Kreitler Rollers
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 164 Post(s)
Liked 92 Times
Kreitler Rollers
Thought I would share a photo of my Kreitler Rollers/Killer Headwind/Magnet Bar implementation. Additionally, the chassis is a freemotion rollers project. Happy to answer any questions about the rare earth magnets, freemontion chassis or Killer Headwind.
Likes For gkamieneski:
Quoted: 35 Post(s)
Liked 11 Times
do you get any movement out of the two frames , must be pretty sticky with the two mating wood surfaces
can't really figure out the reason for that , unless you get some motion with it
Quoted: 164 Post(s)
Liked 92 Times
would seem that the bike would fall off the rollers before the bottom 2 frames were to move.
Quoted: 164 Post(s)
Liked 92 Times
Unlike most of the plans found on the internet, where the actual rollers are modified (drilled and wheels added), my implementation theoretically allows the use of different sets of rollers an leaves the Kreitlers unscathed. The downside as I see it is that the completed unit probably ends up an addition 1 or 2 inches off the floor.
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
are those horizontal wheels on the front roller to keep you from falling off?
funny you have it next to a workbench. that is where i had mine because, i fell off on more than one occasion. i don't roll anymore but sometimes i wish i still had them.
Quoted: 164 Post(s)
Liked 92 Times
Best feature is the Neodymium Magnet Bar.
Quoted: 472 Post(s)
Liked 1,028 Times
OP, thanks for the photo. I have my Kreitler rollers set up in my workshop. I built a barn like sliding door between the shop and the machine room. I set up next to the door jam and that sliding door, locked so it will not slide when I'm rollin. An opening just a bit more than shoulder width. I'm proficient enough to not ride off the rollers but I do still tap those edge points with a shoulder on occasion which signals me to center up. I still need the two correction points.
A friend recently asked if I wanted some old speakers he had. "Sure, why not." I immediately tore them apart to salvage the magnets. Turns out each had some sort of tweeter in the top with a pair of rectangular permanent magnets. Salvaged 6 of them and stuck them to a length of angle iron. Clamped that to the Kreitler frame with the magnets spaced 2mm (one thickness of cereal box) away from the roller. It works just fine, good added resistance. Too much, actually, so that assembly is on the shelf. Don't need it yet.
My shop is unheated which gets me some pretty cool ambient this time of year. No fan required.
Quoted: 164 Post(s)
Liked 92 Times
First magnets I used I salvaged from discarded computer hard drives (there are typically 4 in each drive). Then I found the round 1in versions to be fairly inexpensive at Amazon and they are sold in groups of 10. I fit 8 I think on the angle iron attached to the frame ahead of the back roller. I cut oblong slots in the angle iron where it attaches to the rollers frame, so it can be moved to adjust the resistance.
Quoted: 164 Post(s)
Liked 92 Times
Managed to disassemble the Killer Headwind. There are two(2) 1614ZZ sealed bearing cartridges. They were marked 1614Z but actually are the 1614ZZ as both sides are sealed. I am not sure if these will silence the squeaks and noise the fan makes as these units are notorious for wobbling around their axis, but for $6.50 I thought it worth a shot.
