Campagnolo derailleur misaligned on two cassettes
Old 12-22-21, 06:49 PM
dvizz
Bikes: Wilier GTR SL, Wilier Jena Hybrid ebike, Cannondale Scalpel
Quoted: 9 Post(s)
I have two wheelsets. One with a Campagnolo Chorus 11-29 on a Campagnolo Zonda and a Chorus 11-32 on a Bora Ultra. I like to swap the wheelsets out to keep the Boras from getting gritty winter usage. When I install the Zondas the chain will hesitate dropping down to the middle cassette rings whereas on the Bora cassette all the down shifts are smooth. I loosen the cable knurled knob a half a turn and that remedies the hesitation. I'm wondering why the cassettes have this bias, I checked the spacers between the cassette sections and they are per spec.
dvizz is offline
Old 12-22-21, 06:55 PM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 741 Times in 421 Posts
This is normal
trailangel is offline
Old 12-22-21, 07:04 PM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Your thread title should be reversed: "Two cassettes misaligned on Campagnolo derailleur"
The RD is attached to the dropout. If the cassette on each wheel is the same distance from the dropout, & thus the RD, they will shift the same.
The trick is to shim between the freehub body and the back of the cassette so that the small cog is the same distance from the axle locknut (or equivalent) on both wheels.
This can be done with shims cut with knife or scissors from beer cans- about 1mm.
woodcraft is offline
Likes For woodcraft:
Old 12-22-21, 07:22 PM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
the problem isn’t the cassettes - it’s the hubs. Ideally, all Campag hubs would be seamlessly interchangeable, but this isn’t always the case. In your case, it seems like the Zonda hub is placing the cassette slightly “outboard” compared to the Bora hub, so you’re having to slacken off the RD cable a smidge (ie moving the RD out a bit) to bring the Bora-adjusted shifting in line with the Zonda-located cassette. A spacer behind the Bora cassette would solve the issue by placing both cassettes in an identical position wrt the RD. The actual thickness of the spacer is a matter of trial and error, but once you’ve nailed it down, adjusting the shifting for one hub will translate perfectly to the other hub. Use that spacer every time you install a cassette on the Bora and you should be able to swap between the Bora and Zonda without having to adjust anything.
Litespud is offline
Likes For Litespud:
Old 12-23-21, 01:39 PM
TiHabanero
Quoted: 1726 Post(s)
Liked 1,350 Times in 705 Posts
For what its worth I have found this issue within brand using Shimano hubs. When a customer asks about a second wheelset, I always recommend using the same hub for a second wheelset as it will minimize compatibility issues.
TiHabanero is offline
