tires that are good 700x28-32
What tires are out there that are on par with Continental 4 Seasons. I'm not sure if I can ride bigger than 30s on my tektro road calipers.
Quoted: 4197 Post(s)
Liked 3,849 Times
I would expect every major tire brand has it's equivalent to the Conti 4 Seasons. You might want to find out how wide/tall a tire fits before spending $, and don't assume the tire's labeled size is the on your rim measured size. This is why I generally suggest a visit to the LBS and ask if you can test fit a tire before you pay for it. Andy
AndrewRStewart
AndrewRStewart
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
If you like the Conti 4 seasons, they do come in both 28 and 32.
In my experience, Conti 28’s on vintage type narrow-ish rims mount up at 28mm; on later/wider rims they’ll bump up closer to 30mm.
Vittoria Control Graphenes in size 30 mount up at 28mm on Mavic Open Elite rims, more like 30mm on a slightly wider rim like a TB-14
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
The list is long. As @ Andrew R Stewart suggests, find out for sure what spacing you have for clearance, vertical and lateral. You will still need to learn what size for what tires will clear, and leave a bit of room for safety and non-marring of those areas. Also, finding a tire that mounts without too much difficulty is a definite plus. Personally, I like Hutchinson Fusion 5 performance or all season. Also, Vittoria Rubino Pro IV. One of my favorites for road are Vittoria Open Pave, but I see them only in 25 and 27mm.
If you already have a tire that you really like, why change just because of wanting wider, unless they do not come in wider widths. If you are looking for something lower in cost, but still good quality, the Rubino IV should work nicely.
Quoted: 2337 Post(s)
Liked 2,818 Times
I have had recent good luck with panaracer gravel kings in 28 and conti gp5000 in 28 (and vitorria corsa control tubies in 30mm) I have found good results with the conti race lite tubes.
