6-speed freewheel suggestions
Quoted: 39 Post(s)
Hey, I thought about posting in Classic/vintage, since this would relate to older bikes, but it's more of a mechanical issue--I wondered what people have found works well as a replacement/upgrade 6-speed freewheel. I've got a mid-80s Super Galaxy, currently with 5 speed freewheel, Maillard Sachs type, and I'd like a bit more range and maybe smoother running. Local bike shops have either the Shimano Tourney or the Sunrace equivalent 6-speed. I've also seen a few odd 'Mega range' freewheels available, going up to 34t in the lowest gear... not sure the chain would be long enough, though.
Does anybody have experience with other freewheels? Is it possible to switch to Campy here, or a higher 'level' of Shimano? My chain is in good shape, and I'm hopeful that the angled teeth on the Shimano Tourney would make things a bit smoother already.
I suppose another possible option would be a 7-speed, as there's a fair amount of margin there, though I'd have to stock to friction shifting, as the 105 shifter is only 6-speed. Any advice appreciated. Thank you.
any shimano 6 speed freewheel should work for you . I would stay away from Sunrace , they cheap and don't last very long . you might need to spread the frame alittle for the new one to fit .
Really Old Senior Member
No idea what a Super Galaxy is, but does it have French threaded hubs?
IF so, you need a French FW.
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
maybe you want to check the "OLD" width. many 5 speeds were 120MM and 6 speeds are 126MM.
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
My favorite freewheels are Shimano's Dura-Ace and 600 models from the mid-80s. They're getting harder to find, though, and the cost is going up. I suspect a modern IRD or SunRace freewheel ought to work well enough. Don't even think about Campagnolo freewheels, unless you have money to burn and don't mind a 28T maximum size large cog, assuming you can even find one. Depending on the specifics of the new freewheel, you may need to adjust or replace the rear derailleur, change the chain length, and/or re-space and re-dish the rear wheel to get clearance.
Bikes: '85 Bridgestone 400
I go through freewheels pretty quickly. The DNP EPOCH 5 Speed Index Freewheel Bike 14-24 is cheap and sturdy. It'll also fit your hub and frame perfectly. I agree SunRace wasn't my favorite freewheel. I have found cheaper freewheels than SunRace that perform better.
I have ridden my friend's Shimano Dura-Ace. They are amazing but out of my price range.
Quoted: 1943 Post(s)
Liked 2,164 Times
Well I found out your Super Galaxy is a Dawes touring bike. If you can fit a 7 speed freewheel in there instead of a 6 speed you will have more of a selection and get hyperglide. As mentioned above you need to measure the overall dimension between the locknuts on the hub or the distance between the dropouts on the frame.
As also mentioned Shimano Dura Ace and 600 are my first choices in a 6 speed uniglide freewheel. The same for 7 speed and I would add a Sachs Aris that indexes fine with Shimano. You can go with more range (32t/34t) if you swap out the rear derailleur to one with a longer cage. It doesn't have to be a 6 speed derailleur to work with a 6 speed freewheel. I don't know if an 8 or 9 speed with narrow pulleys will have enough room between the cage side plates for a wider 6 speed chain, but indexing should not be a problem. I run 7 speed chains with 9 speed derailleurs with no issues. I'm sure someone can provide better info on whether a 6 speed chain will run through an 8/9 speed derailleur.
John
John
The Tourney (TZ 20?) 6-speed freewheel is about as good as anyone needs. Clean-shifting Hyperglide cogs, and an innovative design that removes a lot of weight.
I have about 100 pounds of freewheels and freewheel cogs that include multiples of Sachs (6,7 and 8 speeds), Dura-Ace (6 and 7 speeds), Shimano 600, and several Suntour units (Winner, Winner Pro, New Winner etc.). Plus newer freewheels such as Sunrace, Shimano, Falcon etc.
I am guessing that the super-hard Dura-Ace freewheel cogs would outlast the Tourney ones by years, but the Tourney freewheel costs what? $12? An outstanding value.
