Replacing rear alloy on carrera crossfuse 21 inch
Hi guys
My rear wheel got hit out of shape on my carrera crossfuse 21 inch.
The rear wheel rim is warped out of shape so i have to change it. The halfords guy was quoting aroung 80 pounds . Was wondering if i can get cheaper, but still good. Where to get and which ones? After i get them, will take it in to halfords to put together and check. Cheers for any advice
Bikes: Way too many
Quoted: 897 Post(s)
Liked 606 Times
If there's a local bikeshop near you then you can see if they can straighten it for you, which should be cheaper than replacing the whole thing. It could be as simple as the spoke tension.
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
Hi guys
Quoted: 6193 Post(s)
Liked 4,808 Times
Depending on why your current wheel is warped it might be very fixable by a wheel person at a bike shop. Not a department store.
If you decide to get another wheel then after you've ridden it for a while, take it to a wheel person and let them check it. Do the same for your other wheel that isn't messed up.. yet. Spokes sometimes loosen up after the initial use. Particularly machine made or mass produced wheels on a assembly line.
Price you were quoted seems very reasonable for a budget wheel.
welcome to BF!
welcome to BF!
Likes For Iride01:
