Ruler and Chain Checker are Diverging
#76
Pin wear and any roller wear (which is vanishingly small) are combined in any measurement you make on a chain. I will not say that chain checkers are more accurate or measure roller wear over the rule method. The amount of wear measured with both methods is the same and either method can be used. I find the chain checker to be quicker to use with the same result. If you think differently it is up to you to demonstrate how the measurements can be disconnected.
Again, my main objection to the rule method is the use of a 12” rule and the estimation of the 1/16” wear while simultaneously claiming that the rule method is “more accurate”. Get a 13” rule and I’d have zero problems with the method. I still don’t think it is more accurate than a chain checker.
#78
SRAM says to replace at 0.8% without specifying cassette speeds. KMC says to replace the chain between 0.75% and 1%, again, without specifying speeds. I can’t find anything from Shimano. Park Tool says to replace 10 speed and below at 0.75% and 11 speed and above at 0.5%. Pick your poison.
The rule method, by the way, replaces chains at 0.5%. 0.75% would be 3/32” and 1% would be a full 1/8”.
11 speed and above chains are thinner with regards to overall width. Perhaps the thinking is to replace them at 0.5% since the pressure on the pin is greater.
#79
Quoted: 4337 Post(s)
Liked 1,521 Times
If a chain checker's instructions say that the chain should be replaced at .5%, that doesn't mean the chain should be replaced when a ruler shows .5% elongation. They measure different things.
#80
Sure. Please do that
I have measured new Shimano, KMC and a YBN 10s chains. They were all close to 132.25 mm when measured as suggested by campy.
Taken at face value and assuming 132.6 mm is representing 0.5% wear. A new chain should measure ~131.94 mm. However they dont. I suspect the engineer calculating the numbers forgot to account for slop in the rollers that adds at least a few tenth of a mm. That, or a campy chain has bigger rollers than shimano and the rest of them. I dunno?
No matter, I have found the campy method doesnt work well with shimano or other generic chains. A lot more wear is tolerable than tossing the chain at 132.6 mm.
#81
Shimano, SRAM, Park and others all have chain gauges that are designed to exclude roller wear. Seem to indicate roller wear is not significant and including it may in fact hinder measuring the the relevant wear component.
#82
Quoted: 1104 Post(s)
Liked 1,824 Times
#84
Yes, like that.
They measure elongation with the rollers pushed in the same direction, where older model gauges pushed rollers in opposite directions, thus adding roller wear to the measurement. Im not aware if this was attempted taken into account or not.
Funny how the SRAM gauge allows for up to 0.8% true elongation, 60% more wear than the oft cited 0.5%.
#85
Liked 1,521 Times
Yes, like that.
You are right that the pins get pushed the same way, subtracting the roller wear. I wonder if they consider that more accurate, or if they are bowing to public opinion that rollers shouldn't be checked after decades of doing exactly that.
#86
Quoted: 2332 Post(s)
Liked 2,097 Times
The reason is better resolution. By far.
Likes For GhostRider62:
#87
Liked 1,824 Times
No doubt about it, there are a few ways to get the job done. He made a statement of fact (according to him) and I want him to explain it.
Quoted: 2593 Post(s)
Liked 1,922 Times
#89
Liked 2,097 Times
#90
Pedro's Chain Checker Plus II | Jenson USA
#91
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,198 Times
The rollers have zero influence on how elongated the chain gets from pin and link wear and absolutely will not show up if you measure the chain with a ruler. Pin to pin distance is entirely a measure of how the inner links and pins contact each other. Having a ring around the two won't change that.
The looseness of the rollers will cause wear on the cogs but that looseness is related to the pin wear so if we measure pin wear, we end up in the same place with regards to the need to replace the chain. Again, there is no reason to be concerned about the what little (if any) roller wear occurs. It’s a nonissue.
Stuart Black
Stuart Black
Likes For cyccommute:
#92
Liked 4,198 Times
Sure. It’s all over the place and opaque what the percentages is in reference to. Some toole even uses mm rather than %. Thus I made up my own campy like system, but with significant more allowance for wear, as mentioned in an earlier post. Ive been meaning to get a shimano chain checker to see what they consider "worn out" but so far I haven't. If anyone has one (or any other brand) and a digital calliper id be interested in the go/no go dimensions of such tools. I'm betting they too are all over the place.
The rule method folks always point out the horror stories of people showing a worn out new chain to hammer home their point that their method is “better”. I would hazard that the vast majority of those kinds of measurements are user error.
