Need Recommendation: Cable Cutters
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
I use a set of Pedro's clippers. Work great, very precise cut. The parks are good too though, IME.
Likes For f4rrest:
Quoted: 4559 Post(s)
Liked 2,802 Times
Likes For canklecat:
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I got Master Force Cutters at Menards for $9.99. 8 inch cutters have used for past 3-4 years. Way cheaper than bike specific cutters and much better more durable. These slice through cables not a bit of fray like razor sharp.
Likes For deacon mark:
Likes For timsmcm:
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Likes For speedevil:
Quoted: 4221 Post(s)
Liked 2,943 Times
Likes For himespau:
I think Park Tool is a professional cable cutter even though they are a bit expensive. But if you want a cheaper price and still have quality you can check out Klein Tools 63050
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I was working on some project bikes and cutting more cable than usual, so went to my LBS and asked what they used. The tech was working with the SRAM cutter at that very moment. I bought it. It's very nice.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
I have a set of XLC cutters at home. I have to admit that I use them more for cutting spokes than cables but they still (after that abuse) cut cables cleanly. I've used most of the major brands at the local Co-op and can't say that I can tell any difference between them.
Quoted: 641 Post(s)
Liked 1,517 Times
The first time I did cables I looked in my toolbox and found some Thomas and Betts crimpers. The cutter on these worked great so never went and got a task specific tool. The crimper works for the cable ends as well.
Over the hill
Quoted: 995 Post(s)
Liked 1,203 Times
Someone once suggested a Dremel w/ cutoff wheel, and it seems to make cleaner cuts than anything else I've ever tried.
It's like riding a bicycle
Liked 2,943 Times
Over the hill
Quoted: 995 Post(s)
Liked 1,203 Times
Housing only. I don't know what that would do to braided cables, and those get crimps on the ends anyway.
Quoted: 800 Post(s)
Liked 512 Times
How often are you guys crimping and cutting cables? I've been doing my own bike work for the last three seasons and I haven't needed to crimp/cut a cable once. Or are you just stocking up on tools 'just in case'? Nothing wrong with that. I do it all the time.
Liked 2,943 Times
If you build up a bike from a frame. Or you just want to recable the bike (usually ever couple years for me), or you want to put new bars/shifters on, you'll need them.
Likes For himespau:
Quoted: 344 Post(s)
Liked 297 Times
What himespau said, but also some bikes come stock with cables that are too long for some riders' tastes. Different people replace cables at different periods. After 3 years, you're probably coming up to the time when you'll need to do it soon.
Likes For Leinster:
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
I've had the same pair of Felco cable cutters in my toolbox for 20 years, have not found reason to seek anything else.
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
I’ve used fence pliers for many decades, certainly the last forty years. And a pointy punch to open out the end of a cut cable housing. My current pliers say Diamalloy R500.
They are equally good at crimping on and removing cable ends.
Clearly, I bought these a long time ago. They are now considered vintage and Diamond Calk and Horseshoe Co. is long since gone.
Otto
Otto
I am using the Crescent Porter wire cable cutter tool that cost $30 and it works very well. The Dremel cut-off wheel works well but does take longer as I need to take out the tool and mount the cut-off adapter and an abrasive disc, and then put it all away when done. Much faster to grab the Crescent cutters out of the tool cabinet and cut the cable and then put them back in the drawer.
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
My Park Tool cutter works fine with wire cable and cuts housing easily--but mashes the spirial flat. I have a bench grinder in my workshop, and that makes quick work of the mashed spiral housing. A dremel would work for this, but it would be slower. I dip the housing in water to keep it from heating up. I get a perfectly square end to the the housing, and finally a large sewing needle opens up the wire hole.
Liked 2,943 Times
I've seen comments about cutting the cable itself (not the housing) with a Dremel cutoff wheel. I tried it on the long cutoff end for my front brake cable. Nope: it flings individual strands off the wire cable, so the cable gets extremely frayed. Wrap with tape and cut? No better.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Diagonal cutters for all cables and brake housing. SRAM cable cutters for shift housing only. In nearly 30 years of doing this for a living I've never used a Dremel for anything housing related. Nor have I determined I'd be doing a better job if I used a bench grinder.
Pro tip: Park small flush cut diagonal cutters work awesome for zip ties.
