1958 Raleigh Lenton Grand Prix
Friendship is Magic
Bikes: old ones
Quoted: 26394 Post(s)
Liked 10,367 Times
...this was a project that took some time. Here are some images from the first ride today.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
...I think this is the bike that Peter Kohler used as an example on his history page, as originally sold on ebay to someone else. Anyway, that's pretty much what it looked like when I got it. It had been a wall hanger.
Like all the "time capsule" bikes I've worked on over the years, this one had some significant mechanical issues. On the upside, it was pretty much all there. More later.
Quoted: 5888 Post(s)
Liked 3,471 Times
Cool bike, subscribing to the thread.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
...once you get them adjusted correctly and lubricated well, they are very solid performers. I think it helps that on the front of this bike, there's only a two tooth jump, from 47 to 49, and the chainrings are now pretty straight (after an hour or two of bending and banging on them. ) I honestly did not expect the rear derailleur to shift nearly as well as it does. Quite smooth and effortless. It runs backward, like the old Suntour Skitter. So with cable tension released, it seeks out the largest rear sprocket, and pulling the cable shifts it to the smaller cogs in back.
I did have a kind of near death experience figuring out how to pull out the broken pull chain remnant from the spring guide rod. It's designed to be in there free, with the anchor pin loose from fully seated by a full turn. So it should just screw right out. This one was pretty solidly seized in there. So after a session with a MAPP gas torch and some Freeze Off, when It was still not free, I was kinda stuck and looking on e-bay for a different one.
Then as I was looking at the damn thing in the bench vise, it occurred to me that the special tool I needed would look a lot like the slotted spindle you use to install helicoils. I looked at my collection of that stuff, and an M6 helicoil installation tool is exactly the right diameter to tap in there with a small hammer. It grabbed the top tongue of the pin and with some more Freeze Off spun it out easily. Here is a diagram of the assembly (courtesy of someone on Classic Lightweights).
Likes For 3alarmer:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Wow, that is a time capsule! Beautiful bike.
I've got one from the early 60's I think, but it's a totally different animal.
Mine looks like a standard roadster frame with different bits bolted on, whereas yours is designed as a "sport" bike from the frame on out.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
I have a Lenton Sports that splits the difference between those two. It has the graphics of Hudson's and the white head tube of the O.P.s. It's hard to find caalogs with these models in them, so knowing the year can be problematic.
Two fine examples of the gold here.
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
What color is yours? Got pics?
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Nicely done. Always glad to see another one back on the road.
Before . . .
. . . . . . . and after
Before . . .
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Likes For USAZorro:
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
I never understood the 49-47 combination. Several I have seen come with my personal favorite 49-46, which works brilliantly with something like 14-16-18-21-24 in back.
I am glad you got your bandspring rear derailleur to work satisfactorily. I gave up on a similar unit and replace it with an early Campag. Gran Sport, which was a huge improvement.
Bikes: Motobecane Le Champion, Raleigh International, Bertin, Raleigh DL-1 1980, Colnago Super,Follis, Bianchi Competizione, Brompton M6L, Black Mountain Monstercros
Quoted: 125 Post(s)
Liked 839 Times
Glad that bike found you Mike. Beautiful job and thanks for documenting your work here.
-D
-D
Likes For djkashuba:
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
...it was more or less all there when I bought it some years back. Most of the stuff I changed out was stuff I had around here in the "parts from god" boxes, and I took those 27" wheels Super Champion wheels off semething else when I changed it out to 700c last year.
...thanks. I never had a bicycle with one of these on it before. Simple and effective, but again, mine has only a two cog jump. Works flawlessly.
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
...rode it 20 miles today. I managed to put a small tear in my bike shorts from the combination of the narrow Brooks Swallow saddle and the original seat post and clamp, with the bolt end sticking out farther than the narrow nose of the saddle. Found a suitable 25.4 (maybe 25.5...I had to sand and wire wheel it a little to get a nice fit,) alloy single bolt post out in the post milk crate. Had to install an M8 helicoil in it to get it to work. I would have been disappointed if it had been easy.
I really like those shorts, so I hope I can repair them.
It rolls along about like you'd expect from a straight gauge 531 Raleighish club bike from 1958. It's not gonna set any land speed records, but it has to be much faster than it was with the original stainless steel rims and ancient tyres.
I was agonizing over how original to keep it, because it was so original. Then I put the wheels in a stand and saw how far off they were from dished on center. So it was an easy decision to make to go with a more rideable wheel set. I guess I could rework the original wheels, but I would then never ride the bike, so limited appeal in that.
Quoted: 221 Post(s)
Liked 237 Times
Are you having any shifting problems on the front derailleur on your bike? When I restored mine, I used a 10-speed (old nomenclature, 5-speed rear) chain on it although the derailleur seemed to have enough width to handle a single speed chain. So . . . . . I find out if I don't shift the front carefully and quickly, the chain drops between the chainwheels. And I do mean "between". As in getting the chain out means carrying an old screwdriver in the tool bag to use as a lever. It loves to stick itself down there.
By the way, my picture of the finished bike was taken immediately after it was put back on the road, and before I put the final set of wheels on it. Which are period correct (no, I can't remember what components I used, will have to walk out to the barn to check), bolt on hubs and steel rims, but aren't the factory specced components. Someday, hopefully.
I do love the more relaxed geometry of the bike, it's my second favorite ride after my Raleigh Tourist. And, boy, is it fun to show up at Ashland Coffee and Tea on a Sunday morning while the usual crowd is around. All those carbon Colnago's and Trek's . . . . . and the jaws hitting the pavement.
Syke
Syke
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
Note that at least one of the rims has been relaced with an Araya look alike, but I think the original Dunlop on the other wheel is the legit original. Also note how far off dish both wheels are as received. I suppose that by installing one wheel with the dish offset in the opposite of the other, the bike rode nicely sideways down the road.
It's interesting trying to scope out the history of these older bikes as I deconstruct and reconstruct them.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
Some other insignificant details that might be interesting:
...somewhere along the way, someone (not me) drilled the down tube for a bottle cage. When first I discovered this, I was disappointed, but then I considered that it's straight gauge steel tubing, and that worse things have been done in the name of progress. As sold on ebay, the holes were covered by some antique bottle and cage with straps as attachments. So the bike was probably ridden more than the ebay "historic time capsule" version would suggest.
Anyway, when life gives you lemons, you thread the holes and use them to mount a bottle cage.
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
...finally, the original bar and stem of steel. And the original pedals that work out OK for me with my wide feet using spacers.
Friendship is Magic
Bikes: old ones
Liked 10,367 Times
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
My Lenton has typical English 26" roadster wheels, albeit with a 5-cog freewheel, but I've got an early 60's (Raleigh-made) Triumph Sebring with Dunlop 27" clinchers. I'm also torn on which direction to go with the Triumph, because I love all the unusual old components. The rims are in decent shape, and would probably be serviceable with Kool-Stops. The Lenton however, will likely get 700s laced to the original hubs. My Lenton just isn't as rare or unusual as the examples that you guys are sharing.
Likes For Hudson308:
Quoted: 339 Post(s)
Liked 631 Times
If anyone on this thread is still out there, I just found a 1958 Lenton grand prix and want to know if anyone has found a match for the gold frame color.
