What Sort of Gearing Works Best for your Needs?
#276
Maybe.
It's not like I'm forced to use the interleaves; they're just there when I want tight shifts, which most of the time is in circumstances where a double-shift isn't clumsy to employ.
It's worth emphasizing that the middle/big front shifts are a lot snappier and less disruptive than on modern wide doubles due to the relatively tight front ratio. So much so that sometimes, when I want a shift that's a little bigger than a 1-cog rear shift, I'll sometimes flick the front shifter instead of using a rear shift.
A multi-range non-interleaved setup with similarly-effective ratio placement and overall range is surprisingly hard to create. Modern doubles have to use quite wide-ratio cassettes to achieve similar range, even in 12-speed.
#277
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
There is one thing about this though..........in both bikes and running, cadence tends towards some kind of "norm" or bell curve if you will of folks who cycle or run "really well".
Having the ability in running to have a littler higher cadence allows you to vary your gait less when encountering hills or needed changes to maintain your run power. If you can run at 180 spm then you can vary that an easy 20 or 30 either direction and not change your gait too much. If you run a really slow novice like 100, you don't have as much ability to do so and will have to change your gait a lot more.
I tend to believe the bike cadence norm of "90" comes from half of the normative "performance" run cadence of 180. And follows for harder efforts often to be more spm or cadence and easier ones lower.
We chased things to hunt/eat for a long long time, so figure our bodies adapted to optimize that. Folks who ran better ate better and survived to reproduce. A bike cadence is half because a cycle is left AND right. Running spm is each foot strike.
Run fast to chase your food ----> 180 spm -----> pedaling a bike divided by 2 -----> 90.
Personally I'd argue lots of folks have a mental block going to a compact crank because of some macho thing going on. "Real men ride a full size crank". So they freaking mash the daylights out of totally ridiculous gearing.
Also, good luck with loving that 11 cog so much. Trackies run more teeth front and rear for this reason. You can also have a nicer gear spread with more teeth than fewer for a given speed. 11 teeth is about the least efficient tooth count out there excluding the novel idiocy of axs 10 tooth cogs.
Cadence variability is a talent, one that is part natural and part worked on. Having it provides lots of capability on the bike to immediately adjust to environmental or race demands. Being at 60rpm in an 11t doesn't really provide the same level of immediate speed adjustment.
#278
#279
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
I am 6'5 210# and went from 24.9 old BMI to 23.15 new BMI.
I always thought me being right on the absolute edge of being categorized as overweight is a bit nut at my current weight, but really dont think much of it. I mostly dismiss that BMI metric as pretty worthless, actually.
While I 100% could improve on my fitness and get stronger while also reducing fat, its tough for me to view myself as actually overweight at this weight. So the new calculation tracks in this case.
...or maybe its just an adjustment to make everyone feel slightly better.
#280
Newbie racer
Liked 1,569 Times
1rpm change at 60rpm in 53/11 is about 0.6 mph
1rpm change at 92rpm in 50/16 is about 0.25 mph
That's just how gearing works.
#281
Quoted: 3942 Post(s)
Liked 7,284 Times
#283
Liked 7,284 Times
#284
But either way, that doesn't answer my question regarding livedarklions' cadence range.
#285
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
There are plenty of guys out there who can mash, but they simply produce more power at a higher cadence, so that's what they ride. Track cyclists would be the obvious example. All I meant about your inability to spin is that you said that for you it results in less power, so therefore your torque must drop off rapidly with cadence. If your joints are fine and you enjoy it then it's all good. It's like running an IC engine in a very high gear at a very low engine speed. The torque puts a lot of stress on the rods and bearings. Which reminds me of another thing with gearing - acceleration. A lower gear allows faster acceleration until you spin it out. Torque at the rear hub is proportionally higher in a lower gear for a given crank torque. Again as it is with cars. But you need a decent range of cadence to take advantage of it.
Like I said above, I start by spinning a relatively low gear, then rapidly shifting up. My acceleration is very good, as are my rods and bearings, which are quite intact and pain free.
I don't know why you feel a need to keep explaining to me that what I do is unusual, that's been my premise all along. Basically, this all started with me commiserating that buying new bikes with high gearing is getting extremely difficult.
#286
Tragically Ignorant
Liked 9,098 Times
In this example (presumably assuming a typical 700c road setup), 60->61rpm is somewhere around .36 mph, not .6mph. Also, gearing math requires consideration to proportionality: changing by 1rpm at 60rpm is arguably more like changing by 1.53rpm at 92rpm than 1rpm at 92rpm.
His reasoning was so specious overall, I barely managed to read through it.
Nothing like getting wished "good luck" for something I've been doing successfully for years.
#287
Newbie racer
Liked 1,569 Times
I'm not arguing you can't have any range you want, I'm arguing the effectiveness of such a gearing choice in a practical nature. Folks can pedal from anything over zero to whatever if they want to.
It's simply not as effective to try to vary cadence to vary speed at a really low cadence versus a higher one.
My argument about cadence talent is that if you're at 90, if you have the talent, can vary that from 70 to 110 probably pretty well. If you're starting at 60 can you in good faith argue that person can vary that cadence in an effective manner (not forcing it) by the same 40rpm spread?
You can argue the person starting at 90 could be 60 to 110 if including standing on a climb. So 30rpm under 60 is 30. C'mon, can you in good faith argue that? 30?
