Enve Road Fork Clearance
Old 09-27-20, 12:16 PM
3MTA3
My EC90 fork doesn’t have the clearance I need anymore. I have Hed Belgium+ rims and Specialized Turbo 26 tires fit just fine but GP4000s and Vitoria Corsa 25s don’t have enough clearance. (Both fit but they rub the fork in different situations.)
I’m considering an Enve road rim brake fork as a replacement. Do any of you have this Enve fork you could post a photo of with your tire setup? I would appreciate any input or other ideas.
Thanks.
3MTA3 is offline
Old 09-27-20, 01:13 PM
Dean V
Quoted: 1067 Post(s)
Liked 259 Times in 153 Posts
25mm GP4000 will fit but not a 28mm.
Dean V is offline
Old 09-27-20, 03:28 PM
3MTA3
I’m concerned about the wide rims, too. I’ve had GP4000 25s with narrow rims fit fine but not with the Belgium+ rims.
3MTA3 is offline
Old 09-27-20, 04:48 PM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
It depends where the tire has clearance issues. With my Colnago wider rims made the outside circumference less allowing 25mm tires to fit.
Atlas Shrugged is online now
Old 09-27-20, 06:32 PM
Bah Humbug
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
With my S1 I could fit 25mm GP5ks on Hed+ rims but only 23mm GP4ks. In my experience, the Hed+ over the Hed C2 made the tires go wider (obviously) but not taller.
Bah Humbug is offline
Old 09-28-20, 01:05 PM
3MTA3
The rubbing is happening on the sides of the fork, not the crown.
3MTA3 is offline
Old 09-28-20, 01:35 PM
Clipped_in
Rubber side down
Clipped_in's Avatar
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times in 105 Posts
OP I have an ENVE fork on a 2015 Cannondale Supersix HiMod frame. I ride HED Belgium+ rims with Conti GP5000 25mm. They fit fine and ride very well. 25mm Corsas and Michelins Power tires are too wide. You can probably keep your fork and just go with narrower tires. The GP5000's are a lot closer to the stated nominal tire width than most other tires.
Clipped_in is offline
Old 09-30-20, 12:40 PM
jrg1244
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times in 44 Posts
I ride an ENVE 2.0 rim brake fork using H+Son Archetype 700c rim (23mm wide) with Conti GP5000 28c tires. There's room to spare, fear not. On a sidenote, I love this fork! I should have bought it sooner.
jrg1244 is offline
Old 09-30-20, 03:23 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Liked 244 Times in 181 Posts
Thanks.
I think that's the fork I have and those are the rims I use. I've run Schwalbe Pro 25's regularly. I have the Vittoria Corsa Control 2.0 in 28c on there now and I've had the Schwalbe Pro1 28c on there but it was tight - those are pretty pudgy tires. Here are the measurement for some of the tires I have. The 28c Schwalbe worked but little rocks would get jammed in there. The 28C Vittoria's are what is on there now and have been for about 1000 miles. They seem to work well.
Tire Height Width
Schwalbe One 25mm 26mm 29mm
Schwalbe One 28mm 27mm 31mm
Vittoria Corsa 28mm 26mm 30mm
JohnJ80 is offline
Old 10-01-20, 10:03 AM
jrg1244
Quoted: 45 Post(s)
Here's a pic of the Enve 2.0 with Archetype and GP5000 28c tires. Hope it helps.
jrg1244 is offline
Old 10-15-20, 10:09 AM
3MTA3
I contacted Enve and they said the Belgium+/ Corsa 25 set up will work. If the Corsa tires are, in fact, too wide I’ll go back to Continental (even if they’re a huge pain to get on/ off). I ordered the fork thanks in part to these replies.
Thanks to everyone who replied.
3MTA3 is offline
Old 10-15-20, 12:54 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
thats should work just fine. I run the Belgium+ tubeless with the 28c version of that tire on that form so you’ll be just fine.
JohnJ80 is offline
