Vintage Jersey Lettering
Quoted: 1079 Post(s)
Liked 1,899 Times
I love 70's era jerseys with the embroidered lettering:
Does anyone know if there's a particular name for this type of embroidery or who does it?
Likes For P!N20:
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I think the true vintage jerseys had flocked letters, and this embroidery is an imitation of that (a pretty good imitation, but an imitation). A lot of fancy sewing machines can do embroidery like this, can't they?
(with apologies for not answering your question).
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
Liked 1,899 Times
Hmmm...not sure, I believe they co-existed. All I know is De Marchi did embroidered lettering back in the 70's and they were a top quality product.
Probably, but modern embroidery doesn't look like this in my experience. There's something rustic and tactile about that jersey lettering. Maybe it's just a setting on the sewing machine? Sewing isn't my area of expertise.
I think it might be called cornely or chainstitch.
It’s chain stitch. Been trying to find some one still doing it in the US but have only found a rodeo supply place in Wenatchee Wa. and have not been willing to send them a jersey for a trial. Reasonably common in Italy : I have seen it done on site at a vintage ride and outside a fabric shop. Just need the right machine, some artwork and a steady hand. Mastrofisso.com does it it Italy.
Likes For Mr. Spadoni:
Liked 1,899 Times
Quoted: 874 Post(s)
Liked 2,287 Times
A modern retro style jersey with sewn lettering. I also have vintage jerseys that are sewn in a similar way. My vintage ones are from the seventies.
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 149 Post(s)
Liked 366 Times
Check Oregon Cyclewear, they produce Merino Wool jerseys and work with a local vendor for custom lettering. Reasonable rates and quick service is what I experienced when I had a jersey made.
Likes For Markeologist:
Liked 1,899 Times
Yeah those jerseys look awesome. The trouble is, I live in Australia and postage from the US is usually astronomical - kinda ironic seeing that the wool comes from here! Doesn't look like they do the chain stitch though, which is my current obsession.
Quoted: 3015 Post(s)
Liked 3,802 Times
How about stomaching something from New Zealand - https://www.soigneur.co.nz/
Liked 1,899 Times
A modern multi head machine will given a super durable, multicolor design. Chain stitch does not hold up as well, is really hard to do in more than one color, but has a one of a kind look, because it is.
Sorry. Gotta set this straight. Yes, embroidery can be done with a home machine. It will give a result similar to chainstitch but a lot depends on the garment and how good the sewer is. Flocking came about as a cheaper alternative to embroidery. It’s usually a heat press process so it’s pretty simple to do.
multimodal commuter
Liked 574 Times
The kind of flocked letters I was thinking of are older, like a 40's - 50's, and the letters were individually stitched onto the jersey by hand.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 3,802 Times
Bartali 1933 by iabisdb, on Flickr
Cinelli 12 by iabisdb, on Flickr
Bizzi 07 by iabisdb, on Flickr
multimodal commuter
Liked 574 Times
^^Yeah, I can't tell exactly what that is, but I'm sure you're right. It doesn't look hand stitched on, not at all.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 3,802 Times
multimodal commuter
Liked 574 Times
I am fighting a very strong urge to start perusing old cycling photos on google images right now, to see if I can find the image I have in my mind. But alas I don't have time for this right now. Carry on!
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
Liked 3,802 Times
But the difference is that flocking with a whip stitch does not flex/stretch. Not important with an oversized jersey. It does matter with a form-fitting jersey. Chain embroidery stretches.
Likes For iab:
Quoted: 1639 Post(s)
Liked 829 Times
I think that term had mostly disappeared though......
Now, people just call them just "lettering" or "graphics", no matter how they are done.
Quoted: 1829 Post(s)
Liked 3,375 Times
for what it's worth... a early 70's Raleigh jersey with embroidered letters. The threads just go back and forth across the width of the lines that make up the letters.
for a high resolution version, go here: https://live.staticflickr.com/1471/2...1def4_3k_d.jpg
My other Raleigh jerseys use the flocking method. They are late 70's or early 80's.
Steve in Peoria
Steve in Peoria
Since I am explaining mode, and since I rarely get to talk about something I spent years doing, the letters that you are thinking of were usually die cut felt. Fancier ones had a background. As a kid, I could walk into the sporting goods store in my town and they had a wall filled with bins filled these letters. Nowadays, you can still get similar letters, usually in a twill fabric, heat or RF cut for a clean edge. I think, and a hockey player can set me straight, these are still used for name plates on jerseys( or sweaters if I happen to be speaking to a Canadian)
Quoted: 350 Post(s)
Liked 276 Times
Spectrum is OCW’s vendor. The shop does good work but like most embroidery shops, they don’t do chain stitch. Chain stitch is done on a specific type of sewing machine, sometimes called a Connelly, but made by others as well. One operator, one garment at a time. Most embroidery shops run multi head machines. Design is programmed in, the correct thread colors are set on the bobbin, and the operator can go on to the next job while the first one is running.
I spoke to the owner of Spectrum last year and she said that she cannot do chain stitch; however, she knows another local shop owner who did and that she could facilitate the needed chain stitch embroidery. An example can be seen on the Oregon Cyclewear old stuff page, the “Century America” jersey.
