Can I change to a flat handlebar?
Quoted: 35 Post(s)
Liked 47 Times
I'm just getting back into biking after 30+ years away.... Back in the old days, I had a 10-speed with racing style drop bars. A Sears "Ted Williams" model! I rode it a lot. Wish I'd had an odometer on it, it would have been a pretty good number.
Recently, I acquired a new bike, a 16-speed model which also comes with drop bars, Shimano Claris shifters, etc. The trouble is, I don't find the drop bars comfortable any more. Compounding the issue, I can't apply the brakes with my hands up on top of the bar, which is where I do all my riding. The Sears bike had a second lever on the brakes which were reached from on top of the bar, and that was the way I rode. I almost never used the drop position then and I don't use it now. I don't find it comfortable.
Can I buy a flat bar and swap the shifters over onto it? It looks like it'll work, but I notice the Claris shifters for sale on Amazon and on Shimano's website specifically mention different models for drop vs. flat bars. Am I missing something? There looks to be plenty of slack in the cables. Maybe TOO much. But surely I can absorb the excess to some extent. My current bar diameter is 25.4mm and there are plenty of flat bars available in that size. Can't I just untape and remove the Claris shifters and re-attach them to a flat bar, and adjust placement so its most comfortable? Or am I just not seeing some sort of stumbling block which makes this impossible?
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
What I would suggest is you work with someone on fitting your bike. that may involve raising the bars a little, maybe moving the saddle up a bit, or back, and checking the width of your bars. (it is a thing. When I bought my bike, I switched out the narrow drop bars with a slightly wider bar).
Second, you can add a second set of brake levers you can use when riding on the top of your bars.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 94 Post(s)
Liked 71 Times
It would be a pretty simple process with either bike you own. I made a video a couple of years ago converting an early 80's bike to a flat bar, or actually a riser bar set up. The shifters used would work with either 8 speed indexed or friction systems.
Likes For Le Mechanic:
Likes For BNSF:
Quoted: 1188 Post(s)
Liked 1,154 Times
Being 8 speed the swap is really easy. Easiest way would be to get some Claris ST-R240 flat bar combination brake and shifters in a 2x8. You'll need new brake cable inners with MTB cable ends on them. Gear cables can be re-used. Think about getting some flat bars with a few more hand positions like butterfly bars, Velo Orange Crazy bars, Jones Loop, Surly Moloko
Quoted: 35 Post(s)
Liked 47 Times
My hope was that my current road bike style combo brake and shifters would work, but if not I'm glad I asked first. So far so good, thanks everyone!
Quoted: 424 Post(s)
Liked 272 Times
It can be done, but maybe shouldn't be done, because of the cost of new bars, shifters and brake levers. And, not all mountain or flat bar brake levers and shifters are compatible with road brakes and derailleurs, so you need to know what you are doing.
sure it can be done with enough money. I just sold my commuter (Redux 2) flat bar bike to get a gravel bike ( Topstone ) with drop bars. You have to buy too many things for it to be cost effective.
Likes For sean.hwy:
Liked 208 Times
Or this. https://velo-orange.com/collections/...-bar-handlebar
Or this https://www.somafab.com/archives/pro...or-2-handlebar
Just MO, but honestly, I would urge you to try to make drop bars work.
Liked 208 Times
These are inline brake levers you can install on your current drop bars. They work way better than the old suicide levers. https://www.amazon.com/Tektro-RL720-.../dp/B0090X36Y0
Quoted: 35 Post(s)
Liked 47 Times
Hey now, that's pretty clever! Probably a wiser choice than my original idea. And it lets me ride with my hands where I am used to and not super wide (which probably would have been the case had I followed through with my original plan). Thanks!
Likes For BNSF:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Look up flopped and chopped bars that are popular in fixed gears. Basically you take the drop bars and mount them upside down so the hooks come up and back. you then hacksaw the hooks off leaving you with bullhorns that your brake/shifter levers will mount to.
https://bikerkits.com/bullhorn-handlebars/
Quoted: 1572 Post(s)
Liked 642 Times
A bicycle is a simple machine but the devil is in the details. Every part on a bicycle has to work with, and match, every other part. As you get into swapping your handlebar you will find yourself having to change a lot of parts.
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times
Mustache bars will work with road levers. https://www.ebay.com/itm/Bicycle-Mus...4383.l4275.c10
Liked 1,154 Times
if you did want to re use those, maybe butterfly bars would be best, you could arrange the levers on the curves on the bars to get clearance between the lever and the bar.
