Silver downtube shifters
Old 01-03-12, 06:19 PM
Yo Spiff
Carpe Velo
Yo Spiff's Avatar
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 13 Times in 12 Posts
Considering buying a set of these Silver shifters from Rivendell for an 80's bike with Shimano 600 levers that won't stay put. They are actually shaped a lot like the Shimanos and the description sounds like they may be worth it. Wondering if anyone has any experience with them?
https://www.rivbike.com/product-p/sh11.htm
Yo Spiff is offline
Old 01-03-12, 07:18 PM
RJM
I'm doing it wrong.
RJM's Avatar
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times in 1,664 Posts
I have a Jamis with them, my Riv uses the barend version and have ridden a few other bikes with other brands/types of downtube shifters and I think the silvers are among the best. I like the look of the old campagnolo downtube shifters better, but the silvers work better. Of course they are only friction shifting so if you want indexed downtube shifters you need to look elsewhere. The silvers are really smooth operating but they also stay put and don't ghostshift, assuming they are tightened enough. They just work well.
RJM is offline
Old 01-03-12, 07:35 PM
canam73
Quoted: 13 Post(s)
Liked 9 Times in 5 Posts
I have a set as bar-ends also and I think they are the best fiction shifters that I have tried.
canam73 is offline
Old 01-03-12, 07:43 PM
Yo Spiff
Carpe Velo
Yo Spiff's Avatar
Thanks for the input. The RD is index capable, but I'm only caring about friction shifting for this bike.
Yo Spiff is offline
Old 01-04-12, 11:25 AM
greaterbrown
greaterbrown's Avatar
I bought a pair of these from VO several years back. I had been using Shimano's 8-sp DT indexed shifters.
I wound up sending the VO shifters back and converting to Shimano 9-sp Deore DT shifters.
What I didn't like about the VO shifters (which I believe are exactly the same as the Riv version) is the ratchet. You move the shifter to bring the RD into your gear selection and the shifter "falls back" to the nearest ratchet. This fall back effectively un-trims the shift, putting you slightly off gear. So, you must learn how to slightly over shift to let the shifter fall back to a (hopefully) correct trim. Argh!
I'd love to see VO/Riv bring out a true friction shifter with out ratchet. ie campy's record era.
Try em. Maybe you'll love em.
greaterbrown is offline
Old 01-04-12, 11:57 AM
Doohickie
You gonna eat that?
Doohickie's Avatar
Location: Fort Worth, Texas Church of Hopeful Uncertainty
Bikes: 1966 Raleigh DL-1 Tourist, 1973 Schwinn Varsity, 1983 Raleigh Marathon, 1994 Nishiki Sport XRS
Quoted: 164 Post(s)
Liked 67 Times in 44 Posts
I've always seen the ratcheting as a plus. I usually have to over shift slightly to get the chain to move to the desired gear and letting it fall to the next ratchet stop trims it fine.
Spiff: I have some old Suntour friction DT shifters that don't ratchet if you'd like to try them. I don't need them.
A little different style than Shimanos....
I stop for people / whose right of way I honor / but not for no one.
Originally Posted by bragi "However, it's never a good idea to overgeneralize."
Doohickie is offline
Old 01-05-12, 08:11 AM
Yo Spiff
Carpe Velo
Yo Spiff's Avatar
Thanks. I'll let you know. Might try again to get the original 600EX levers to hold better. Not in a rush, as this is a spare bike.
Yo Spiff is offline
Old 01-05-12, 09:09 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 914 Times in 603 Posts
Is the screw very tight, but the lever is still too loose ?
Maybe you're missing a washer or one of the internals is flipped ?
Homebrew01 is offline
Old 01-05-12, 09:14 AM
BillyD
Administrator
BillyD's Avatar
Quoted: 11794 Post(s)
Liked 6,295 Times in 3,335 Posts
Handsome bike.
BillyD is offline
Old 01-05-12, 09:24 AM
Doohickie
You gonna eat that?
Doohickie's Avatar
Quoted: 164 Post(s)
Originally Posted by BillyD
Handsome bike.
Thanks. It's been updated since then.
Old 01-05-12, 09:49 AM
RoboIsGod
RoboIsGod's Avatar
Bikes: 2020 Fuji Transonic; Zunow Z-1; All-City Macho King ACE; De Bernardi Track
Liked 10 Times in 1 Post
I'd search Ebay for a nice set of Dura Ace or 600 shifters. Even a set of Suntour Superbe's would look really nice and work very nice as well.
RoboIsGod is offline
Old 01-05-12, 09:54 AM
Commodus
Liked 3 Times in 3 Posts
I'm not an expert on these things, but on the set of 7400s I picked up recently there is a little star washer inside. It is worn (kind of squished by the pressure from tightening them down), and I believe it is the cause of the slippage I was getting. I fixed it by just going indexed, but I wonder if the washer was replaced it might fix the problem we're having.
Commodus is offline
Old 01-05-12, 10:59 AM
Yo Spiff
Carpe Velo
Yo Spiff's Avatar
I do think there is a washer worn. I tighten it down fully and the lever still slips under tension. I roughed up the mating surfaces a little and it holds better than before, but still not great. I guess if I do a little research, I can find some appropriate replacement internals.
Yo Spiff is offline
Old 01-07-12, 06:30 PM
Walter
SLJ 6/8/65-5/2/07
Walter's Avatar
Liked 19 Times in 6 Posts
The washer wears on DT shifters and that causes the problem. Back in the day it was an easy fix but nowadays I'd imagine spare parts are rare to non-existent. Have heard good things about the Riv shifters but haven't used them. I friction shift my FD even on modern bikes due to circumstances pretty much unique to myself and use SunTours that I regularly find on eBay but they are ratcheting.
“Life is not one damned thing after another. Life is one damned thing over and over.”
Edna St. Vincent Millay
Walter is offline
Old 01-07-12, 08:31 PM
Commodus
I don't think those washers are special. At work I have bins full of 'em, various sizes. Maybe the size is odd, but worth have a look into.
Commodus is offline
txiong
Road Cycling
42
03-08-18 09:46 PM
dinkjs
Bicycle Mechanics
16
09-09-11 01:07 PM
hoyc
Classic & Vintage
11
06-08-11 06:08 PM
ph4nt0mf1ng3rs
Road Cycling
67
09-26-10 04:26 PM
hernick
Classic & Vintage
55
04-02-10 11:22 PM
