Non-metal white gas fuel bottle
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
On my summer tour, I would prefer to carry my fuel bottle (white gas) on my bike instead of in a pannier (I have cages for four other bottles, so I won't be shorting myself water). Wondering whether anyone has found a non-metal fuel bottle that will fit in a bottle cage. I could carry a metal MSR bottle in a cage, but I would prefer not to, as try as I might, there is no way to completely get away from the rattling and jangling. Also, I use a white gas stove (and a wood stove, and also an alcohol stove, both of which I like, but I'm not bringing them). I'm happy with it. I don't want/need to invest another stove, so please don't recommend I buy "Stove X instead."
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Quoted: 18411 Post(s)
Liked 15,531 Times
Putting on my lawyer hat: I doubt one exists because of the proximity of the flame to the bottle. Shattering is likely also a concern.
Have you tried a thick sock with a Velcro strap for extra security. I saw that setup on the road back in '00.
I put my MSR fuel bottle ( they are pressurized and that's another reason why plastic is a No.)
I put my MSR fuel bottle in the under the down tube bottle cage of Nylon ,plastic
and secured it further with a Toe strap around cage and bottle to have no rattling like you describe..
Quoted: 286 Post(s)
Liked 100 Times
My stove is a Svea, so the fuel bottle just carries fuel, it does not hook up to the stove. Something like a sock could work, but I was hoping to do this with a purpose built piece instead of with duct tape and bailing wire.
I use plastic bottles in metal water bottle cages and a metal bottles in a plastic cages
if you look at Nalgene laboratory bottles of heavy duty thick plastics , or the bottles made for the alcohol stoves , like Trangia,
They may have gone over to metal bottles by now , I dont own one .. .. so I don't know for a fact
their safety cap may be Sigg compatible to use the Swiss metal bottles..
they may not set you on fire, using them to refill the stove off, and cold..
replace one of your bottle cages with a gorilla cage. https://images-na.ssl-images-amazon....1Zcy2ZQwPL.jpg
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Unless you view glass as a viable alternative, you are out of luck. Wrap the metal bottle with old handlebar tape. If you have an MSR stove that goes with the bottle, you will have to carry the bottle anyway.
NB There are Nalgene bottles for volatile fluids...
https://www.fishersci.ca/shop/produc...tles/p-4522007
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times
Occam's Rotor
Liked 2,331 Times
profile bottle cages I use this one , prior version without the tip catch
I got a set of Super Straps decades ago bad as a pedal toe strap ,
but since it has a ratcheting buckle like a ski boot , they can get really tight around metal fuel bottle & nylon cage
Quoted: 3459 Post(s)
Liked 1,465 Times
White gas or coleman fuel, I always just make sure that the lid is tight and put inside my pannier, never had any problems. If you spill a bit on the bottle doing camp kitchen chores, it is such a volatile liquid that it evaporates in a few minutes. Kerosene however does not evaporate off of the bottle very easily so I put that in a cage, such as the photo below.
There are bottles that fit the cages quite well. Photo is 9 years old, so the specific bottle in the photo is not made anymore, but I would expect that others that fit are available.
One of my msr metal bottles fits very snugly in my regular old bottle cage, no rattles or anything, but depending on how loose yours is, there must be a quick easy wrapping fix with some sort of tape, or thin tough foam, that will eliminate rattling and stay in place properly.
I do sympathize because I very much dislike rattles and whatnot on my bike.
Bikes: 1988 Specialized Stumpjumper Monstercross Touring Rig, and a couple of others
Quoted: 46 Post(s)
a bit expensive, but sure, why not.
Really depends on the looseness and what thickness is needed.
Only the fellow who asked the question knows this and I guess if he is interested, he will have to improvise with stuff, and maybe go through Mk 1, Mk2 to finally get to Mk 3 that works for him.
seems to me there are very cheap foam cylindrical "outers" to put over beer cans in summer or that sort of thing, that could be either modified or cut up and attached together to fit either his bottle and or be a good fit for his cage.
If you're dead set against an aluminum bottle, get a Nalgene. I'd bet a Gatorade bottle would be fine also.
Bikes: 1973 Raleigh Competition, 2010 Rivendell A. Homer Hilsen, 2010's Bike Friday Pocket Companion
Quoted: 19 Post(s)
Svea's are dead simple to operate with no moving parts, self-pressurizing, and take but a little while to master. The 1-2-3 was my favourite for years until...
They do have a fatal, and dangerous flaw. That is the over-pressure relief valve on the filler cap basically points straight at the burner. On over-pressure the valve releases, sending hot fuel vapors straight into the active flame. What results is a runaway ball of fire that burns until the fuel runs out. The the tank explodes. How do I know? Thankfully this happened outside the tent, and in an area with no burnable materials. And that it didn't hit anyone in its 15-foot flight away from its point of origin.
Still elegantly simple.
(I've since had a couple of MSRs that are much more fiddly to operate. I now prefer the little butane/propane units although there is the waste of the spent fuel bottles and poor performance in cold weather.)
Cheers!
aka Timi
Every August my bud & I use a "modern" canister burner out West. It's usually around freezing or a bit below in the mornings so a bit of a PIA to get the oatmeal going, but we make it work.
Palmer
Quoted: 1666 Post(s)
Liked 1,818 Times
Perhaps an Arundel Sport (polymer) or Looney Bin (adjustable, clamping) bottle cage? Then there's the DOM Monkii cage that holds the bottle in with a big, cinching velcro strap, and the Topeak Modula EX that ratchets in to hold the bottle tight.
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,989 Times
I use the PDW Bird or Owl cages and no rattles on my MSR fuel bottle, if I need to I can push the wings in for a tighter fit on something say like a King Cage or MSW or Jim Blackburn style you can push in the top part a bit or I would wrap with some bar tape or electrical tape.
A simple strip of electrical or duct tape around the cage tube? Or a couple wraps around the bottle about a half inch from both the top and bottom, to create contact points on the bottle that aren't metal? Maybe it would be a good way to store some "emergency" tape on your tour.
Been meaning to mention this for a while, to respond specifically about using a nalgene or similar--i just really wanted to stress how it's never ever a good idea to use a visual normal drinking container for dangerous, water looking fluids.
I strongly believe this is something to avoid, as the consequences of a mix-up are pretty serious, especially down the road with a moment of inattention and especially with children or someone else.
there, my public service slash dad instincts have been expressed
