Quebec tour (Gatineau-Quebec-Tadoussac-Saguenay-Quebec) in September - Seeking Recomm
Quoted: 1324 Post(s)
Liked 927 Times
[QUOTE=user2;22196202]
I use one Arno strap on each pannier wrapped horizontally around the pannier, the rack strut and the seatstay.
Cheers
Edit.
My friend did the same as I did but used bungee cords. On a test ride on a paved trail and riding downhill one of his rear panniers fell off the bike. When he switched to using the Arno straps he had no more problems. We toured in Northern Ontario and rode some pretty rough roads and never had a worry about a pannier coming off. Yet the Arno straps are quick to take off if you want to remove the pannier.
Cheers
Edit.
Last edited by Miele Man; 08-23-21 at 12:22 PM. Reason: Added comment about bugee cords
Likes For Miele Man:
good to know what you are using.
First of all, Arkel stuff is good quality all around, and the cam lock system is known for being robust and effective. I personally have been using Ortliebs since about 93 or 94, but know that the Arkel system is a great , proven system.
its pretty easy to fatten up the rail a bit, but the cam lock motion may abrade the tape a bit over time. Probably no harm in just trying out some electric tape , or cloth hockey stick tape (which is pretty tough, Ive used it on bike parts for eons, and it hardens over time which is nice)
and you can see how it works. Personally that little amount of play wouldnt bother many people, but I admit that I eliminated play with my Ortliebs before doing some long trips that I mentioned.
Mind you, I commute on a bike with older ortliebs and some play, and it doesnt bother me.
If you do try the tape it fatter route, its probably better to cover more length of rail than you think, in case your panniers shift forwards or backwards a bit.
re the bottom movement of the pannier coming away a bit from the bike. I guess its personal also, but that doesnt bother me too much, as long as the top stuff is not coming off--and lets face it, you'll be on paved roads the whole time, so I really dont see it as an issue---but, heck , throwing on a really solid and secure strap seems pretty darn easy.
You just really want to be sure that it doesnt end up in a wheel, thats all--but from all the stuff Ive read, and as the last guy said, its a pretty common trick to keep things stable.
for what its worth, the weather forecast seems to show that the killer heat we are having is going to lessen by friday, so hopefully you won't be starting out in these 31, 32, 33c days with humidity to match.
as you already said, I think it will be good to just have the mindset that you may have super hot and you may have pretty cool at nights also.
I'm sure this mixed bag will be the reality.
The Arkel system does seem really solid and nearly impossible to shake off the rack when the cams are engaged properly. The only downside in my view is the need for a bit of extra space for the cams to swing without hitting the vertical parts of the rack. When I first started using them there were a couple occasions where I had one end become unhooked because I wasn't paying attention to make sure the cams were fully engaged.
In the grand scheme of things I think the pannier rattling is the least of my concerns so I'll probably just leave it for now. It's only an issue when going over rough roads or the concrete transitions between cycle paths/roads/driveways. It's more of a mental thing that I don't like the sensation of the load wiggling around. I've actually got a couple cam-lock straps that I might bring with me.
Yup, it looks pretty good at the moment and should make things a bit easier for us starting out. Although I'm a little off-put by the current forecast for rain on day 1 (Saturday). I'm hoping we can enjoy our cleaned and lubed bikes for at least one day.
ya, I saw the rain thing and went...ooops. As you say about the clean and lubed bikes, thats what always bugs me about riding in rain, is that I like to keep my drivetrain clean, so it means more work afterwards. Ive been pretty lucky over the years touring with rain, but obviously we have to deal with it sometimes. After a day riding in rain, I always wipe the chain with a rag well, at least this gets a lot of the gook off, I do the jockey wheels and maybe floss the cassette with the cloth also, and a quick wipe off of the chainrings. Not too long to do, and then I relube the chain, depending on how long it had been since lubed, how much rain, etc
This is why I always have a rag with me, and on long trips, will grab a discarded shirt or whatever off the side of the road at some point when my rag starts to get pretty dirty. Keeping the frame and whatnot clean isnt a big deal, but Im one of those riders who makes an effort to keep the drivetrain clean, its a win win anyway to do it regularly, less work and faster, plus your drivetrain lasts a lot longer than if you ignore it, like many riders do.
A few more last minute thoughts, kinda late but hey...
On a set schedule trip, try to have some wiggle room for days off. I know you have the car rental set up, so similar to when you have a flight back and have to be there for that, but try not to have a plan that's too tight and absolutely requires riding 100km per day, every single day sort of thing.
re Saturday and rain. I have to admit, if I saw it will be steady rain all day....it would be hard to want to start.....but you're just going to have to make the call from the fairly accurate weather hourly reports we have access to now.
You probably have already planned out each days ride and destination (mostly or all camping right? ) but keep in mind that it's usually good to at least have some idea of an option B shorter day, or C longer day. Often not an option due to campground locations, but there you go.
on multi week trips, I've always wanted to take a day off about once a week. You can do every 5, 6 days, whatever feels right for both of you--and it's always good to be accommodating and flexible with each other with this sort of stuff and communicate well with each other.
The taking a break day is nice, and even when I was your age it was nice, and it hasn't changed now that I'm as old as your parents.
Schlepping a heavy touring bike will be more tiring the first week, so sometimes an earlier rest day in that first bit can be nice.
cheers again
cheers again
cheers again
cheers again
We won't actually spend 7 days in QC, I just kind of left those days as extra rest days.
We were thinking of deciding each day how far we go or when/where to take rest days based on how we're feeling. I marked out a bunch of campsites to make it easier to plan and I don't think there are any stretches longer than about 60km along our route without a half-decent campsite option. We planned to camp most of the time but will also stay in hotels in cities or if we just want a roof because the weather is getting us down or whatever. Then we'll try to arrive in QC a couple days early to do tourist stuff before the car rental day.
