Bertin C37 Reynolds 531 Campagnolo - need more info
Hey guys, look at my today's finding. Someone put fenders to this frame and straight handlebar probably not knowing much about frame. I'm intrested in every information you can give me about this model, year, original parts etc. I would also want to know something about L.JUY simplex sticker - never heard of those.
There is nervex stamp on bottom bracket with numbers like : 59'3064'D22E38 or 59'3064'B22E38 or 59'3064'B22838 ( some letters and numbers are so similar, but one of those 3 is totally correct )
Dropouts are marked brev. campagnolo as on the pictures.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
Likes For gugie:
Quoted: 3803 Post(s)
Liked 3,324 Times
the Verot model 63 chainset is a helpful dating aid as it enjoyed but a brief production life of roughly 1963-1967
the L. in the L.JUY marking is for Lucien, first name of Monsieur Juy, father of Simplex brand products
the long markings on the NERVEX bottom bracket shell are technical specifications and not a serial
bertinjim shall be along shortly to give you far more and better information on the cycle
verktyg
Quoted: 1036 Post(s)
Liked 1,237 Times
1960's Bertin C37
Very early Bertin ads from 1960's Ron Kitching catalogs. Note - they didn't show Campy dropouts on these frames. That could be do to using old printing plates for years. Printing catalogs was very expensive before the days of desk top publishing.
Photos of an original Bertin C37 frame from ~1963-64??? that I pulled off of the internet years ago. Note the # 62 on the NDS dropout is the frame size C-t-T - 62cm - not the year. Bertin made a lot of bikes/frames to order not to catalog specs that's why you see do many variations. Chrome plating was probably one of those options.
Terzot Your frame is probably a 1965-67 Bertin C37 model. It could have originally been equipped with Simplex, Campagnolo or even Huret derailleurs.
The French thought highly of Huret Alvit derailleurs and even used them on some top of the line bikes. They were the French idea of all metal derailleurs to compete against Campagnolo (as opposed to Simplex Delrin Plastic derailleurs - at least in their minds).
WORD OF CAUTION! That stem is awfully high. I recommend pulling the fork and checking the threads on the steerer. When a stem is expanded in the threaded area, it can cause the threads to bulge leading to a catastrophic failure! Also many bike manufacturers used cheap steerers sometimes made of seamed pipe with a sleeve brazed into the bottom. Peugeot and Motobecane were some of the biggest offenders but Raleigh did it too. Saved a few pennies and centimes!
Removing all of the extraneous merde-de-velo plus some elbow grease, cleaning and polishing, and voilà the frame will look a 1000 times better.
If you're planning on doing a restoration, you can probably get those olde French Reynolds decals from H. LLoyds in the UK.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Liked 3,324 Times
forward pump peg is NERVEX item Ref. 845
rear peg for AD HOC is NERVEX item Ref. 846
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Very nice for a pre-boom bike discovered in the wild!
Genesis 49:16-17
Genesis 49:16-17
verktyg
Liked 1,237 Times
Rust!
I feel ill (for you)
Rust like that on the seat tube could indicate it's toast! Ferric Carcinoma...
My late 60's early 70's, 57cm Bertin C37. My legs have shrunk so it's on my list of bikes that I don't ride any more and it's going be "moving on". NO RUST...
verktyg
verktyg
Chas. ;-)
Chas. ;-)
I know there's some rust, but for sunday rides i think it won't change anything. We'll see . I'm considering also full renovation, but it would require a lot of time, which i recently don't have . Thanks all for answers!
Quoted: 5888 Post(s)
Liked 3,471 Times
that bike is hot.
WGB
Bikes: Panasonic PT-4500
Quoted: 1794 Post(s)
Liked 2,328 Times
