Winter cycling clothes
We see a lot of ads for winter cycling clothes and we may have seen videos and photos of pros/amateurs out riding in the winter but I wonder if that gear (some expensive stuff from Castelli and other high end brands) is really good enough for the deep winters we see here in Canada and the northern US states.
Any opinions from anyone who has or knows of someone who has some of these types of winter cycling clothes?
Quoted: 507 Post(s)
Liked 237 Times
My record for commuting was 8F. Thin short sleeve poly shirt, thin long sleeve poly shirt, 200-weight fleece, 200-weight softshell jacket, nothing cycling specific. Long base layer + 200-weight softshell pants. I got somewhat sweaty and hot while moving but this was for ~30min commutes. Hands and feet are the hardest to keep warm, I had to wear thick primaloft-filled skiing gloves (warmest I have) and 2 pairs of socks so I could do better on that front.
It's easy to layer to stay warm when you're moving, the bigger question is how comfortable is the clothing to cycle in?
Quoted: 2432 Post(s)
Liked 638 Times
I haven't lived in the north, but I do ride motorcycles in freezing weather at high speed and the best thing I have is a heated vest. Keeping your core body temp warm, so the blood pumping out of your heart and going to your limbs is warm, is the key. If I lived up north and rode in the single digits I would wear a battery powered vest with an adjustable thermo. If you get too hot just turn it off.
On the other hand, it is rare to see an amateur/pro road cyclist (live, photo or video) riding on snow- and ice-packed roads so it might be that high end cycling-specific winter gear (again, Castelli and the like) are designed for winters where the overnight temp might drop to -5C/23F and sunny, daytime temps go up to 5C/41F and any overnight snowfall has melted from the roads in the sun by noon.
I'm interested in hearing whether anyone here owns some of these higher end winter cycling-specific gear and at what temperatures are they comfortable riding in them.
Quoted: 507 Post(s)
Liked 237 Times
To stay warm you only need 3 layers: base, insulation, wind-proofing (no cotton anywhere!)
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 408 Times
There's no magic formula, but there is a basic one--base layer for wicking sweat away from the skin, a mid layer for insulation--the thickness of this layer is determined by the temperature, and an outer wind-breaking layer. More expensive pieces might have better cut, maybe better sweat-wicking quality, maybe softer on the skin, etc., but ultimately it comes down to those three layers.
As for hands and feet, I've been using chemical heat packs for anything colder than -5*C or so. Fingers, especially the thumb, are the most difficult to keep warm. The poor thumb is always separated from its siblings, and don't get the benefit of group heat, and unfortunately I need it separated to operate the brakes.
@autonomy and @mcours2006, this is great info, thanks.
It appears therefore, that there are no magic or high-tech (not available to other kit makers for the next 50 yrs) materials that the high end cycling clothing manufacturers have that others don't and I kind of suspected this but just wanted to hear from others. Yes, there may be some differences in quality of the kit such as manufacturing or fitting or a special combination of materials that cheaper brands might not go to the trouble of creating but in terms of basic materials, they aren't really any different. I suspect therefore that the photos of pro road riders in these high end kits may not be in deep winter temperatures that some of us have to (want to) ride in.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
However, my city generally experiences winter temps in the -10 to -20C (16 to -4F) range and I am wondering if these high end brands are capable of keeping a cyclist warm in these temps.
Quoted: 261 Post(s)
Liked 11 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I own the following garments.
Note that I live in North Georgia, USA but I did live on Long Island for the first 44 years of my life. I cycle throughout the winter down here and we do get some cold snaps where it stays in the teens for several days.
Castelli Sorpasso Wind bib tights - make sure you size up. Fleece inside and windproof through the legs and abdomen. The one oddity is lack of windproofing in the groin area which some complain about but I don't find too bothersome given the thickness of the fabric. This has been comfortable down to 22°f for 1.5 hours. I've not had opportunity to ride this garment at lower temps.
Castelli Nanoflex bib knickers - size way, way up. These are knickers and used regularly down to about 40°f. I would easily wear these at lower temps if they were full tights, they are very fleecy inside. High water resistance has come in handy on one occasion when I got caught out in a shower at about 45°f. I was able to find a dry spot during the rain but the road spray riding home after the rain let up was easily handled by the Nanoflex fabric.