Stuart Black
Stuart Black
#93
Liked 1,521 Times
I do agree with you but have to ask why are you making such a big deal about roller wear? Measuring with a rule or measuring with a chain checking tool gives the same result so the measurement is equivalent and we don’t need to know anything about roller wear. There’s no need to even be concerned about it…if it even happens. It. Will. Make. No. Difference.
If the rollers have wear, that wear directly impacts chain pitch when wrapped around a sprocket.
Elongated chain pitch is what wears out sprockets prematurely.
If you want to know what the chain has for actual on-sprocket chain pitch, you can't ignore the other source of elongation: The rollers.
You can't measure roller wear by measuring the pins alone.
That is the last time I'm going to explain that to you. The fact that seemingly flip flop between understanding and not understanding what a ruler measures makes communicating with you too frustrating.
#94
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
The standard chain check tools like the CC 3.2 take the pin wear and add the wear of the the two rollers. That will give a different distance than measuring the pins alone if the rollers have wear.
#95
Liked 1,521 Times
Yeah, why can't I be polite and friendly like you?
I participate in all sorts of forums about all sorts of topics. This particular one is full of interesting problems that I love; but also aggressive, dismissive, passive aggressive and insulting people who seem to hate nothing more than someone who actually knows what they are talking about. It is mind numbing how hard it is to have to explain, explain and re-explain even the most basic geometrical concepts to other adults who think I'm being ridiculous for suggesting that bikes work the way they actually do.
Instead, I should be like the typical person I end up dealing with post after post - someone who doesn't seem to ever suggest an actual solution to anything, doubts and dismisses everything and takes personal swipes at anyone actually useful to make themselves feel better for being little more than an aggressive doofus. I don't know why that's the way it rolls here and other bike forums, but maybe you just don't have to be very smart to pedal a bike or type on a keyboard.
I love my writing forum. Everyone is smart and the doofuses get banned sooner rather than later. People actually like it when someone has knowledge or ideas.
#96
The problem with you is that you never stop to consider that you might in fact be wrong. In pretty much every topic you have a rigid (and often quite simplified) opinion of how this or that particular thing works and that opinion is then dogma, the pinnacle of science (even with no evidence) and the ultimate truth. All other possibilities are simply false and not worth even considering.
I see that a lot in my profession. The strange thing is that people don't learn even when they are shown to be wrong in the most definite possible terms.
Likes For elcruxio:
#97
Liked 1,521 Times
I'd think you were being ironic if I didn't know better.
We can have a debate about whether roller wear is a factor in cog wear, and I am entirely open to being shown to be wrong. Just as I admitted a few posts ago that the new Park tool removes the rollers from the measure. But we can't have a conversation about the topic of roller wear if people don't understand where the parts of the chain are. And that stuff ends up being half the posts.
It is tough having an engineering conversation mixed with remedial topology. Especially when the people that really don't get it are insulting.
#98
Liked 2,097 Times
The recommendations are all over the place because wear is a range rather than a hard value. It’s not like you are supposed to change your chain at 3247.3 miles, no more, no less. The whole “rule method is more accurate” argument is kind of silly since there isn’t a given value for chain wear. We replace chains when we get to about 0.75% (0.094” elongation over 12” or 3/32”) to prevent wear of the cassette and, to a lesser degree, the chainwheels. And that’s only for derailer bikes. Single speed or IGH chains can go for many more miles because they aren’t being shoved from side-to-side regularly.
Go/No Go gauges were put in place for monkeys.
0.75% is way too much to prevent chainring or cassette wear. Secondly, once wear starts on a chain, it is not linear. So, 0.4% is when my chains get tossed. It can be as little as 4,000 miles or as much as 10,000 miles.
I'll let the rest of you argue about rollers.
#99
Expired Member
Quoted: 3648 Post(s)
Liked 5,381 Times
It might save you some aggravation if you share your engineering credentials in a signature. In my experience, folks here are respectful of actual expertise.
Likes For shelbyfv:
#100
Sock Puppet
Liked 863 Times
I don't know. Only you or maybe a therapist can answer that.
Lots of anger and rage in this post. Don't let your rage consume you. It's not healthy.
Pins, rollers, who cares? All I know is that the humble ruler lets me know when to replace my chain. And I also know that chain checkers can read worn before the chain really needs to be replaced. And I have never trashed a cassette by leaving my chain in service too long. And you know what? I get about 8K miles out of my chains.
I remember a good quote from a good wheel builder on RBR that is appropriate here. "With bicycles in particular, you need to separate between what's merely true and what's important".
