Hills and cog size
Hills and cog size
Having a tough time traversing the hills which surround my home cycling area (I live on the side of the largest hill in RI). I can do it - with some exertion - on my modern 21 speeder, but the 52-42 crankset on my Dawes is just not enough reduction to "get there". Are smaller cogs available for my Stronglight cottered crankset or do I need to move on to a cotterless set, which I'd rather not spend the money on.
Quoted: 359 Post(s)
Liked 582 Times
Back in the days when men were iron and bikes were steel.... I just don't know.
There are a lot of Stronglight guru's here.
I can only recommend the muggleBay site, and if I remember, a lot of Stronglight rings on Bikeinn.
I remember a coupla hills in Newport, a few on the way to Barrington via the New Hope Bridge,
and maybe one or two near URI....but RI is not flat, that's for sure.
BCD is your gotta-go-to number.
Quoted: 4790 Post(s)
Liked 3,918 Times
I don't know the answer. You have 6-spider chainrings of BCD = ? (BCD - bolt circle diameter.) TA made (And I believe still makes) 6-bolt chainrings and that many of the Stronglight and TA cranksets used the same BCD but not all.
Measure your bolt to bolt distance. (Often far easier to get accurately than finding the BB spindle center.) Post it here and quote me. I can easily tell you the BCD since I have a CAD program.
I used to live in Rehoboth, MA closer to Barrington. I now live out in the western part of RI in between the highest point in RI and the Scituate Reservoir basin. Nowhere to go but down - and back up again!
Quoted: 4722 Post(s)
Liked 3,036 Times
You could get the inner chainrings as small as 36T. Whether or not you can still find them, at a reasonable price, is another story.
Likes For T-Mar:
Quoted: 359 Post(s)
Liked 582 Times
Papa Brillo's, Jade Tree, Salas's, and the Fri night fundraising dinners at some Catholic schools were better than a lot of restaurants.
Where else can you get crab cakes and stuffed quahogs for the Lenten meals on Friday nights, right?
Newport had the pricey good stuff.
Heading inward found the reasonable great stuff.
Knowing someone revealed the truly amazing.
I don't think everyone was a Mayflower family, but many claimed it so.
Seekonk, Swansea, and "Wooster" had some killer mom/pop restaurants. I have no doubt I entered into Rehoboth unwittingly.
Sounds like I just need to keep an eye out on eBay for Stronglight chainrings. 79pmooney, I can work out the BC since I too work with CAD daily. I'll post the size here.
If you like your Dawes - and I can understand having trouble knowing if you like it with your gearing and your hills - I think your best bet is to look for something like a TA Cyclotouriste/Pro 5 Vis crankset or a Japanese triple. You can still buy brand new chainwheels from TA, though they no longer make the crankarms. Velo-Orange sells the arms, though they're pricey. That's if you can't find something used. Since I like the Reynolds 531 bikes I've ridden, I think it's worth the investment, but it's your bike. (From what you've written elsewhere, you may be more comfortable on a smaller frame, though.)
At one point, I rode up College Hill on my Raleigh Sports; that was maybe 1958. Later, I rode from East Providence to Newport on 49-46 up front and 14-26 on the back, maybe 1984. Today I ride 45-42-28 up front and 14-28 in the back, and most of my riding is in flatland. Some is in RI and NY; hence the triple. Oh to be 30 again! Or even 50.
The best place for clam chowder ever in RI or any other place was my house, when my mom was alive and cooking.
Palmer
Quoted: 1659 Post(s)
Liked 1,806 Times
Climbing gear from that era:
Likes For tcs:
Edumacator
Quoted: 2434 Post(s)
Liked 3,107 Times
I think it will be cheaper to get a crankset than a chainring for that particular crankset...
Likes For jdawginsc:
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,586 Times
Those 3-arm cranks were also made by Nervar, Solida and others and were often used on cheap French bikes. I got me one of those once for a handful of euros, which enabled me to go from this ...
... to this:
Granted, the cheap 50/38 set is nowhere near as pretty as the original 52/49, but mated with a 14-28 FW it gave me a much more useful gear range.