Castelli Alpha Wind Jersey - now known as the Alpha ROS jersey. This is an amazing garment with a zippered insulating layer covered by a zippered Gore outer layer. The Jersey version has no insulation on the sleeves and the back is an air permeable fabric to allow heat and moisture to escape and so the effective range is higher than the jacket version. There is a 33 page thread about the Alpha Jersey and Jacket at BikeRadar with more info than you could ever want.
7Mesh Callighan Jersey and Kitsbow Geysers 2.0 Jersey - These are lumped together as they are both excellent, high-end, luxurious insulating mid-layers. The 7Mesh Callighan is long sleeve and roomier while the Kitsbow is short sleeve and the cut is a bit racier. The merino blend of both garments is excellent at insulating while moving moisture. These two garments allow me to extend the range of my other garments down into the high 20's f.
Also consider a windstop base layer such as the Craft Active Extreme WS long sleeve. A review is here. Yes, it is a base layer with Gore Windstop. I am susceptible to bronchitis and have to be particularly careful about cold air hitting my chest. This garment does the trick.
Hope this helps you Yankees and my good friends north of the border. Thankfully it doesn't stay cold for long here in the south. Most southerners Zwift when it gets below 45° so I'm a bit of an oddity here but having grown up on Long Island, weather which makes southerners complain that it is too cold or too windy seem mild to me.
-Tim-
-Tim-
Quoted: 5888 Post(s)
Liked 3,471 Times
When it gets cold, I don't use any bicycle specific gear except perhaps for a balaclava or some sort of headgear.
Quoted: 5224 Post(s)
Liked 3,581 Times
I see some guys with those thick winter cycling tights. I remember trying some on a few years ago & really wanting them but didn't get them, even tho I tried them on at a spring sale. they were one piece bib style & the XXL fit great, not too tight at all I eventually found other options that I use, but those thick winter bib-style cycling tights look like the real deal man
Roadkill
Like mentioned above, the three basic layers approach serves me down to 0F. I usually use a wicking base layer (C9, Target), fleece long sleeve jersey (LG, REI Garage), and a softshell jacket (Sugoi, REI Garage).
For my legs, I found the Performance Triflex tights to work great. As the temps drop, I wear leg warmers underneath. It helps that I got them on clearance.
Senior Guest
Bikes: Jamis Endura, Cannondale CAAD, Raleigh Cross, Fausto Coppi.
Quoted: 80 Post(s)
Liked 47 Times
I strongly recommend
Foxwear | Custom Sized Sports Clothing by Lou Binik | Salmon, ID | (877) 756-3699 .
Talk to Lou.
Best winter custom cycling clothes that is not very expensive.
Talk to Lou.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Don't forget to look at clothing made for other winter sports. 😉 I now have 2 pairs of ski/snowboard pants, one being Burton that has vents in the crotch and legs. I still haven't given them a hard test, on a bicycle, but so far, they're keeping me warm, but well ventilated. 🙂
Bikes: 2014 Bianchi Volpe and 15 Yr Old Schwinn Mountain Bike.
Quoted: 13 Post(s)
I live in the Willamette Valley of Oregon. Our winters are mild compared to other parts of the country. It does get down into the teens and twenties from time to time but the coldest I've ever seen after living here for almost 40 years, was 9 degrees. This year we have been in the 20's a few times. This morning it was 22 when I went out for a 27 mile bile ride. It as sunny and there was no wind. I wore long johns tops and bottoms under bike pants, long sleeve bike shirt, a sweater and and a windbreaker. Merlino socks and sock liners and shoes covered my feet. Claw bike mittens and thin gloves covered my hands. A bike hat and balaclava covered my head and face. I was quite comfortable. I love this weather for biking. By the time i arrived back home I was quite warm as the temperature went up to 36.
Bikes: Stromer ST-1; Gary Fisher SAAB edition; Dahon Speed D7; Motobecane Grand Touring 1972
Quoted: 38 Post(s)
Living in Denver, we sometimes get fairly cold. I've got peal izumi elite top and bottom (nominally rated for about 30df) which I received as gifts. With a couple of layers of thermals underneath (and sometimes a rain/snow layer above) I've ridden down to 15 df or so. Ski gloves rather than anything bike specific.
