Rotate disc brake pads?
Bikes: Spot ACME with Shimano Alfine 11 & Gates Carbon Drive
Quoted: 39 Post(s)
Liked 78 Times
I don't know if this is a dumb question or not but if it is, it wouldn't be my first.
I noticed the last time I checked my disc brake pads for wear that either the front of the rear ones had worn down faster (I don't remember which). Would it be a bad idea to swap the front pads for the rear ones in order to get more life out of the pads?
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I always put the front ones in the rear and replace the front ones (unless both sets require simultaneous replacement).
This does two things:
1. It gives the best, most optimal braking in the front, where it is needed most.
2. It allows me to over-fill the rear hydraulic system a tiny little bit, to keep the bite sharp, without having the annoyance of pads rubbing when I put new ones in.
Likes For Polaris OBark:
Quoted: 6193 Post(s)
Liked 4,809 Times
No benefit for me. And assuming that no two discs are perfectly the same and will have little peaks and valleys on them you'll never see without a microscope then you might actually increase the wear on the pads until they wear into the new surface profile given to them.
It's not like you have to replace the front and rear pads at the same time. So you won't really save anything. Unless you are swapping your faster wearing pads with another persons slower wearing pads. <grin>
Likes For Iride01:
Quoted: 5781 Post(s)
Liked 2,578 Times
I wouldn't swap. There's nothing to be gained. Each pair of pads has a certain life. Moving them around can't change that. All rotating would change is the timing of replacements to both at once vs. one at a time as needed.
In fact, rotating will be worse than not doing so, since it's added labor and fluid (if hydraulic) for no gain.
Also consider that you're not likely to perfectly match the wear, so when you replace one because you must, you'll also be replacing the other sooner than you would otherwise.
Likes For FBinNY:
Car and motorcycle practice is to absolutely never do this. In these cases, taper often wears into the pads and so placing partially worn pads into a different caliper under possibly different load conditions, may cause below par braking until the pads wear down. I also see no advantage. Just leave them where they are until they are worn out.
Likes For redshift1:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Swapping the pads will actually ACCELERATE the wear rates...any differences in Rotor contour or Caliper Alignment will cause different contours of the Pads... once swapped, the high spots will quickly wear until the pads assume the profile of the rotor they now reside upon. General rule of thumb is to MEASURE the remaining pad thickness... any pad pair with one or more at 1mm remaining is overdue to replace.... Just below 1.5mm remaining pad friction material is the best time.... the friction material tends to begin chipping and sluffing off below 1mm, and remember those differences i mentioned? the low spots on the pads can wear thru and gouge the snot out of your discs too.
bottom line...if they look oily, thin, grooved, uneven in thickness, or Glazed, time to change Pads.
there are Resin and Metallic pads,, metallic last longer, but can be noisy and might squeal if not perfected... Resin pads offer superior braking, are much quieter, but wear much more quickly.... Warning: some DISCS won't like Resin Pads and WILL WEAR Rapidly when Resin pads are fitted.
Tip: Semi-Metallic Pads offer Good braking and longer wear than Resin pads.. ;-)
Likes For maddog34:
Quoted: 39 Post(s)
Liked 78 Times
Thanks you all for your input!
When I do decide to replace the pads, will I have to mess with the brake fluid too or just swap the new ones for the old ones?
Quoted: 4204 Post(s)
Liked 3,862 Times
As long as the brake works well with the new pads (doesn't rub, applies sufficient stopping "power") why would one deal with fluid? Now if there's other issues that are fluid related (leaks, air in lines, too much lever pull) than these need to be dealt with independent of whether the pads are worn or not. Andy
AndrewRStewart
AndrewRStewart
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,218 Times
While I agree that rotating pads isn’t necessary, I would disagree with this whole “pads have to match the rotors” argument. The pads and the rotors are wear items and will wear to match each other. Rotors don’t need to be replaced if new pads are installed nor do are new pads needed when new rotors are installed. They will wear together relatively quickly.
Stuart Black
Stuart Black
Liked 4,218 Times
It’s easier if you have a piston press or at least a pad spreader. You can use other tools like a screwdriver or a chisel but those are more likely to damage the pads or pistons. It requires a bit of force to push the pistons back into the caliper.
Stuart Black
Stuart Black
Quoted: 39 Post(s)
Liked 78 Times
Liked 4,809 Times
A popsicle stick will work also to spread the pads. And many other things. But a brake tool for bicycle brake pads is ideal if you have to have that ideal tool.
Likes For Iride01:
Likes For fooferdoggie:
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
When it comes to safety stuff just replace it, if it is worn enough to consider moving it, it is probably ready to replace entirely. Brake pads are not a place I need to save money or want to save money, on a chain and cassette sure to a point not a big deal but pads, no. With brakes always get the best pads and rotors you can get and keep up with replacing them and keeping them clean (with isopropyl alcohol and clean non-oil cloth) and you will have great braking. You hopefully shouldn't really need to change your fluid that often and if just changing pads you should be pretty well set for that.
Likes For veganbikes:
Liked 3,862 Times
Pad spreading tool- I use a clean cone wrench with the pads still in place. Andy
AndrewRStewart
AndrewRStewart
Quoted: 680 Post(s)
Liked 948 Times
Likes For jsdavis:
Clark W. Griswold
Liked 3,993 Times
Quoted: 6963 Post(s)
Liked 10,963 Times
PS, for whoever needs to see this: whether you use a pad spreader, a cone wrench, or a tire lever, it's probably safest to spread the pads apart BEFORE you remove them...Then put in the new ones. Some brakes (Ultegra and D/A, for example) use ceramic pistons that are more easily damaged by metal tools. (I learned this from cxwrench , who has unfortunately been excommunicated from this subforum.)
Likes For Koyote:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