... to this:
Quoted: 5888 Post(s)
Liked 3,471 Times
Cheapest solution is likely to be a large freewheel. You could put a WTB for a 14-32 freewheel on the C&V for sale forum and see what shows up. You will likely need a different RD though plus a bit longer chain.
Likes For bikemig:
Quoted: 1105 Post(s)
Liked 1,326 Times
Likes For oneclick:
The 42T front ring is fine.
Buy an Ultra-6 freewheel in the 14-34T version, or something similar.
Get a wide range (long cage) rear derailleur. Even if intended for a mountain bike, it will get the job done.
You might need a new chain, too.
A 42T front into a 34T rear should get you there.
This is an inexpensive and easy conversion.
That freewheel also has a lot of good cruising cogs in the rear, so don't worry about that.
This is what I use when I know I'm getting into some steep, long mountain roads.
Likes For Bad Lag:
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,186 Times
Suntour SProCompe 5 Speed, 14-16-18-24-32.
Bob
Bob
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
The 3-arm, 116mm BCD crank was pretty common BITD.
Palmer
Liked 1,806 Times
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Would it be possible to convert to a triple to give you some more options when climbing?
Quoted: 1854 Post(s)
Liked 661 Times
I don't remember the chainring bolt layouts, however, for the French cranks or the British ones. Brits like Raleigh and Dawes were more commonly 52/45 and such, but with a lot of variation among models, years, and ... the phases of the moon?
As long as you get a replacement chainring with plain teeth and the screw holes in the correct place, the choice of steel or aluminum should not matter very much, so if perhaps Peter White or another shop has the correct ring you have some flexibility.
Caveats: 1. With a smaller small ring and no other changes, you might need a few more links in the chain. 2. With a smaller small ring and no changes, you might need a front derailleur with a deeper cage, in case the chain drags on the tail. 3. If your rear derailleur is near it's wrap-up limits, you might need one with a longer cage.
Something, maybe the craze for valid Eroica bikes, is driving up the market for vintage derailleurs which can handle wide gearing. I'm amazed at the prices for formerly disrespected items such as Huret Allvits, Simplex dual-pivot rear derailleurs, and Campagnolo Valentino and Tourismo, especially the longer-cage versions (the Valentinos do not have the range to be valid replacements for your original). If your original derailleurs are not at their limits, it's probably smart to limit your gearing upgrade to what the existing derailleur can handle without being stressed. The issue with stress is that these are nearly 50 year old parts and they were not the highest-end availalble in the day. If one breaks it can be hard to replace for less than the value of the bike.
I measured across hole centers and it looks like I have the common 116 BCD, 3 arm crankset. It would be nice to simply swap the 52-42 for a 52-38 or something. I just upgraded the derailleurs from the worn out Simplex to a nice set of Huret Challengers and I'd hate to spend yet more money on different derailleurs..
Although as discussed elsewhere, the Dawes frame will do, size-wise, It was a cheap-bike first attempt at fixing up a vintage 10-speed and not in the best shape cosmetically so I'd hate to put good money after bad. I was thinking I could keep it for flatter terrain and buy a slightly more modern, yet vintage bike with cotterless crankset that is more readily upgraded.
Liked 3,471 Times
https://velobase.com/ViewComponent.a...B8E8D&Enum=108
Shifting is fun!
Bikes: Yes, please.
Liked 4,586 Times
AFIK the "Super Galaxy" was the same frame, but with high end parts.
Likes For non-fixie:
Quoted: 61 Post(s)
Liked 254 Times
I don’t know the specifics on that frame, but if it can accommodate a square-taper bottom bracket, your local community bike shop may have options for cranksets that will either just work or will at least have BCDs that allow trying different chainrings (maybe also available at the community bike shop). I went down a similar route for my vintage road bike that had a three piece crank and very tall gearing. I ultimately put a Sugino triple on it that I think was made for replacing stamped steel chainrings on older mountain bikes and hybrids. It did the trick for me.