I own plenty of higher/mid end winter clothing from assos, castelli, Santini, gore, etc. and mid/lower end but quality stuff from PI, dhb, sugoi, showers pass.
There isn’t a huge difference between the quality lower stuff and higher end stuff in my opinion. The only minor difference is in the fit. The high end stuff basically just feels more sized down and as a racer I like the snug yet warm feeling it gives me. The cuffs and finishes also tend to be a little better designed e.g. flat tapered armholes that easily fit under gloves.
Water repellency I find is a gimmick. Just buy water repellent spray from REI meant for tents - Spray away!!!
living in n iowa we have had some serious cold so far. wind chills to -30. i have commuted 2.5 miles every day for almost 25 years. nokian tires, m and g, 160, on my 26 mtn. bk. for me it is a layering. merino wool, 2 layers when it is that cold, a patagonia r4 jacket, followed with a patagonia wind breaker over that. my head has a balaclava, wool stocking had, then the hood of the patagonia wind jacket, if it is windy.
warm mittens, merino wool long undies, and craft storm pants over that. they don't make the storm pants anymore, nice piece of gear that i have had for 15 years.
2 pair of wool socks, one thin, one thicker, and insulated boots. no clips in the winter.
i have stayed warm, and get to work with very little sweat. a good layering job.
when it warms up, of course i use patagonia pullover jackets, with less clothes.
rain is another story, even with pit zips, moisture stays in. i just deal with it.
love the winter commutes, bike trail most of the way that even gets plowed. although i see very few in the harsh conditions.
I don't spend high $$; what works form me:
Basic shoe covers and wool socks (DeFeet Wollie Boolies); I have a pair of fleece-lined tights (Louis Garneau). I use a wool base layer (Endura), my regular jersey, and a Louis Garneau "Course" rain/wind jacket (usually with thin arm warmers on underneath for layering). If below 35 degrees I use a Louis Garneau neck gaiter, which I can use to breath through in very cold weather. Good winter gloves (BioRacer) was my biggest splurge. And, of course, some sort of fleece cycling cap. Most of this I got from my LBS. I can mix/match layers for anything form 20F on up. Honestly, above 40 degrees I'll ditch the jacket and just us a layer of newspaper under the jersey to block the wind; which I can dispose of easily if it warms to 50
In the winter, I do a lot of longer endurance rides; over 4 hrs it's either going to be warming up, or it's going to be cooling down. Layer help - I often use a mid-weight winter glove, for which I can add or remove thin glove liners when needed. I also use a layer of newspaper under my jersey for wind protection - which is very easy to dispose of at a gas station when it warms up. I usually target dressing as cold as I can tolerate at the start, knowing that I'll warm up in about 15 minutes. Nothing, however, is more miserable than 4 hrs on a bike after getting the layering wrong!
Merino base layers. Long sleeve jersey and a shell jacket and shell pants. If I still feel my legs may be too cold, then nylon sports pants under my shell pants.
So the only thing that's bicyle specific is the long sleeve jersey.
Liked 3,581 Times
Super WW
Bikes: A really light one and a really heavy one.
Quoted: 70 Post(s)
Liked 43 Times
I have 2 castelli espresso 3 jackets. When temps go below 25 they're my go-to jackets - they also have zip vents in the front in case it gets too warm. I've used them down to 1.6 degrees (F) and they're worth every penny (although I got them on closeout- no way would I pay as much as they retail).
They are windproof - nothing gets in - add or remove base layers with the temps.
I don't use cycling specific gloves- they suck. My favorites for below 30 degrees are isotoner flex gloves - they're really warm, waterproof and have great insulation, but still allow a decent amount of dexterity with your fingers. I also have a pair of seirus mtn challenger gloves that are similar. You can find those on ebay and amazon between $10 and $30 a pair (size dependent). I use venture heat - heated glove liners when it gets really cold - they work and the batteries last a long time - I rarely use them on the highest setting, especially under the aforementioned gloves.
