What did you just buy for your gravel bike?
#1051
Quoted: 8 Post(s)
Liked 10 Times
Just pickup up an Ibis hakka, and took it out for the maiden voyage today! Before the bike even arrived I ordered a set of Industry 9 GRC X wheels with WTB Raddler tires. The 1/1 hubs sound amazing and have great engagement. Not quite as good as the I9 Hydra hubs on my mountain bike, but still pretty solid!
#1052
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Did the same a few weeks ago. It works well!
Don't complain about the weather and cower in fear. It's all good weather. Just different.
Likes For ToppDogg:
#1054
Bikes: 2022 Cervelo Caledonia -- 2022 Surly Ghost Grappler
Quoted: 27 Post(s)
Liked 49 Times
Just got a Surly Ghost Grappler, switched the tires to Super Moto X, strapped on a few bags and went on an overnight trip 50 miles out and back. This thing is a lot of fun and easy to strap stuff to. I topped out (spun out) with the gears a few times already but weight was low. I'll wait until she's fully loaded up before making changes.
Likes For 1sp33d:
#1055
Bought this 2022 Diverge last fall. OEM components were standard crabon gravel bike fare - hydro brifters, 1x, riser bar, etc.
I bought some new parts and here is the current set-up.
* ENE Ciclo Grand Compe bar ends fitted with a Jtek Shiftmate 8 on the RD side so that I can clear all 11 cogs on the cassette.
* Ritchey Comp Beacon bar
* 70mm x 35* stem
* Deity Bladerunner pedals
* 38/24 SRAM 10 speed crank
* SRAM GX 2x11 RD
* SRAM Rival Yaw FD
* SKS Bluemels fenders
* Swift Industries Catalyst bar bag
Took it for a spin a couple days ago and it feels so much more dialed now as compared to OEM.
Next up will be a set of Mason Hunt 650b wheels and 50mm+ wide tires
* 70mm x 35* stem
* SRAM GX 2x11 RD
* SRAM Rival Yaw FD
Likes For jlaw:
#1056
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
^ gets the award for most creative and non-stock build of the year. Dont care that its only Feburary- doubtful anything will come close.
Likes For mstateglfr:
#1057
Quoted: 5223 Post(s)
Liked 3,579 Times
#1058
El Rayo X
Quoted: 7 Post(s)
Liked 36 Times
* 70mm x 35* stem
* SRAM GX 2x11 RD
* SRAM Rival Yaw FD
* 70mm x 35* stem
* SRAM GX 2x11 RD
* SRAM Rival Yaw FD
Likes For jonathanf2:
#1060
It was a milestone birthday purchase and I want it to be just the way I like - which is a little quirky by current industry standards.
#1061
It's called the 'Ultralight Bike Mirror' - made by the same company that makes Tubus racks and Ortlieb bags. See it here:
https://www.modernbike.com/ortlieb-u...nd-bike-mirror
$30. Not cheap, but it works well for me. I mount it in a location where it doesn't interfere when riding the drops. A vertical orientation gives a decent rear view. It is convex and that takes a little getting used to. Adjusted correctly, I can see rearward when riding the tops, hoods, and drops.
it's light enough that even though the band attachment to the bar is a little weak it doesn't move much. Some electrical tape would make it rock solid. The knuckle joint on the back of the mirror is robust.
The best drop bar mirror currently available IMO.
#1062
Pedalin' Erry Day
This is a neat decision and I also like your build overall. As a question/suggestion, could you run that shiftmate as an inline adapter somewhere on the housing before it enters the headtube (to get it out of the way of your fingers), or does it have to butt up against the shifter mount since it needs a solid stop?
#1063
I ordered the Shiftmate from SJS Cycles in England - took about 10 days to receive. If you have questions they are pretty quick to reply to an email.
The Shiftmate 8 allows the ENE Ciclo bar end shifter to just clear 11 cogs - not sure that this would clear 12. The Shiftmate 6 model will give more boost to cable pull ratio and would likely clear 12 cogs. Ask SJS.
Likes For LS1BadBird:
#1065
Quoted: 8 Post(s)
Liked 10 Times
Got a handful of goodies that I bought for myself or got for my birthday, with at least one more on the way that was backordered 😉
Whisky carbon fiber Seatpost
Whisky stem
PNW components 48 drop bars
Supacaz bar tap
Dark Speed Works bag
On the way is a Wolf's Tooth ring gear.
Whisky stem
Supacaz bar tap
#1066
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
another bike to train and eat winter grim instead of damaging the nice bites on the carbon bike.... and a set of garmin powermeter rally pedals.
Likes For Fentuz:
Likes For rivers:
#1069
The Shiftmate could be placed in-line prior to the frame entry port at a break-point on the housing. This model of Shiftmate is meant to be installed in a straight run of housing. Other models have a 90* bend and are normally located adjacent to the rear derailleur.
#1070
Roam v2.
Soon, the Assioma Duo. Will switch in Bontrager Comp pedals.
Have taken on a cycling coach for a first race in 10 weeks.
#1071
Sunshine
Liked 7,473 Times
#1072
Bikes: Two Independent Fabrications, a Niner RLT, and a Trek Domane
Quoted: 10 Post(s)
Liked 16 Times
You can't go wrong with I9 hubs. I have two sets of hydras laced up to ENVE rims. I can swap wheelsets and not even touch the rear derailleur.
#1073
Quoted: 286 Post(s)
Liked 100 Times
Vittoria Terreno Mix G2.0 Tubeless TNT Gravel Tire, 700x38. Not interested in changing tires for conditions, and their Mix are great as a Jack of all trades. Plus, they were on sale for $39/ea. I've ridden Vittorias for many years as touring and all purpose tires. Like them a lot.
Likes For revcp:
#1074
Fat n slow
Quoted: 3254 Post(s)
Liked 2,081 Times
Ordered some Tufo Thundero 40s. They’re still being shipped but at 38 a piece it was hard to pass up given the reviews
#1075
Mason Hunt 650b Adventure Sport wheels and Continental Race King Protection tires (27.5 x 2.2) - mounted tubeless.
I'm ready for that spring gravel!! (Although being 'mud season' around here some roads are a definite no-go).