#288
Likes For HTupolev:
#289
Quoted: 2333 Post(s)
Liked 2,097 Times
My preferred cadence depends on power and varies from 68-72 rpm at randonneuring speed to 92-94 RPM at TT efforts.
I run a 56/39 rings with 11,12,13,14,15,17,19,22,25,28,32 cassette
#290
Tragically Ignorant
Liked 9,098 Times
The math was wrong (looked at wrong row in sheet), but you effectively proved my point in the yellow I changed in your quote.
I'm not saying this makes me equivalent to the fastest cyclists out there, it does however seem to make me the fastest cyclist I'm capable of being.
I'd comment more about my range, but since I don't measure it, I don't have any real numbers. But why are you assuming that my range is bell shaped curve? It could easily have a much longer right-hand tail than left. You're making a bunch of assertions based specious assumptions. But hey, 90 is half of 180 must mean something, right?
#291
Tragically Ignorant
Liked 9,098 Times
Based on what you wrote below, I don't think you understood the yellow.
You wouldn't need to. A 40rpm spread at 90rpm is comparable to a 26.7rpm spread at 60rpm, namely 46.7rpm to 73.3rpm. And similarly...
90rpm->60rpm is comparable to 60rpm->40rpm, not 60rpm->30rpm.
If someone is actually effective cruising the flats at 60rpm, then using my modified ranges, sure, I don't see why it's a crazy position. Highly unusual, but not obvious-on-its-face ridiculous.
More to the point, if my normal cadence is about 60 RPM, why would I need to go down to 40? My variability could be to go above and not below my normal.
#292
Newbie racer
Liked 1,569 Times
Get is to argue the outlier for fun instead of writing it off as the not very useful datapoint.
Apply this same concept to run cadence and it gets a bit silly. Go try to run at 80 spm. You look like a long jumper striding to the sand pit.
I’m done taking the troll bait on this one. Mash away. But if we ever go on a run I expect no less than a half marathon worth of long jump strides to go with the 40rpm bike cadence. If they manage it, we need video as that’ll be an internet sensation.
#293
Tragically Ignorant
Liked 9,098 Times
Fair for converting 60 to 40. But my personal opinion is that since this is BF, you can’t discount folks posting stuff like LDL just to rattle the cage.
You do get that gearing is not a thing that exists in running, right? Draw all the stupid analogies you want, I'm not lying.
And I've still got no idea why you think riding at 60 rpm requires me to ride at 40 rpm.
#294
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
Hey, livedarklions - I'd actually like to see how you gear your bike(s) (I thought that's what this thread was about). For example, do you put on a 55t or 56t big ring (like were used on 650C wheeled triathlon bikes long ago to offset the smaller wheel size, and can you even get those big rings these days or have 10t and 11t cassette cogs essentially made them obsolete)? Do you put on a straight block cassette (can you even get those these days or do you have to "build your own")?
The next club ride on a flat course, I think I'll spin on my 13-18 straight block freewheel
#295
Yes, but this isn't analogous. Running largely doesn't employ gearing, so the idea of maintaining power output while using a slower stride at higher force simply doesn't make any sense. In running, if your drive foot is actuated more slowly relative to your upper body, it means you're moving slower and (if conditions are equal) producing less power. On a bicycle, the relationship of torque and cadence is tunable: if a rider's legs are uncomfortable pedaling rapidly but can push with enormous force, they can select a higher gear than a more typical rider would choose; their resulting pedal stroke would be unusually slow, but otherwise need not be kinematically-whacky in the way that super-low-cadence running would be.
Likes For HTupolev:
#296
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
#297
Tragically Ignorant
Liked 9,098 Times
#298
Tragically Ignorant
Liked 9,098 Times
The two bikes I do most of my riding on are old brifter bikes with 8 speed Shimano 600 Tricolor, and I have 11-28t cassettes, standard issue Shimano. It's 53t in the front, and I forget the size of the small chain ring. I don't think my front derailleurs could handle a bigger chain ring, but I've never actually looked into it.
I do think that people are probably too reluctant to experiment with higher gears because of people claiming certain things are impossible or making grossly exaggerated claims of danger.
#299
Tragically Ignorant
Liked 9,098 Times
I get this nonsense a lot from people like burnthesheep who can't get their minds around someone doing something they can't. All he had to do to make it implausible was to ignore the fact that I'm on an actual bicycle with adjustable gears.
Next, someone will argue that my knees will explode or something.
#300
Quoted: 338 Post(s)
Liked 408 Times
Do you actually measure cadence using a device or no? Self reported cadence without measurement can be quite a bit off. It is like when people talk about power but don't measure it 🤷
Left to their own devices, the legs do some sort of resistance matching. If I'm riding easy my cadence will always be lower because it just feels natural. 60 rpm at 110% of FTP is a miserable experience, but 60 rpm at 60-65% of FTP feels perfectly natural.
Some people train low cadence on purpose, too. My wife's triathlon coach had her do loads of low cadence drills (it's somewhat popular in triathlon, idea is it improves the run I think). So we're on a training ride together, riding at same speed and similar power, same 11-30 cassette and I'm on 50-34 chainrings and she on a 55-42 with a 15 rpm lower cadence. It's trainable, although I don't see why you would.
