Cassette Size
Quoted: 25 Post(s)
Cassette Size
Can I replace a 10 speed 11-28 with a 10 speed 12-27? My goal would be to do this without replacing the chain or chainrings because those are fairly new. I would assume the rear derailleur would need adjustment.
Quoted: 4200 Post(s)
Liked 3,853 Times
Yes, but assume the chain will need replacement too as chains and cog sets both wear with use. Also always check der adjustment when any gear system part is replaced. Andy
AndrewRStewart
AndrewRStewart
Quoted: 836 Post(s)
Liked 1,061 Times
Yes, it shouldn't need any other changes but there is a small chance the new cassette doesn't sit exactly the same distance from the hub so may need some minor limit screw and cable adjustment. Also possibly a B-tension screw adjustment but not likely.
Really Old Senior Member
There's a very good chance you may only need a click or 3 on the barrel adjuster.
Quoted: 18372 Post(s)
Liked 4,507 Times
Measure your chain with a tape measure or ruler.
If it is exactly 1/2" per link (12" per 24 links), then you are fine. If it is stretched, I'd go ahead and replace he chain too.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Fairly new doesn't really tell the story. Measuring the elongation does tell whether the chain should require replacing. 12" pin-to-pin. Greater than 1/16" elongation?
Quoted: 2026 Post(s)
Liked 1,096 Times
The switch should need only the most minor limit screw and cable tension changes at most. But tell me, where did you get a 12x27 10-speed cassette? That was my favorite combination for years but they seem to have completely disappeared. I can find 12x28 and 12x30 but they both miss the 16T cog the 12x27 has.
