Will my new bike take my weight or should I return it ?
#51
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
You should stop answering questions as if you have the least idea what you are talking about. You don't.
#52
Quoted: 2597 Post(s)
Liked 1,923 Times
Likes For pdlamb:
#53
Expired Member
Quoted: 3653 Post(s)
Liked 5,391 Times
You thought this because you don't know your arse from a hole in the ground. Axle failure is common, left unrepaired will cause further issues w/bearing life and possibly frame alignment. The exact same thing can be said about seatposts - they often bend and if not replaced will bend further with less force, and this can damage the frame too.
Likes For shelbyfv:
#54
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,095 Times
Also, the sky is sometimes falling, right, Chicken Little?
#55
Tragically Ignorant
Liked 9,095 Times
OTOH, Wilfred Laurier does know his arse from a hole in the ground. The hole in the ground is the one he isn't talking through.
#56
Tragically Ignorant
Liked 9,095 Times
I did bend a seatpost on a MTB and the OP is also using MTB.
I think you are more likely to bend a seatpost on a MTB than road or hybrid bike because you have more length of the seatpost sticking out due to shorter seat tube.
I bent mine just riding on bumpy roads, okay, it's a cheap post and I'm using a lot of setback at the time but....I've also read others bending their more expensive but stock seatpost on light trails with their hardtail MTBs.
Likes For livedarklions:
#57
Expired Member
Liked 5,391 Times
Now guys.... I mostly wanted to make the point that the thread had been trolled, second page onward. It's long past being of use to the (absent) OP. I'm done unless OP returns.
Likes For shelbyfv:
#58
Tragically Ignorant
Liked 9,095 Times
No, you misunderstood. OP's bike is a hybrid. It's a decent fork, but an inexpensive one.
#59
Quoted: 1034 Post(s)
Liked 1,289 Times
Thanks for the response, but you're wrong. All answers (with a few oddball exceptions) stated "it'll be fine but watch out for the following..."
And the recommendation for if any of those following things should occur? "that happens sometimes,, just get a new one". Nobody said 'axles may bend, so don't bother riding'
I don't know how much experience you have designing and building bikes for, or being, a Clydesdale (heavier) cyclist, but these are the things that come up all the time. The solution many have landed on is to encourage, but include some cautions about possible pitfalls, and explain that they are easy to overcome. The main obstacle to a Clydesdale is not frame and component failure, but becoming discouraged, and surprise mechanical failures, or unnoticed mechanical problems that increase drag and wear and therefore make riding less rewarding, are a very likely source of discouragement, so we think it's worth mentioning them when asked. OP realizes they are bigger than average and may have problems less common among lightweights, and sugar coating and glossing over potential pitfalls is not doing them any favours.
I do get that axles can bend, spokes can break, and on and on, but none of those failures are catastrophic, and the OP should not be so worried that they decide to not ride the bike, and give up on it altogether. So let's not throw countless mental roadblocks in the way of someone wanting to ride their bike.
Likes For phughes:
