Does Cyclocross damage road wheels?
I found expensive year-old road wheels for sale at ~40% off list. Drawback: the seller says they were used for cyclocross.
If they look undamaged and are true, can I assume they will be fine? My concern is cyclocross appears to put a lot more stress (dirt/mud...) on wheels than normal road riding and there might be unseen damage. True or nothing to worry about?
Thanks!
Thanks!
Bikes: Neuvation F100, Surly Cross Check, Van Dessel Holeshot
it is hard to say, as it depends on the rider, but what really damages wheels is low volume high pressure tires, which is the opposite of a cyclocross tire.
Overacting because I can
Bikes: Merlin Agilis, Trek 1500
I ran my Kysrium SL for cyclocross this fall with no problem and plan on using them as road wheels this spring. If the braking track still looks smooth and you don't see any dings in the rim or deformations, go for it.
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
As a wheel builder in a cross crazy area I can say with good authority that yes....it can.
Grit and grime/sloppy conditions can help accelerate wear on braking surfaces. Apart from that if the wheels are well built and were applied correctly (eg no one is using their 16 spoke TT wheel for cross) then you can mitigate the damage cross does to wheels.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
aka mattio
anything CAN damage a wheel, but i don't think the fact that they were used for cross would change how you evaluate them. feel their bearings. feel okay? spin them - look true? ping the spokes - sound evenly tensioned? good.
Alias530
16
12-03-14 11:28 AM
mgmannin
9
12-06-09 05:57 PM
