Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Tire width
Old 08-11-18, 04:51 PM
prankster
prankster's Avatar
Bikes: 2017 Spez Allez Sagan Superstar
Quoted: 14 Post(s)
Tire width
Hello,
I just started getting into track racing. I bought a used track bike with HED Stinger 6. The tires on them are 22mm wide. The widest tubular track tires on sale at the moment is 23mm. I have been road racing for several years now. Coming from road racing, this is all new to me.
Is there a trend of going to wider tires (25mm) on track racing? If not, is 22mm as fast as 23mm on track?
prankster is offline
Old 08-11-18, 07:15 PM
JimiMimni
Quoted: 30 Post(s)
Based on my limited experience, there are a few things to look for in track tires, in addition to width. You need to consider the total rolling resistance of the tire, and the rolling resistance at the pressure you intend to use, as well as how the tire width and rim width interact. If you take a listen to the CyclingTips podcast episode from the TTT in the Tour, Josh Poertner, formerly of Zipp, talks about his 105% rule. For maximal aerodynamic advantage, the rim should be 105% wider than the tire, at a minimum. Your current setup should be good, provided you have fast tires, and frame clearance for the Stingers.
In general though, yes, wider is slowly becoming adopted by the track community.
JimiMimni is offline
Old 08-11-18, 08:20 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
That’s interesting. I wonder if that is a trend happening indoors? Some of the advantages of wide tires on the road, like lower pressure, would not seem to be as big of an advantage on a smooth surface.
colnago62 is offline
Old 08-12-18, 02:32 AM
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 365 Post(s)
Liked 87 Times in 58 Posts
When tires get wide they will limit your gearing choices unless you put on a longer chain. I learned this after experimenting with 25mm tires. Stick with 22-23mm.
Baby Puke is offline
Old 08-12-18, 12:46 PM
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
There might be a minimal, immeasurable advantage to going slightly wider on an indoor track. As you go through the banking, the tires will deform more because of the G forces. A larger tire deforms more readily with less energy loss than a narrower tire. You can counteract this in a narrower tire with higher pressures. For indoors, my guess would be 22-23mm would be fastest if you aren't running high pressures. Ultimately, my guess would be narrower rims and tires at higher pressyres would be fastest on an indoor track.
taras0000 is offline
Panza
Road Cycling
19
07-11-15 03:23 PM
chas58
31
02-24-15 03:29 PM
roka
Bicycle Mechanics
7
05-25-14 10:06 PM
goldfinch
Road Cycling
5
08-17-12 09:04 AM
rpalmer
General Cycling Discussion
3
05-27-10 04:44 AM
