Teflon tape for creaky BB?
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 520 Post(s)
Liked 10 Times
I still have the creaky BB issue often after a day or two after riding in the rain. A guy I ride with on the commute often suggested to use teflon tape on the BB cup threads. This sounded pretty good. I'm also wondering of I can wrap a thin piece of tape around the Octlink V1 splines as well. Anyone else use teflon tape for BB installation?
Quoted: 4788 Post(s)
Liked 3,909 Times
Teflon tape on the threads will only help. THere are no promises, but nothing gets worse and years from now you may be thanking yourself for the foresight. (Actually you won't. The BB will just unscrew like it should. It's when you don't use it and go years when you wish you had.)
I wouldn't put it on either the octalink splines or a square taper. Maybe the tape, then blue loctiting the bolt in place to get rid of the squeak, but I would want to know first that it was for sure the source of the squeak. (Maybe do the threads first, try it, if still a squeal, tape the spines, try it and remove the tape if that doesn't cure it? If it does locktite the bolt.)
Ben
Ben
Quoted: 1572 Post(s)
Liked 643 Times
That's typically a 30 ft/lb torque spec. That's more than I would use if I were left to my own judgement. You might be a better bike mechanic than me and not need a torque wrench. On the other hand, you're the one with the creaky bottom bracket.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Teflon tape probably works but I fixed a creak with grease on the BB threads of a cartridge BB. I think that was back in 2010 and it has never returned.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
i kinda doubt the BB itself is creaking... usually ends up being the taper that the crank seats on, or the screws/nuts that hold the chain rings onto the crank spider... or pedals.... or the seat, maybe? i've even heard of the seat CLAMP being the source of a "crank squeak".
Quoted: 2026 Post(s)
Liked 1,095 Times
Yeah, it's usually not the bottom bracket itself but the interface between its threaded cups and the bottom bracket shell. Copious grease or anti-seize along with proper installation torque usually keeps them quiet but I've also used teflon tape with great results.
No, I don't. might be the pedals .. riveted on plates ? A friend gave me his steel Campag pedals,
I banged the swaging more.
The Moose
Bikes: 2016 Giant Roam 2, 2004 Norco Torrent, 1969 Raleigh Grand Prix
Quoted: 108 Post(s)
Grease the bb threads and you should be golden for a good while. The creak is probably from a chainring bolt or some other component in the stack. You can use thread lock on bolts which helps reduce noises.
Quoted: 520 Post(s)
Liked 10 Times
^^ Grease was what I have been doing in the past. Although would be nice to have a more permanent solution since the creaky bike usually comes back after a rain or two. This morning I took off both crankarms and put a little grease on the Octlink splines. It didn't seem to help. So it seems that the creaking is coming from the BB lockrings. Will try to get some teflon tape on them soon. Might need to buy a small roll of it at the local hardware store.
Quoted: 520 Post(s)
Liked 10 Times
50voltphantom
Bicycle Mechanics
17
08-10-17 09:28 PM
jeven
Bicycle Mechanics
2
07-29-10 12:06 PM
