Huret Allvit rear derailleur
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
I'm trying to disassemble a Huret Allvit RD just to clean it up, re-lube, and re-assemble. I'm stuck on the jockey wheels. I've got one free of the cage, but I'm not sure how to get to the ball bearings. The other one, I can't get the nuts loose to remove it from the cage. The nuts are circular with two flats, so a socket won't fit; I think my only option is an open-end wrench. The nuts are low-profile, too, so it's easy to slip when you apply torque to the wrench. Any tips?
Quoted: 3504 Post(s)
Liked 2,924 Times
Make sure you have the right-sized wrench?
Quoted: 4200 Post(s)
Liked 3,853 Times
A cone wrench (IIRC 13mm) will fit these pulley cones. Like some low cost front hubs, the cone/bearing preload is held by the cage bolts (axle nuts in the hub example). So some trial and try again is the usual process to find both the best cone/pulley spin after pulley bolts are tightened.
For a budding wrench these Allvit ders are a great training ground for basic assembly skills. How to set bolts and lock nuts to allow for freely moving pivots but no slop. How to work with springs that fight your fingers. And the older bike need, how to adjust cup and cone bearings. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 282 Post(s)
Liked 129 Times
