Practically new tires splitting?
Does anybody know what causes almost new gumwall tires to split so quickly. Replaced them less than six months ago. I wish I could attach a photo. But the forum says I’m not allowed until i write more than 10 posts.
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,570 Times
Happy With My Bikes
Quoted: 882 Post(s)
Liked 2,305 Times
I put tires just like those on an old Takara about a year ago. I haven't put many miles on them but they look like the day I put them on (about 100 miles give or take). Just a guess, maybe these were older tires when you bought them. I would think that even under inflated they would hold up better. But what are you inflating them to?
Edit: And I would contact where I bought them to see if they will stand behind them.
Quoted: 4559 Post(s)
Liked 2,802 Times
Try another tire. I've never had that problem with Continental Grand Prix Classic or Soma Supple Vitesse skinwalls. Those aren't too expensive either for good quality tires. Excellent ride quality too.
That tread pattern on the pictured tire vaguely resembles the Conti GP Classic, but the genuine Continental tire has reddish brown sidewalls. They're translucent, not gumwalls stuck to the sides. Remarkably tough too, although I avoid gravel on those tires.
Likes For canklecat:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Don't know the cause, but it appears that the fact that the tires are gumwalls is irrelevant.
Likes For Sy Reene:
Quoted: 18404 Post(s)
Liked 15,496 Times
Looking at that photo I get the sense that it's a cheap tire. I am guessing an on-line, the-price-was-too-good-to-pass-up special.
Quoted: 18354 Post(s)
Liked 4,502 Times
It looks like you've put a fair number of miles on those tires.
But, as far as the cracks, those look like they may have been NOS tires.
Are they 27"? Perhaps they tend to sit on the shelf for a few years at a time.
The only things I can think of that would cause damage like that would be a LOT of direct sunlight, or perhaps parking on a hot air vent.
Likes For CliffordK:
Quoted: 4388 Post(s)
Liked 4,828 Times
What tyres are those? They could just be ancient stock or some cheap junk.
Likes For PeteHski:
Quoted: 4245 Post(s)
Liked 1,350 Times
Looks like the tires are really old. That’s why they split.
Ive never seen tires do that. Even ones with thousands of miles on them.
climber has-been
Quoted: 3417 Post(s)
Liked 3,548 Times
If a tire cracks when almost new, it was probably exposed to one or more of these causes before it was installed.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Quoted: 8266 Post(s)
Liked 9,000 Times
I have Vittoria Rubino Pro tires doing that. I usually buy them on-line and I think two of them must have sat around because I had to take one off because it was splitting so bad and the other is starting to get the same way.
Likes For popeye:
Quoted: 6178 Post(s)
Liked 4,796 Times
I don't have any need for gum wall tires. But I've not bought a pair this century at all. So maybe the tech is better. But the tech has also gotten so much better with modern tire compounds that the benefits of gum walls today aren't anything other than cosmetic.
In the 70's, they'd look like that or worse pretty quick from UV damage. Maybe if that is a cheaper brand of tire, there isn't much UV protection for any of the material whether the gum wall or tread.
Might be the camera angle, but the tire looks like the bead might be at the witness line in the area where the cords are showing in the tread. Is this a 27" tire? Last 27" tire I bought had to be a cheapo tire and I had trouble getting it to seat properly on the rim. That was on my old Varsity that I pretty much gave away for the cost of the chain and a few other things I had just put on it.
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
Is that one of the Rene Herse tires?
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
That's a really inexpensive tire. It probably had been sitting around for a long time before you got it. Sorry.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Quoted: 641 Post(s)
Liked 1,517 Times
Tire looks old. Check the date code to see when they were made.
Likes For Ogsarg:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
You're kidding right? Of course it's not one of those. It's a cheapo CST that's falling apart.
No. They actually look quite different. RH slicks have a strip of flat tread between the herringbone section and the sidewalls, which is apparent in the image you posted.
RH slicks also generally have either a bald or ribbed center, not the diagonal cuts seen in the OP.
Apologies for backwards tire:
Liked 4,828 Times
They actually look like non-branded tyres from the 80s that you typically got on mail order catalogue bikes! I like how the black "tread" section is just painted (really badly) onto the casing.
Likes For PeteHski:
The reason it looks sloppy is that the tread rubber wasn't well-aligned with the tread patterning in the vulcanizing mold.
Liked 4,828 Times
Yes, I was kind of joking. This tyre is so badly made it doesn't really surprise me it that it fell to pieces.
i’ve been inflating them to 90 psi which is the max pressure allowed. And it has probably been almost a year, so I will check with the bike shop to see if they’ll stand by them.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
It's no big deal - the rubber doesn't provide the strength, the casing does that. As long as the splits aren't so big that the exposed casing is vulnerable to cuts you should be fine.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Liked 4,828 Times
