12-speed Chainring & 8-speed chain?
SRAM Eagle X-SYNC 2 Chainring - 38t, 104 BCD, steel. 12-speed
Above chainring is available at a relatively low price.
Will it work well with an 8-speed chain, say SRAM PC830?
Single chainring, up-front.
Two possibilities at the rear.
1. Single 3/32” cog
2. 8-speed cassette
1. Single 3/32” cog
2. 8-speed cassette
Liked 2,968 Times
no. it could cause the chain to be thrown off/jam.
-Oh Hey!
-Oh Hey!
Liked 2,968 Times
You'd likely have chain slip as the 12 speed chain will not properly seat when used with am eight speed cassette.
-Oh Hey!
-Oh Hey!
Quoted: 1943 Post(s)
Liked 2,164 Times
You can use an 8 speed chain with a 12 speed spec’d, well technically it is one speed, chainring.
I have not measured the inner width of different speed chains but it is really the inner width you want to be concerned about running a 3/32 rear cog.
Depending on the site, derailleur chains through 8 speed have a 3/32 inner width. 9 through 11 are 11/128, although I’m not sure that all 9’s have a narrower inner width. Not sure about 12 speed.
John
John
Liked 2,968 Times
IME with Shimano stuff: the 8 speed cogs are slightly thicker than the 12sp cogs.
-Oh Hey!
-Oh Hey!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,466 Times
Using an 8 speed chain with a 12 speed chain ring (as anga proposed) should work as there is no front shifting and, as Troul mentioned, the 8 speed chain is wider than the 12 speed chain ring, so the two fit.
Theoretically, using a chain that is wider than the chain ring may allow some side-to-side play which may increase wear, but that is offset by using a steel chain ring.
Best practice (for a 1X and clutchless RD setup) would include a chain guide; I use this: Amazon.com : CyclingDeal Mountain MTB Road Bike Bicycle Chain Guide - Chain Drop Catcher - Chain Clamp Guard - Single Chain Guide - Size 31.8mm & 34.9mm : Sports & Outdoors
Quoted: 514 Post(s)
Liked 448 Times
A wide chain on a narrow cog might be noisy and might lead to excess wear on both the ring and the chain, but technically it should work. I never tried it. I would probably use this a temporary kludge but plan to replace it eventually with the correct ring.
