Top Fillet Brazing Vintage (New one)
#101
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have built with tubing down to .7-.4-.7 which is why I tend to stick to silver.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
#102
Quoted: 1245 Post(s)
Liked 1,321 Times
1946 Schwinn Cruiser
Likes For Atlas Shrugged:
#105
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
You will never know whether there was cleanup post brazing or not most likely there is some. Obviously if the frame builder is doing this as a business the less filing the better. I am still mystified about the romance that surrounds filet brazing. It is clearly the simplest method requiring the least skill, fewest specialized tools, easiest to repair and coverup errors, cheapest materials cost, heaviest and finally the weakest.
Admiral Grace Hopper
"...heaviest..."
Henry James bottom lug
3/16 Gasflux C-04 Nickel Bronze Rod
Practicing fillet brazing - less than one stick of bronze filler rods used on each. Pix cause it happened.
"...stronger..." Many have claimed this, but I'd like to see some destructive testing data. Rather than do all the work here, I'll let you find that. I would say that fillet brazed, lugged, and TIG welded frame joints are "strong enough"
"...least skill..." You a framebuilder? Again, UBI teaches both methods, but you need more practice time on fillet brazing before they let you loose on real tubing.k
"...fewest specialized tools..." What specialized tools do you need for a lugged frame? Be advised I've done both.
"...easiest to repair and cover up errors..." You a framebuilder?
"...cheapest materials..." Yep, lug cost + silver brazing costs more.
It comes down to style, and lug angle availabilty.
Likes For gugie:
#106
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
"One accurate measurement is worth a thousand expert opinions."
Likes For Cynikal:
#107
Liked 1,321 Times
"...heaviest..."
"...heaviest..."
#108
Quoted: 4509 Post(s)
Liked 6,374 Times
#109
Liked 5,790 Times
As a certified welder and journeyman Tool & Die Maker (5 year apprenticeship) who has spent decades in custom metal fabrication there is nothing special about frame building and especially fillet brazing. The fact that there are one and two week courses that teach it to complete neophytes pretty well explains it. You never see fillet welds in Aerospace, nuclear, high pressure or any other areas which require certification. Frame Building is much like the Wizard of Oz a lot of marketing and superfluous fuss yet nothing special behind the curtain.
#110
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
#111
Quoted: 3803 Post(s)
Liked 6,639 Times
I’m a certified internet opinionater, and I think this thread is dumbed.
Likes For nlerner:
#112
Go Ride!
Bikes: Klein Quantum Pro, Klein Attitude, Azuki SS, Merckx AXM, Klein Quantum Race, Klein Quantum
Quoted: 109 Post(s)
Liked 155 Times
I
I’ve always admired the welds on the old Klein frames….but some of the brazing photos posted on this thread make these aluminum welds look sub par!! Always great to see craftsmanship and care evident in the outcome of something built by hand.
Likes For Sonofamechanic:
#113
Quoted: 3464 Post(s)
Liked 2,827 Times
but since the thread is about fillet brazing, the Viscount Pro.
#114
Liked 2,827 Times
marketing is necessary to help keep the doors open.
you have never brazed up a set of chainstays into a bottom bracket and then found that the rear spacing is not what you fixtured it to.
build a half dozen frames and report back.
#115
Liked 5,790 Times
Currently I use 56% silver as much as I can due to the lower temperatures. I keep the lugs and braze-ons to silver but use brass on cantilever studs. There are great silver alloys that buildup like brass at lower temperatures. I have used 50n silver and about to start playing with 45% silver to start learning fillets.
Rather than choose between lugs and fillet brazing, you can have both in bilaminate construction (pic from Brian Chapman):
Video of the master at work: https://www.flickr.com/photos/chapma...in/dateposted/
Likes For gugie:
#116
Liked 6,639 Times
#117
Quoted: 2337 Post(s)
Liked 2,809 Times
#118
Quoted: 4224 Post(s)
Liked 2,944 Times
#119
Liked 5,790 Times
If you love that, more Chapman bike porn can be seen here. This guy's the full package, a full constructeur. He's got his own crank and brake design, does his own paint, has great artistic skills, great photographic eye, and his videos are extremely well edited. Oh, and prolific as well.
Likes For gugie:
#120
Liked 1,321 Times
If half a dozen frames are what it takes to master the welding of a bicycle frame, you are making my point. As far setting up the fixture correctly and ensuring alignment remains in place can be quickly learned and mastered. Anyone with a solid mechanical aptitude, patience, appropriate supplies, and some mentoring can consistently and reliably make a bicycle frame.
#121
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Likes For Cynikal:
#122
Quoted: 634 Post(s)
Liked 444 Times
#123
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,454 Times
Attempting to convince Ayn Rand of turning over in her grave with a thorough appeal to faulty logic?
