Catching up after a while: Puncture resistant tires, shoes
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
There are other options for creating courses for your Garmin Edge 830, but I've found their site the easiest to work with.
Likes For terrymorse:
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
Do you have an account at ridewithgps.com?
By the way, it seems that you can also use Garmin Connect to create a route. I'm assuming you've used it and found not as simple as ridewithgps.
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
Hahaha, that's random, but funnily innovative. Drying the shoes after washing them? I can't say I ever washed my shoes since never had issues with sweating inside. Ventilation has been good in the old Diadora shoes and the Torch 1.0 has a vent even underneath the shoe, so hopefully no sweaty feet there either.
Liked 10,646 Times
If you plug your Garmin into a computer, there's a hidden folder called new files, copy the route you exported from rwgps into that folder and your Garmin will turn it into a route (it can use) when you unplug the USB.
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
Yeah, I know about Garmin folders. My point was that Edge 500 has horrible navigation and if you are trying to explore a new route and get off track, I've found it pretty difficult to navigate back to the path, so I didn't use it despite having downloaded many routes into the device. From the videos I saw on Edge 830 navigation, it should be nearly perfect.
climber has-been
Liked 3,563 Times
My experience using Garmin's UI is pretty awful, and I didn't want that frustration.
Not when the ridewithgps UI is so good, and mature.
Quoted: 765 Post(s)
Liked 1,733 Times
Garmin Connect was designed by creatures from hell. It was the reason I left Garmin and moved to Wahoo.
Likes For jaxgtr:
Xc7
Well, XC7 is over $200, more than twice the cost of Torch 1.0. I picked it up today for $109, which is closer to my budget. On the other hand, I did go all in on a bike computer and finally upgraded by Edge 500 to Edge 830. Can't wait to try out the navigation when it arrives tomorrow. I've been relying on my phone and google maps, but it hasn't worked well when I get off the path.
I have the Garmin Edge 530 and Love it!! The Garmin Connect app is great.
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
An update: I actually used Garmin Connect to create a few courses and it wasn't bad at all. It seems Garmin has fixed some of the issues it used to have in the past, like the inability to duplicate a course. It still has clunky areas, but is free. Ridewithgps requires a monthly subscription if you want to get turn by turn alerts come up during your navigation when you download the course file from there. That wasn't worth it for me. Plus can send any courses from Garmin Connect wirelessly to the Edge.
Likes For Excelsius:
Quoted: 4399 Post(s)
Liked 4,846 Times
It's not that hard.
Are you aware of particular issues for the conversion? From what I read, it seems all rims should be "TLR".
Aerothan is an interesting concept, but at $30/piece plus inability to repair, I'm not sure it's a good investment. If the tire is protecting from flats already, not sure if the tube would be important because if anything can get through a tough tire, the tube wouldn't stand a chance. But I would have to buy new tubes since the ones I have only cover up to 25mm. Maybe if there are cheaper alternatives, wouldn't hurt if the tube is somewhat puncture resistant as well.
https://www.bicyclerollingresistance...pu-inner-tubes
Tubeless. But assuming you have non-TLR rims, another thing you may have missed is that riding wider tires is considered less flat-prone for most if you get a fast-rolling, supple tire run at lower pressure without significant (if any) loss to speed.
There are also new non-butyl inner tubes that are marketed as being more puncture-resistant while also adding less rolling resistance than the traditional butyl ones.
However, there are tubeless tires with extra layer of puncture protection so you're not just relying on the sealant to do their job but for the tire to also hold itself together in the worst possible puncture event, allowing you to fix the tire and continue back home. Tires like Gravelking slicks. Many actually find they roll decently fast and have excellent grip over paved roads ofc, not as fast as dedicated road or racing tires. Obviously, the puncture resist layer will add a bit to weight and rolling resistance. It all depends on your priorities. I'd definitely feel safer going down a hill at 50 mph knowing my tires will hold together.
To the topic: puncture resistant ... shoes. I've got 'em. Not great riding and they weigh a lot but if a fight breaks out after too many beers, really good for **** kicking! Steel toed work boots. Carolinas. All day comfortable. Good looking leather. Toe and sole completely resistant to glass, debris and goat heads.
I'd rather get puncture resistant tires and tire repair kit so you don't get flat and walk the way home in the first place.
Quoted: 4806 Post(s)
Liked 3,928 Times
Why would anyone want puncture resistant shoes? I suppose, if you get a flat, you can walk the remainder of the trip many miles on foot without fear of a broken glass or nails getting through the sole of your shoes.
Liked 4,846 Times
Rollingresistance.com does not rate Specialized Armadillos, which are Specialized's answer to Gatorskins and other puncture resistant tires. I wonder why. I ride them, and although they are a bit harsh, I haven't had any flats yet.