Bikes: Custom built LHT & Troll
Quoted: 846 Post(s)
Liked 149 Times
Looks like a great plan, probably painlessly doable.
Perhaps you want to list travel time as well as (or instead of) kms. ex: Trois-Rivière > Quebec (148 kms) should take roughly the same time as Quebec > Baie St-Paul (actually, likely less -- apps underestimate the duration of loaded trips when gradient is steep).
I just did a quick google maps thing of QC to Baie St Paul and it estimates about 900m of climbing, and 900m of dumping altitude over 96 klicks. Like I said, depending on your experience going fast on two wheels, be wary of letting things get out of hand speed wise, especially if there is a tail wind.
So 900m climbing isnt horrible, just pace yourselves well.
as for the 150k day, be sure to be well rested and make sure you are eating well (balanced diet wise) as it's still a big old day. Early start is key so you can really pace within yourselves.
ironically enough, I'll be in Ottawa this weekend visiting family.
oh, good to know that you can hit a hotel if needed and for a break from a wet tent or whatever.
You're right, the Trois-Rivière > Quebec (148 kms) is an hour shorter than Quebec > Baie St-Paul (97km).
Yeah, 150k would be a pretty big day for us. When we did our overnight shakedown trip last month we had a 115km day and we were both pretty tired for a few days afterward.
while I'm a slight guy, I figure I'm probably pretty average all in all.
Likes For djb:
Quoted: 846 Post(s)
Liked 149 Times
Take care
Likes For gauvins:
as for the weather, it probably wont be rainy all day, and in the big scheme of things, we just have to get through it and this is part of touring--the mindset of sometimes things aren't great, weather, traffic, whatever, but then a day later we'll have a great day--neat landscapes, fun encounters with people etc and you forget the blah day.
kinda a metaphor for life isn't it?
Roll with stuff and keep a positive attitude.
Likes For djb:
Liked 927 Times
To User 2.
I thought that I had images of my Arno straps on the panniers on my bikes. I guess I lost those along with a lot of others when my old laptop died.
Here are a couple of images I took tonight. the Arno strap is located higher on the pannier than what I usually have it. I don't have a problem with an Arno strap slipping down the frame or pannier.
If I want more security I wrap the Arno strap around the seatstay and also around the last support on t he rack. I don't usually do that. I feed t he Arno strap behind the seatstay and rack supports and then fed t he strap through its buckle at the side of the pannier. Arno straps make panniers very secure to the rack yet are easy to diengage when needed.
If you want clearer images let me know and I'll take some tomorrow with a white paper between the strap and Arno strap to show the Arno strap much more clearly.
Cheers
Cheers
To User 2.
Cheers
Cheers
I like this idea, especially for trips involving rough gravel roads I'm sure it makes everything more secure and the panniers will last longer too.
Appreciate this, thanks. My panniers are kind of tapered towards the bottom so I will have to watch closely if I try this to make sure the strap doesn't slip down and get caught in the wheel.
there's a guy occasionally on here who used arkels and biked all across the 'Stans, Uzbekistan etc and as far as I remember, had no problems and praised arkel stuff and the mount system. Don't recall if he used straps but I'm sure he rode over more rough surfaces there than I did in my Mexico and central America trips.
Larger, more voluminous tires at lower pressures do help though, to an extent, but panniers are still going to get shaken about. This is why I made the steps to eliminate any free play, fattening up the rails with tubing and tape, and it works well overall.
I used 2inch wide tires, they don't look it because my frame can take larger ones, so these look small.
I also left a lot of space between tires and fenders in case of mud, or if I needed to put on some knobby tires.
Likes For djb:
Liked 927 Times
Here is a poor quality image (it's a photo of a small photo) that shows the panniers I first used Arno straps on way back in the 1980s.
Good luck and cheers
Thanks for the additional info on the panniers and straps.
We've made it from Gatineau to Montreal and things are going well so far. Riding the loaded bike is kind of fun, it's like driving truck the way it just kind of rolls over everything.
I was a little anxious when the hotel staff here in Westmount asked us to keep the bikes in the underground parking garage given how often I hear about bikes getting stolen from apartment parking garages in Ottawa. We checked out the garage and it was just an empty bike rack in one of the parking spots. Maybe I was overly conservative since the garage requires a room key to access, but we ended up bringing the bikes up to the room with us. I'm not sure what we would have done if they seen and stopped us from bringing them up here though. We only packed a cheap cable lock for the trip. I'm sure the bike security will become less of a concern as we go further away from the big cities, but it just sucks having to worry about the security situation at places like this.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
If we want a motel/hotel, we look for a mom-and-pop "motel" out of town. Usually lower price and motels have a place to put bike in front of room, if not inside room. In QC we stayed at a bike-friendly place, Le Widor, that had safe storage and was close to stuff. Look for Bienvenue Cyclistes signs.
Likes For IPassGas:
glad too hear that you listened to your common sense thing about the bikes, that's really good, and important. Sneaking bikes into rooms is a very good skill! Just always be careful of chains and bed sheets or curtains, leave no trace.
Too bad I'm in Ottawa, I would have suggested a quick hello.
Likes For djb:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
I only once had a little hotel tell me to keep the bike outside, but it was the tiny village of Field, and I couldn't lift it to the second story anyway.
In Montreal by the freeway, the hotel offered their closet. A bunch of them do this if they refuse bikes in the room.
On my car trip, my CCM was tied to the roof, except for a few layover nights.
Have a great trip.
Have a great trip.
