TRP Cable Pull Disc Brakes Surprisingly Good!
Did you need to do anything special during setup? That is typically a very problematic pairing of components. I designed short pull arms to be able to use HY/RD calipers with my Campy levers on my own bike. With the stock arms, the brake levers hit the bars before max force could be applied. The Spyre calipers have a similarly long pull actuation arm but the design is such that a shorter pull arm isn't easily swapped in.
Likes For joejack951:
TRP Spyke = Long Pull (mountain)
TRP Spyre = Short Pull (road)
Apparently, the best overall solution is Paul Klampers if you are running Campy levers. Paul makes a version of their actuating lever specifically for Campagnolo. Maybe some day I'll splurge and get a set, but at $500 for a set of Klamper calipers... I'll stick with the Spyres for now.
Quoted: 123 Post(s)
Liked 54 Times
I have to say that I am surprised to hear the love for these brakes. I have TRP Spyre-C brakes on a Salsa Vaya and have been pretty underwhelmed by them.
Maybe its me but I had been hoping/expecting for both more power and modulation from disk brakes but did not want the added hassle of hydraulic.
Suggestions for improvement (w/o going full replacement with hydraulic) that I am seeing in this thread are: 1. replace calipers w/ Yokozuna Ultimo, and 2. Try Deore XT rotor/Decathlon semi-metallic pads. Am I missing any??
Compression less housing may help, but I've never used spyre as I jumped from BB7 to juin tech.
Likes For katsup:
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I had my budget drop bar 29er built up with TRP Spyres that I had on my first cyclocross build. I've been using full hydros for over 2 years so I was concerned going back to mechanical. I FORGOT how good these brakes feel especially when paired with compression-less housing.
Likes For DarKris:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
I have a good exprerience with TRP Spyres and Sora 3503 3x9 levers. The only problem for me is some lack of stopping power during braking from the hoods. From the drops or from the tops (Tektro 721 cross levers) it is adequate. Here I have to admit being a heavy rider at 300#. Housing is compressionless Jagwire Road Pro, I can confirm that it makes a difference.
What do you think: is upgrading from Spyres or BB7s to a 4 piston caliper worth it? I have read that HY/RD is only marginally better than Spyre. In particular, do these 4-piston brakes give better stopping power? FWIW, the bike I have is QR, no thru axles. Yokozunas are $200+ for one caliper, not exactly cheap.
Not nearly as pricey as Yokozuna Ultimo
dvdslw if you’re having a hard time rationalizing an upgrade, I can help: the Yokozuno Ultimo lets you keep your DA levers, but the four-pot calipers improve power and modulation, but also look way sicker than either Spyre or HY/RD!
Quoted: 217 Post(s)
Liked 155 Times
I'm using Juin Tech R1 (2 piston) and paid $135 for the pair (pre covid) and both the bikes with the BB7 and with the Juin Tech are QR. I like the Juin Tech much more than the BB7 brakes. I am using normal cable housing and am much more confident in my braking. Compression less housing is due to go on once I unwrap the bars, but it may be awhile.
Yokozuna's price has some overhead for branding and it also includes their Reaction cable/compressionless housing. $450 for a pair of Ultimates comes close to the price of a hydraulic groupset...
Quoted: 2432 Post(s)
Liked 638 Times
I had Spyres on a first year Diverge and they were great. I have an '07 Cannondale F4 with BB5's and I actually love them. I like both of them more than the 105 hydraulics on my road bike. But on the other hand, the SLX hydraulics on my newest MTB are the best brakes I've ever owned.
Quoted: 1975 Post(s)
Liked 232 Times
Anyone else ever get water in them and have to replace the bearings? I had a pair for awhile that got crunchy over time wet commuting and decided to replace them with HY/RDs then full hydraulic but apparently they can be rebuilt
https://singletrackworld.com/forum/t...rebuild-guide/
Quoted: 624 Post(s)
Liked 396 Times
Reaction brake cable housing and they work great.
Quoted: 123 Post(s)
Liked 54 Times
I wasn’t crazy about them before.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I have TRP Spyres on one bike currently--love them. I live in a very steep area, and I have no complaints. I had some BB7s too in the past and was perfectly happy w them as well.
Quoted: 624 Post(s)
Liked 396 Times
TRP does have a great warranty service, they sent me a new set of HYRDs when one of my pistons got seized
Quoted: 427 Post(s)
Liked 339 Times
Quoted: 284 Post(s)
Liked 313 Times
Inspecting my brakes today (TRP Spyres) I'm about due for new pads. What pads do you folks recommend? What's on there now is what came stock with them on the bike. Have lasted quite a while actually, and it's steep here.
Likes For redlude97:
Quoted: 427 Post(s)
Liked 339 Times
Thanks! Looks like the price of R1's is the same now, dual piston GT is twice more expensive. Looks like I should also try R1 as people say that BB7 has a slightly better stopping power than TRP Spyre (and Spyre has a better modulation), and R1 is more powerful than BB7.
Quoted: 217 Post(s)
Liked 155 Times
Anyway, I can confirm that Juin Tech R1 is much stronger than TRP Spyres. After the upgrade I have the stopping power from the hoods I had been missing before. I am not saying that Spyres or BB7s are bad, for me some advantages of Juin Tech R1 are:
- Better stopping power, need it as a heavy rider.
- Hydraulic system will re-center automatically, very convenient for the QR wheels I have on the Double Cross.
- Adjustment for pad wear is done with one knob. With Spyres I had to drill a hole in the dork disk for the 3mm wrench to adjust the pads. Also, these adjustment screws would loosen, making me re-adjust them periodically. Purple Loctite (kind of) fixed this.
- Slightly shorter lever throw, easier to setup.
- No sophisticated mechanical parts which can be contaminated with dirt.
