Is chain waxing worth the time and expense?
Likes For Kontact:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,461 Times
I wax my chains. It's a lot less work, but it requires a system to be less work. Building up that system is somewhat expensive (not really) and tedious, but once I got mine done it cut my workload to a fraction of what it was.
The system requires a slow cooker, some sort of chain sorting system so you don't mix chains between bikes, multiple chains per bike, connex quick links and some tools (hooks made of spokes, pliers, quick link pliers etc.)
I have three bikes in active rotation, four in the defrosted months. My wife has three bikes in active rotation and I maintain all of them.
Quoted: 4221 Post(s)
Liked 2,943 Times
If you mainly ride on a trainer indoors and have cats that are jealous of the amount of time you spend on the bike (and show it by rubbing up against the bike whenever you are nearby or on the bike), yes, absolutely. 100%. If that doesn't describe you, I don't know. You'll have to figure that out for yourself.
Quoted: 1163 Post(s)
Liked 441 Times
While I am very diligent and meticulous at cleaning and maintaining my bike I lubricate my chain with the traditional squirt bottle. I have seen the waxing and hot-wax discussions but is seems like overkill to me. I have tried 3-4 various chain lube products and they perform well in my opinion. I don’t want to get into product promotions or brand loyalty on this thread.
But, is there any advantage to waxing bike chains?
Likes For masi61:
Quoted: 3489 Post(s)
Liked 2,906 Times
ignominious poltroon
Quoted: 2222 Post(s)
Liked 3,407 Times
i.e., a chain oiled with wax.
Likes For Polaris OBark:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Softens it. The “wax” most people use is candle or canning wax. Both are “hard” waxes which means they are rather inflexible and mostly just break off. A “soft wax” is more flexible. Petroleum jelly is probably the most common soft wax that people have experience with in addition to factory wax lubricant. Both would soften a hard wax because they form a solution with hard wax which changes the properties of the hard wax.
Stuart Black
Stuart Black
Liked 4,201 Times
Band saw blades as well. These guys make waxes for chains in various applications, especially dusty conditions. This company talks about the lubricating functions of wax as well.
Frankly, the distinction between “oil” and “wax” is a bit nebulous. They are both part of a homologous series with similar properties but different molecular weights.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,201 Times
Oil is used because it flows. If you put it on and wipe off the “excess”, there is still oil inside the chain. Moving the chain or even just letting it stand, allows the oil to migrate to the outside where you have to wipe off the excess. Rinse and repeat ad infinitum. There is no such thing as a “properly oiled chain” that doesn’t have oil on the outside and that translates into a black gunky chain which leave black gunk everywhere.
How often do you clean your “properly oiled chain”? My pictures above were for chains that were in the middle of their service duty. They are clean and the chain can be handled without getting gunk all over everywhere. I only need to clean the chain once. I seldom need to clean the rest of the drivetrain at all. I’ve used oil in the past. I have never experienced an oiled chain that is “clean” and I have handled tens of thousands of oiled chains.
Stuart Black
Stuart Black
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
I use a method that was explained years ago by a guy named Garth on the old Bicycling forum.
I clean a new chain in oderless mineral spirits
heat in a tin pan in a 200 degree oven
Sprinkle with powdered graphite (optional)
Rub with a votive candle (or whatever solid wax you prefer)
Turn it over and repeat.
One last bake for 5 minutes or so
Let cool, flex over the pan to remove the excess wax and put back on the bike.
I generally go 700-1K miles between treatments
My drivetrain and hands stay as clean as in the post by Cyccomute above (actually my hands stay cleaner because I use nitrile gloves when working on my bike or changing a flat on the road).
Don't have to deal with a pot of melted wax or dripping chains.
Liked 1,461 Times
Liked 3,407 Times
Yes.
You might be better off mixing in some mineral spirits. I found that softens the wax without making it more tacky. Basically, you are adding some lower melting-point, lower molecular weight wax molecules to the mixture. I also found I had to reapply more often.
Liked 4,201 Times
Petroleum jelly (e.g. Vaseline) and factory lubricant are both tacky (i.e., exhibit mild adhesiveness). So if I soften canning wax (or any other high purity paraffin wax) by mixing in some factory lube, would the resulting wax also be more tacky and thus pick up more debris?
Stuart Black
Stuart Black
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
Likes For dedhed:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
The bandsaw I used was lubed with antifreeze.
