I Hate Garmin
I Hate Garmin
I'm writing this while I'm still pissed, b/c it's been about 3 days and I can't get my Garmin Edge 130 plus out of sync mode. And I can't download what the unit said is a software update. I just looked at my clock and I've probably been at this about 2 hours. This is on top of the couple - 3 hours I spent on this a few days ago. And the Garmin website is USELESS. I'll have to call Monday and waste more time.
Garmin Connect is supposed to auto sync w/my Edge and other Garmin devices. But of course it never does. And when I do it manually there is often a glich. Also, Connect always says "Complete setup" b/c I don't want to do the emergency notification feature - which doesn't let you decline. No, Garmin, I don't want to give you tel numbers/info of other people.
Yes, I'm VERY frustrated at the moment, and when they work my Garmin devices are good. But there are clearly gaps in the software of the apps and devices. And we know they know this -- but IMO they're willing to live with some level of dissatisfaction by users as long as their bottom line isn't affected. That's not right.
So righ now, I HATE GARMIN.
Thanks for listening.
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,432 Times
Attach it to a desktop computer via USB and update it that way. If that fails, wipe it and set it up again.
It should take no for an answer for the emergency contact. Mine do (including wife's 130+).
Quoted: 818 Post(s)
Liked 1,653 Times
Press and hold the POWER button for about 20 seconds. This will force the unit to a soft reset. Then follow Polaris OBark's suggestion.
"No, Garmin, I don't want to give you tel numbers/info of other people." Oh, I wouldn't worry too much about that. After all, anytime you use a GPS unit on your ride, your location information is transmitted to the mother ship of the aliens from Flattirera, who then decide if they want to send down their death ray beam to your wheel and free all the trapped air inside.
Garmin Connect does not take "no" for an answer on my iphone.
And, I've already done the wipe/reconnect twice. And tried to use Garmin Express -- which refuses to find my unit.
Liked 3,432 Times
But try doing the update via USB.
Also, if you have a lot rides in there (saved as individual files), you might have to delete them manually to create enough space for the update.
These kinds of things shouldn't happen, but they sometimes do.
Quoted: 3237 Post(s)
Liked 2,082 Times
Make sure when you attempt an Express connection that you are using a data cable for a Garmin. Not all cables will work.
Likes For Steve B.:
Bikes: Caloi MTB, Raleigh heritage international
Quoted: 30 Post(s)
Liked 58 Times
I have a love/hate relationship with garmin. I love my devices when they work but heaven help you if you have a problem. After I updated one of my handhelds it incorrectly interprets the battery state. Also, my map that I purchased by garmin no longer works. Luckily I get the free ones on gpsfilesdepot.com. I got this one for someone else to use on a boat but we got rid of the boat so I was using it in my handheld. It worked fine until it didn't.
And don't get me started on stupid features and lack of useful features. For instance, on my 64 (and others) there is an "odometer" feature. You cannot clear it. It is the result of where you've gone the entire time you've been using the GPSr. This is different from the trip odometer that you can reset.
But there is only one trip odometer. So If I want to record the distance of a particular leg of a trail I'm hiking I can't. I could if I could clear the trip odometer. My car has two trip odometers. I think I've had bike computers that have had more than one. So I called garmin to see if how I could clear the "odometer". They said I wouid have to do a factory reset. In other words lose all my carefully recorded tracks and waypoints, and who knows what else. I know I know, I already have them backed up but that's not the point. I asked the garmin person in what circumstance would that feature be useful, an odometer that could not be reset by the user. What information is it giving someone? They got quiet and I hung up.
But is seems there is no alternative so I will keep on using them and just dealing with their lazy software issues.
Don't get me started on basecamp.
Quoted: 6962 Post(s)
Liked 10,961 Times
A lot of good advice here. I'll add that, if none of it works, you might try calling Garmin. It's been a couple years, but when I had issues and called them a couple times, they were very prompt and helpful.
Likes For znomit:
Quoted: 4254 Post(s)
Liked 1,353 Times
There are two types of USB cable.
- Charging only (which will not work).
- Charging and data.
Garmin’s cable is the second type (and, conveniently, has Garmin printed on it).
Likes For njkayaker:
Quoted: 6193 Post(s)
Liked 4,808 Times
If you are having an issue with your Garmin device and the Garmin App then call Garmin support. You can opt to leave your call back number with them and they will call you back. That way you don't have to sit on hold in the phone queue and can go about your business.
Doesn't matter whether your device is new or very old.
aged to perfection
Quoted: 837 Post(s)
Liked 1,254 Times
the comment made above about the device being completely full is telling.
Eventually you have to delete some ride files (*.fit)
that could well be why you are having difficulty. Hold the power button down for 30 sec.
the problem I've had with Garmin devices is that the USB socket will not connect, contacts worn.
otherwise I'm a fan
good luck.
/markp
otherwise I'm a fan
good luck.
/markp
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
My experience with Garmin Customer Support was excellent. I had a small cheap computer that insisted on turning my Bontrager flashers off. I called Garmin, sent in the unit, and they sent me an upgraded version (factory reconditioned) at no charge. I don't keep ride records so that was not a big deal.
Likes For Inusuit:
long story short i listened to some advice here and was able to finally get the unit to sync with Express (which i had to reinstall), got the software update and sync. don't know if it will sync thru Connect yet.
went back to look at solutions on the Garmin website: IMO a Tower of Babel. much better advice here. thanks all. (i still hate Garmin.)
Likes For gene99:
Liked 2,082 Times
Likes For Steve B.:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Quoted: 270 Post(s)
Liked 447 Times
Liked 10,961 Times
Is there a way to delete old ride files en masse - without hooking it up to a computer? I've just been swiping left on them, one at a time, and then hitting the 'delete' button.
Likes For Koyote:
Randomhead
Liked 3,696 Times
I wish people on their forums would go back and say what worked for them more often. I usually find what I want there. I also still hate garmin, they can never pay me back for the crap I've had to put up with due to their products. I'm just hoping Wahoo sticks around, otherwise garmin will go back to never updating their devices.
so i called Garmin re an issue with finishing setup on my Connect account, and the person i spoke to inisited there is no need to clear history on the unit. he said it will do that automatically if needed, and/or compress files if an update requires.
Liked 4,808 Times
So did you get your original issue resolved when you called support? The suggestion of clearing the memory may have been a red herring that you shouldn't focus on.
Liked 1,353 Times
If people are having odd issues with their Garmin unit, it might make sense to clear-out the activity files. If these files are being uploaded to Garmin Connect, there’s (generally) no reason to keep them on the unit anyway.
There’s a limit of 100 courses and these are not deleted by the unit. So, these have to be deleted by the user if there are too many of them.
The Garmin devices don’t compress files.
The problem with activity and course files isn’t with having enough free space. The problem is related to the number of files (which wouldn’t be affected by compression).
so before i spoke to Garmin i started to delete files, but found the only way was individually on the unit. (i delected them on Express but it didn't also delete them on the unit.)
any other way to do this? (so it doesn't take forever.)
