood curves and such. Meter might read low also, no idea. Seems low for curvy stuff and 1940ft in 20mi at 20mph.
Likes For burnthesheep:
#382
Tragically Ignorant
Liked 9,098 Times
That's a good day! Mazel tov, silly goals are fun.
Likes For livedarklions:
#383
Liked 289 Times
The source is in my earlier post, just click on the name of the paper. The figures in the paper are for Gross Efficiency (GE) and are useful for comparing trained and untrained athletes. Using gross efficiencies will give you the total calories burned during an activity which will include calories from your Base Metabolic Rate (BMR). To determine the 'extra' calories associated only with exercise and not include BMR they normally would use a 'delta' efficiency number which is a little higher than GE. I think 25% is probably close enough given the variability seen between individuals.
Likes For gregf83:
#384
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
Don't know if this video has already been posted, but it really makes things pretty easy to understand. Calories in, calories out.
#387
Quoted: 526 Post(s)
Liked 462 Times
https://www.youtube.com/watch?v=Fne9-LW0ivc
Likes For RH Clark:
#388
Quoted: 229 Post(s)
Liked 119 Times
I would agree to a large extent on the importance of calories, however just like everything else in life it isn't just black and white.
https://www.youtube.com/watch?v=yuds0Y-FPcI
#389
Quoted: 1027 Post(s)
Liked 325 Times
I didn't watch the entire 30 minutes, but nothing in the first 10 minutes refutes the idea that to lose weight your caloric intake must be less than your caloric expenditure. Can anyone cite examples of diets that recommend eating MORE calories and expended? Yes, what you eat matters...but weight loss is still about calorie reduction.
Likes For OBoile:
#390
Quoted: 1273 Post(s)
Liked 1,384 Times
235w suggests you're very aero and are turning all the energy used getting up the hill into productive motion going down rather than braking! i know that it would take me WAY more power than that to achieve the same result.... but of course i'd burn more calories lol.
