Flat bar road bike comversion
Bikes: Cannondale's R2000, R-1000, RT1000 Tandem , Killer-V 900HT, Miyata Dupli/Cross Tandem , Specialized Ground Control A1 Comp , K2 5.0 Comp , Trek 820 , Giant Kronos lugged steel ,Raleigh M-60, Gary Fisher Pro-Caliber.
One of my winter projects is to convert my wife's C-Dale R-1000 to a Flat bar.
My question is, are there any twistgrip shifters that will work with Ultegra F&R derailleurs. Would prefer to use this type of shifters vs trigger due to cost and simplicity of use.
Quoted: 1572 Post(s)
Liked 643 Times
Probably.
SRAM produced Shimano compatible twist shifters with friction front and up to 9 rear cogs.
Bikes: cannondale 400st, dean el diente, specialized hybrid
Quoted: 20 Post(s)
Liked 7 Times
SRAM shifters with names,e.g. attack, if I remember correctly will in theory work with shimano derailleurs. I hope, because I need to put grip shifters on my trail bikes.
Bikes: Serotta Davis Phinney, 1992 Serotta T Max,1984 Specialized Allez, Olmo, 1974 Strawberry,Redline bmx, ect.,
I would recommend the Shimano flat bar road shifters because of the trim feature just like her STI levers were the gripshift front shifter is shift by feel.
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Except Shimano's flat-bar shifters won't work correctly with the OP's Ultegra front derailleur. The SRAM Attack shifters work with the Shimano rear derailleur, and the "micro-ratchet" front shifter will work with the Ultegra.
Jeff Wills
Jeff Wills
Likes to Ride Far
Some of SRAMs grip shifts are now indexed on the left/front shifter. The ones that are friction (or, at least have many click positions) work well with all front derailleurs. I've had good results using a 2006 X-7 left-hand grip shift that had about 7 clicks using it with a 105 triple FD. In 2009 I replaced the rubber on the gripshift had worn down so much that it was hard to turn, especially when wet, so I tried to replace it with a X-9. I was disappointed to find out that the X-9 left-hand gripshift was indexed with only 3 positions. With some skilled cable adjustment and using the limiting screws, I was able to get it work OK, but I was happier when I was able to switch the 105 FD for a MTB version.
So, can anyone confirm which SRAM grip-shifts are now friction (or at least had 7+ positions) and which are indexed (with only 3 positions)?
SE Wis
Quoted: 2745 Post(s)
Liked 3,390 Times
Here's some more info. Flat bars near the end.
https://bike.shimano.com/publish/cont...ty%20Chart.pdf
we be rollin'
If you want mountain grip shifters with a road front derailleur, you need the flat bar group front derailleur like FD-R443.