Quoted: 1079 Post(s)
Liked 1,017 Times
OP, I used wax for a short period on my road bike and seemed to have to wax every other day or the chain sounded dry and squeaky, even had the noise start same day it was waxed after riding 75 miles. Not good when multiple people get annoyed enough with the sound that they offer the shop tech that fixes their bikes, lube so he can fix his own. But the newerwaxes seem a lot better and I will be starting to wax my kids' track bikes since those don't experience rain, snow or mud and if they hold up well I might experiment with the road bikes. Honestly I'm lazy and I keep a small bottle of prolink lube and some rags in my car. If I notice a chain seems dry or poorly lubed I'll give the pedals a spin while dripping lube on the chain, let it sit a moment and then hold a rag to the chain while spinning the pedals till everything looks clean. Doesn't seem to make a mess or drip anything all over, but not a long process
Likes For Russ Roth:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
People have written walls and walls of prose about how it’s a waste of time
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 4,201 Times
The bandsaw I used in the staff shop at work wasn’t small. We used wax sticks like this. Cut aluminum, steel, and plastic.
Stuart Black
Stuart Black
Quoted: 2332 Post(s)
Liked 2,097 Times
Front chain has 800 miles on it from a hot wax, guilty for not rewaxing sooner but recovering from Covid and a bit lazy. I can rub my hand on it and not leave a mark.
Rear chain is lubed with liquid wax and is a little gunkier. It is on a recumbent and is more of a PITA to remove and therefore doesn't get as much love.
To redo the hot wax, I turn the crockpot on and throw the chain into it. After being in the melted wax for a while, I remove it and wipe off the excess wax from the exterior plate surfaces. Reinstall. Perhaps not kosher because I'm sort of using the wax to displace any metal particles but it achieves two purposes with one stone. Hands stay clean and no solvents although I use them to strip off the factory wax and if the chain got nasty but the front chain will get waxed soon, it is overdue
You don't really need a slow cooker. You can do it over your stove too.
Also- you don't really need to slow-cook the chain every time. After the first time, I just use drip wax. I think it's just as good. Just make sure the drip wax is not too cold. Warm the bottle up in hot water if needs be. If you want to be thorough, you can take the chain off, immerse it in drip wax inside a zip lock bag, and put the zip lock bag somewhere warm so it can penetrate the chain.
Drip wax can supplement hot waxing, but it doesn't flush the chain clean. Extended use of drip waxing can start introducing wear due to the contamination locked inside the chain by the wax.
Of course in hot waxing that contamination is transferred to the hot wax, but it's easy enough to clean by scraping the bottom of the hardened puck clean every year or so. But for touring purposes I think drip waxing is the way to go.
I only have to melt wax once in two to three months. I power the slow cooker on and in an hour or so I'll have a pot of wax which hasn't overheated and hasn't caught fire. And If I've been smart all of the chains are already waxed by that time. A stovetop requires one to watch over the melting process lest the wax overheats or starts vaporizing or catches fire. It's also easy to inadvertently overheat the wax on a stovetop as the wax at the bottom of the pot can already be way too hot while the surface is still solid. It's not uncommon to get the bottom wax to 150C or more while the top is still solid. Going over 100C isn't great for the wax. So the melting needs to be done with pretty low heat anyway and that takes time that could be spent better.
I treat all used chains at once and that's the main workload I do only every few months. The sorting doesn't really take time as every bike has a peg where the chains of said bike are hanged. So I just hang the chains to drip. When they're cooled I take them off the wire tools and hang them on the pegs. Used chains get put on the same peg already laced in the waxing wire tool so no mixups are possible.
If I treated every chain individually I'd be spending more time on watching over the wax and I'd spend more time with the actual waxing process since I wouldn't get the time bonus of treating multiple chains at once. Now I have far more say in when I do the waxing. And while waiting for the wax to melt I can either do something useful around the house, get some work done, or drink beer and do other bike maintenance tasks that have accumulated to my to do list.
It's just easier having every bike usable and ready to go whenever we want to use them. If a bike was in maintenance queue when I wanted to use it, that'd be a real bummer.
Quoted: 4338 Post(s)
Liked 1,522 Times
Liked 1,522 Times
My mortiser uses wax on the slides and gear, the radial arm saw uses it on the post that raises and lowers the arm. The bandsaw, table saw, jointer and planer all have their cast iron tables/work surfaces waxed to inhibit rust and make the surface smoother for the boards to move over.
Liked 2,906 Times
In my years at the bike shop, it was my experience that even so-called "knowledgeable" cyclists use WAY too much oil on their chains. I'll say that again: WAY. TOO. MUCH. OIL. I guess it falls under the adage of, if a little is good, lots must be way better.
Likes For Hondo6:
