BMX Sprocket with 11 spd Narrow wide teeth
I need to run a smaller chainring on my 1x11 setup to help with my chainline, is there any 11 speed chainrings that I can mount to a BMX crank, or any cheap alternatives like that?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You have provided exactly zero useful information to help figure out your issue. Try again...with some details about what you're working with.
Likes For cxwrench:
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
You want to mount a 1x chainring to the inside of your crank spider? Sure, there's a bunch of narrow-wide 1x rings you could get, but you need to know the BCD (bolt circle diameter) measurements of the spider. Or do you have a BMX crankset with a splined interface? We definitely need more info.
