Go Back  Bike Forums > Bike Forums > BMX
Dia Compe 1080 specs
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Old 09-30-09, 11:59 AM
zhooker
Having trouble finding a front brake (one that is side pull, not center pull) for the frame/wheel combo on my fixed gear. looking at BMX brakes.
Can anyone get me the RANGE/REACH (min and mix) of the pads on the Dia Compe 1080. I think I saw the max is 105mm, but I need the MINIMUM.
Or, if you can recommend a brake that will reach approximately 62mm (ish), please do recommend!!!
thanks
zach
zhooker is offline
Old 09-30-09, 05:38 PM
fuzzbox
Your imaginary friend.
fuzzbox's Avatar
Bikes: A sweet Quamen ATL custom, GT Mach 2
This is bmx not fixed gear roadie bikes take your problems elsewhere.
Every passing minute is another chance to turn it all around.
fuzzbox is offline
Old 10-01-09, 12:23 AM
FuzzyRyder
Live To Ride Ride To Live
FuzzyRyder's Avatar
Bikes: Fit flow
Why do you feel the need to be so rude with all your replies? Just because he doesn't ride a bmx, who cares? Anyways, i am not really sure, but i can't see there being a real serious issue other then the fact that a bmx specific brake will probably look rather bulky on a road bike.
BMX For Life
FuzzyRyder is offline
Old 10-01-09, 11:11 AM
Street rider
We win all charity rides
Street rider's Avatar
Bikes: BMX, fixed gear
Why not use a v-brake? it would give you more stopping power, and it would fit your frame...I don't think u-brakes would fit a road/fixie frame would they?
Street rider is offline
Old 10-01-09, 12:08 PM
Kodyo
If the reach isn't small enough, couldn't you file down the inside of the brakes where the pad goes with a dremel?
What do you need the reach to be?
Kodyo is offline
Old 10-02-09, 02:57 PM
FuzzyRyder
FuzzyRyder's Avatar
Bikes: Fit flow
He is using a caliper. there is no brake posts, and u brake mounts aren't compatible with v brakes anyway.
BMX For Life
Old 10-02-09, 08:18 PM
tyler11
tyler11's Avatar
one company makes an adapter that you bolt into the caliper hole and it turns that into u or v brake mounts
tyler11 is offline
Old 10-02-09, 11:50 PM
Kodyo
U brake
https://www.danscomp.com/489057.php?cat=PARTS
V brake
https://www.danscomp.com/489051.php?cat=PARTS
Kodyo is offline
Old 10-04-09, 05:14 PM
Street rider
That's what i was thinking of. My bad for not putting that part in too.
