zwift - 9 speed vs 11 speed on the smart trainer?
I got a used taxc neo and decided to put my old 9 speed bike on it. Is it a disadvantage or are there negatives of using a 9 speed bike vs 11 speed on zwift (or other virtual/training ride apps)?
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,182 Times
assume you have a 9 speed cassette installed on the tacx, you do, don't you? i run an 8 speed and it is just like...an 8 speed.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
number of speeds don't matter. it's all about the watts. 200w with a 38/30 is the same to the trainer (and to zwift er what have you) as 200w with a 52/11. Your cadence and torque may be different, but the trainer don't care.
(fwiw, I go back and forth between an 11sp and 8spd. the workouts hurt all the same)
now, your jumps in cadence are more noticeable with fewer cogs, just like outside....
Likes For superdex:
Randomhead
Liked 3,694 Times
zwift's "trainer difficulty" setting makes the number of gears less important. I don't think that's a good name for the setting, but I'm not sure I have a better name that would make sense to people
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
Yeah, 9 speed cassette installed on the tacx neos. Based on everyone's response, I guess it doesn't matter - since it seems to be about the watts for the trainer. Thanks guys for the explanation!
Makes no difference, if you are like me, you'll spend 95% of your ride time in the same gear.
It’s best to use the same gearing as your road bike. That is if you wish to transfer your indoor training toyour outdoor rides. I found this out this year. I have a Kickr bike so I can have any type of gearing I want. But my real world bike is a vintage bike with a 6 speed cassette. I was riding 12 speed indoors and a wide range of gearing I didn’t have on my road bike. When needless to say it didn’t help on my outdoor riding. So I matched the gearing and now I have a better understanding of what I am don’t as far as how it will transfer to the real world.
Randomhead
Liked 3,694 Times
That hasn't been my experience. There definitely is some specificity, but I don't think having the same gears makes much difference.
The big thing I noticed was the year I did all my hard efforts on the trainer while standing. Climbing steep hills while sitting wasn't great that year.
Hmm... there seem to be some ambiguity. If I put out 200watts of power, how does this associate with cadence? (Probably should google around in more in-depth on both Tacx Neo and Zwift regarding gearing....)
Quoted: 394 Post(s)
Liked 197 Times
here are a couple calculators to play with: Watt ? Speed ? Cadence ? Gear calculators ? Cycling Guy ? Cycling Events ? Cycling training tips
Likes For superdex:
Quoted: 1456 Post(s)
Liked 1,477 Times
Gearing is irrelevant if you run your trainer in ERG mode, which will let the trainer automatically adjust the resistance to match a specific output (watts).
ERG mode is good for structured workouts and you should not be shifting at all when using it. Just pick a gear in the middle and let the trainer decide how hard the resistance should be. In this case - 9 speed vs 10 or 11 speed has zero impact.
I also like to free-ride in Zwift, and when doing that I run the trainer difficulty at it's max setting so that the hills/descents are simulated closer to reality. In this setup, I am shifting through all of my gears on most rides and using the full range of my cassette. In this situation - 9 speed is going to have the same downsides in Zwift compared to 10 or 11 speed that you would find in real life. Larger gaps between gears would be the most notable downside.
Likes For msu2001la:
