Do front disc brake pads wear out faster than rear ones?
Bikes: Pedal Force ZX3
I was never a physics major but somewhere I heard that more pressure is put on the front brake on a bike than on the back. I just had to replace my front brake pads but the rear ones still had some life on them. Is it true that front brake pads get more wear that rear pads? These were resin Shimano pads.
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
It's true in many cases, but brake lever application is HIGHLY personal. Some prefer to use more front brake than rear. Some prefer to use more rear brake than front. This can also depend on the type of riding -- you can often use more rear brake to help steer the bike off road (or to keep from going over the bars in certain off road situations).
Likes For Elvo:
Likes For Juan Foote:
Really Old Senior Member
Normal.
Weight transfers to the front when braking. The more severe the stop, the less weight on the rear, which means you have to use less rear brake to prevent skidding.
Think how much rear pad you would need if all your stops were borderline front wheel stand.
I don't do discs, but I would expect to replace the fronts 3-5 times more often, since I pavement ride only and tend to use noticeably more front brake.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
Unless coasting with your rear brakes on down hills and whatnot rather than brake as works best, your front pads will get worn quickler.
I have always worn approximately 2 front pads for every rear one both on the mountain bike and the road bike.
Most braking power comes from the front wheel, so it makes sense.
Quoted: 2026 Post(s)
Liked 1,095 Times
The fronts should wear out well before the rears if you are using your brakes correctly. The only thing that might accelerate rear brake wear is if you ride in bad weather a fair amount. Then the front wheel kicks up water and grit that sprays the rear wheel and can act as an abrasive on the brake pads and rotor. It's why rim brake rear rims tend to fail before front rims.
Likes For HillRider:
I think it depends on your riding style. If you primarily ride on icy roads then your rear might wear out quicker. In the snow, it's 50/50 for me and dry hard pack then the front wears about 50% faster even when I apply brakes evenly.
Likes For aclinjury:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
If you use your front brake more, then yes. If you don't then probably not. Your front brake has most of the braking power. However some people get scared to use it and they sit relatively untouched when they should be used more often.
Quoted: 6939 Post(s)
Liked 10,944 Times
Answer is "yes."
It's true for cars, too. I tend to keep a vehicle until it is ready for the junkyard, and I have never had to put new rear brakes on one of them.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
As mentioned, depends on riding style. eg. to bleed speed off the bike to keep close distancing in a paceline, I use the rear. Over a 30-60 mile ride, that could be quite a lot of micro-braking events.
Right. I was more replying to the other fella's "2x front pad wear to 1x rear pad wear". On the road yes, less so on dirt. On dirt I find myself braking evenly front and rear, the more i'm behind the saddle the more rear bias the braking. In a straightline then more front bias braking. But hell all this depends on trail/dirt conditions too. Also, when I was running 180mm/160mm front/rear, the front pads wear slower compared to 160mm/160mm front/rear (but 180mm rotor made too much noise so downgraded to 160 rotor and noise disappeared).
Quoted: 356 Post(s)
Liked 323 Times
2) So it follows that if you brake at the rear the most, you will skid much sooner than you would flip over the front if using the front brake.
I'm reminded of certain motorcycle riders, cough - HD - cough, who "had to lay 'er down" and never using the front brake.
I think you heard that from just such a person.
Likes For CargoDane:
Bikes: lots
Liked 2,932 Times
When it's wet or I think the surface can be slippery, I also give more emphasis to the rear brake. Otherwise I mostly brake with the front brake using only a slight touch of the rear as I feel that makes the bike slightly more stable.
Quoted: 1188 Post(s)
Liked 1,154 Times
Sometimes I use my rear brake.
My partner wears her back brake pads out faster than I wear out my fronts.
Most of the time I apply both my brakes simultaneously. If I need to bleed my speed, I usually do it with the front brake. So I guess the usage is split approximately 55%/45% front/rear. However, the brake pad wear seems to be about equal or slightly faster on the rear. This especially true during winter. I reckon it has to do with the fact that the rear wheel picks up more road grime and debris, as it receives some spray from the front.
Quoted: 980 Post(s)
Liked 580 Times
That was "entry level" stuff when we were kids. Once you learn to move your center of mass around (rearward), the front brake becomes much more useful.
Likes For sweeks:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
I think it didn't help that the first bikes I learned to ride were made in the 50s and didn't have front brakes. You just got used to the way a bike handled with coaster brakes only.
The way I finally understood it was if you're running, which leg do you use to stop with?
Quoted: 206 Post(s)
Liked 38 Times
Originally Posted by MyRedTrek View Post
When I was a kid the mantra I remember hearing was you should always apply your rear brakes first and harder to avoid flipping over the front wheel.
My entire life has been a lie!!
Likes For MyRedTrek:
