Sidewall bubble
Sidewall bubble
Old 12-23-19, 10:15 PM
illdrag0n
illdrag0n's Avatar
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times in 68 Posts
Sidewall bubble
Hey guys,
Mounted my brand new Rubino Pro G2.0+ onto the back wheel and seated at 120psi. Noted this from the logo. Popped with a tiny bit of presure.
Theres no bulge and the tyre is holding pressure. Should i be concerned?
illdrag0n is offline
Old 12-23-19, 11:15 PM
Dannihilator
Still kicking.
Dannihilator's Avatar
Bikes: Bike Count: Rising.
Quoted: 159 Post(s)
Liked 46 Times in 32 Posts
I would not try to ride with that tire. The casing threads shifted/were faulty.
Appreciate the old bikes more than the new.
Dannihilator is offline
Likes For Dannihilator:
Old 12-24-19, 11:59 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times in 560 Posts
1. The tire is fine. It was damaged in shipping/in plant. Not uncommon to occasionally get some bubbles or popping on the casing when it finally get pressurized on the rim. Some gases or air voids left in the casing from when it was made.
2. The hole - presumably from popping that bubble - is also fine. The cords do the work. None of them are broken. The tire isn't bulging and assuming the air is still in the tube and it didn't flat.
3. Sure it's not what you want to see in a new tire. Take it back to where you bought it.
4. If you ordered it online from a large cheap priced discounter and it came without packaging then *shrug* it is what it is and ride it.
For all these people who see the slightest little tire defect and think that means the whole thing is liable to assplode any second - I simply invite you to spend any real time in any bike shop and look at the completely dry-rotted out tires that hold 100 psi that come in and out of shops daily that people continue to ride on for years.
So your tire is fine and will have a long life. If you can get it back to someone responsible in the supply chain then they would most likely replace it for you.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 12-24-19, 07:01 PM
illdrag0n
illdrag0n's Avatar
Quoted: 121 Post(s)
Thanks for your responses;
1. I assumed it was the case and there's no possible way it's a punture, seeing as the rubber was air tight and the tyre was brand new in box before mounting.
2. Yes, i popped the bubble. It's mounted in tubeless configuration with stans, and is holding pressure fine.
3. Rather not bother, it was a $40 online purchase.
4. Assume this is the case. It's still mounted to the rim and i stuck the flap down with a little bit of vulcanising rubber glue.
At this stage i'm feeling pretty confident enough to ride it. Can't see it being any more dangerous than a dynaplugged hole.