BTW: I have only come across one used bike in which the chain was *not* worn out. Out of hundreds of bikes. Chains are cheap. Buy cheap and replace often.
Likes For Dave Mayer:
Quoted: 39 Post(s)
Sorry for not specifying; in the UK, Dawes Super Galaxies are pretty common. I'm not sure about the hubs, but I'm posting some photos. The smallest sprocket says MAILLARD, if that's an indication.
Quoted: 39 Post(s)
Another point I should have mentioned. The dropouts measure 120mm, and I don't have calipers to easily check the OLD, but as shown in this photo, there is some room, as the dropouts aren't tight to the locknuts. I would estimate there's maybe 6mm on the side (so I have to first tighten the QR skewers to press the dropouts in, before actually tightening the lever to hold the axle in place).
Quoted: 39 Post(s)
Quoted: 39 Post(s)
My favorite freewheels are Shimano's Dura-Ace and 600 models from the mid-80s. They're getting harder to find, though, and the cost is going up. [...] you may need to adjust or replace the rear derailleur, change the chain length, and/or re-space and re-dish the rear wheel to get clearance.
Quoted: 39 Post(s)
I bought the bike used, but the chain seemed to have just been replaced.
Old fart
Liked 3,395 Times
Great stuff! I'm going to have a look around for these. My derailleur is a Shimano 105 from a 7-speed bike, so I would hope it would fit nicely with the 600 or Dura-Ace stuff. Would they likely give me a lower lowest gear, or just smaller steps? My current freewheel is 12-24T.
Is this the type of 600 model you mean?
Old fart
Liked 3,395 Times
Malliard did not survive the Sachs buy out by Sram , the take over had no interest in their company.
Now the spline shimano remover is common in many SEA freewheels as is the hyperglide pattern cog toothing..
Quoted: 86 Post(s)
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Anyway, Uniglide was an improvement over the awful Italian and French freewheels that preceded them, and that I rode for decades. I don't know how many Regina ORO freewheels I broke or just wore out. Good riddance to all of that crap.
Based on a gazillion miles riding on freewheels, here are my rankings of the smoothness and speed of shifting for different freewheels. Higher is better:
- Atom, Regina, Everest - old French and Italian crap: 3
- Shimano Uniglide: 5
- Suntour with the later chisel-shaped cogs: 6
- Sachs: 8
- Suntour Powershift: 8
- Shimano Hyperglide and knock-offs from Sunrace: 9.
This is all relative to the Camapgnolo Record 10-speed system I've been riding to work lately. I'm rating it a 10.
Best ever shifting: Shimano Alfine 8-speed internal gear hub. No overshifts, undershifts, missed shifts. No noise, no hesitation. Fastest 'gear' transitions I've ever experienced. No maintenance after 5 years. I would have to rate this a 15.
Quoted: 39 Post(s)
- Sachs: 8
Thank you! I love this whole post, which has given me plenty of useful leads. Anyone else think this should be sticky, for old-school mechanics?
My current Maillard FW must be grouped in the 'old French crap,' which I can accept .
Has anyone tried the Sturmey-Archer 8-speed hubs to compare with Alfine? They're def. not cheap, but seem to be the only hub of that kind for narrower old frames like this one.
8th cog on a freewheel is a bridge to far.. have to tear down the last 2 cogs to grip the freewheel tool.
+ the axle is even more likely to Break
time to just go with a freehub at 8 speed if wanting derailleurs.
reading the specs: the gearing in the 8 speed S-A IGH is all overdrives but the 1st one .. best suited in little wheels .
Or, You have to run a chainring less than 30t to have much in the way of a low gear with the 20.23.or 25t hub cogs.
Alfine/nexus the near 1:1 gear is towards the middle so some Reduction and some Overdrive ratios.
3 speed .. 1 over and 1 under middle is direct. 5 speed adds 1 higher & 1 Lower..
Quoted: 443 Post(s)
Liked 27 Times
