Replacement chain for old Shimano 3x7 STX
Bikes: Raleigh MT-200 (1994), GT Karakoram Elite (2013)
I have an old Raleigh MT-200 (which I love as if it were the Old Faithful), with a Shimano STX set.. As per the chain checker tool, I need a replacement chain.
I found mostly that Shimano CN-HG40 may be the right part. In this respect, I have several questions:
- Is it the right part? In a Shimano page it is mentioned that it is "for precise index shifting on 6, 7, and 8-speed HYPERDRIVE SIS and DUAL SIS drivetrains." I am not sure it is ok for me.
- If not, what is the right part?
- Are there many alternative models from Shimano, which may work well. If so, what should I consider to choose?
- Are there alternatives from Shimano which already come with a quick link?
- What are other good alternatives, from other brands?
Expired Member
Quoted: 3672 Post(s)
Liked 5,424 Times
I'd suggest you get an 8 speed chain from SRAM or KMC. They both come with quick links. Even the least expensive will be fine.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Any 6/7/8 speed chain will work just fine. KMC, SRAM, Shimano, are the usual suspects
Likes For dedhed:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Any 8-speed chain will work. 6/7/8-sp uses the same chain, so no need to hunt down NOS 7-sp.
KMC Z-series or SRAM PC-800 series. You may find different models, like PC-830, PC-850, but that generally refers to the finish (black, silver, nickel, etc) than any real structural or performance difference
Really Old Senior Member
Chain checkers can tend to cause one to replace chains before needed.
IF the checker says it's bad, THEN it's time to measure with a ruler to confirm.
I like to measure a 3' section of chain to get a bit better resolution than measuring 12".
1/16" per foot is worn out.
Quoted: 114 Post(s)
Liked 119 Times
I've used the SRAMS 8XX (830, 850, 870) chains in the past with no problems. Their quicklink can be removed with your fingers, no special pliers needed.
Would you know what is the difference between z6, z7, z8.1, z8.3, and also x series? X8.1, X8.2...Thanks!
Any 8-speed chain will work. 6/7/8-sp uses the same chain, so no need to hunt down NOS 7-sp. KMC Z-series or SRAM PC-800 series. You may find different models, like PC-830, PC-850, but that generally refers to the finish (black, silver, nickel, etc) than any real structural or performance difference
Quoted: 836 Post(s)
Liked 1,061 Times
