Enviolo + mid-drive = bad?
Quoted: 573 Post(s)
Liked 118 Times
Hello,
Looks like someone isn't happy with his brand new cargo bike powered by an Enviolo 380 gear hub and Bosch Cargo Line 4 Cruise mid-drive motor, although he was told by the LBS to be light on the pedals when changing gears.
This is not the first time I read about issues with the Enviolo and mid-drive motors: Is that gear hub simply to be avoided for that particular setup?
Thank you.
Edit: Could it be it's just a broken freewheel?
Thank you.
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Haven't really seen a major problem so it could be an issue with the hub. We sell a ton of Enviolo equipped e-bikes and we have had occasional problems with people being rough with the shifter when not pedaling and wrecking cables and the cassette joint (or whatever they call it). Certainly you would be best to consider the cargo hub from Enviolo but one would hope they already spec'd that. I would take it back to the dealer and have them take a look at it.
Not sure what your problem is as the video glitches out on me and I don't tend to download random stuff but the shop should be able to look and hopefully determine what is wrong either that or Enviolo could help.
Yes easing up on the pedals while shifting is good practice. It is what I do with my Rohloff hub now and it works well (I have a gen4 Performance Line Speed motor and am a bigger rider myself)
Quoted: 573 Post(s)
Liked 118 Times
It's not mine. I asked because I read other people having issues with mid-drive and Enviolo hubs.
I also read from another user that the cables used by Enviolo aren't as strong as those from eg. Shimano, which is a second reason to not try and shift all the way at stand-still. Unfortunately, not all bike shops warn riders about that feature of Enviolo hubs: People expect to be able to shift down all the way, like with a Shimano or Rohloff.
In that particular video, if it's just the freewheel that needs replacement, it should be easy.
Clark W. Griswold
Liked 3,986 Times
I haven't seen many issues but things occasionally happen with any system.
